48C Edge Deck - How bad is this bent? Best way to repair? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 04-22-2019, 12:43 AM Thread Starter
demonspeed's Avatar
I just picked this up as I wanted to downsize from my 54”. I didn’t do very good checking it over as I’ve realized since getting it home and mounted that it needs sheave bushings and the tensioner arm/spring. It also has a small crack at the right-rear scalp wheel and on the right side draw bracket. The cracks shouldn’t be too hard to weld, right?
Most concerning is the right-front edge of the deck appears bent. This appears to not only be bent back, but also caused the scalp wheel to be angled down. It also looks like maybe the top (where the chute bracket would sit) before it rolls forward is bent, but I’m not sure if that is supposed to be flat or actually have that “dip”.
Is it actually bent and how bad? Any pics that I could compare? What’s the best way to repair so that I don’t make it worse? Do I straighten it before welding, or weld first then straighten? Could the crack at the draw bracket be tied to this being bent? Do you think I could get through this season before repairing, or could the cracks get worse?
ID:	2373233   Click image for larger version
ID:	2373235   Click image for larger version
ID:	2373237   Click image for larger version
2004 John Deere GX345
48” Mower|48" Blade & Angle Kit|42” Thrower
Front Bumper|Halogen Kit|5x42# Weights|Carlisle HDFT & Xtrac
FOR SALE: BM20827 54” Mulch Kit
Message me if interested! I need it gone!
demonspeed is offline
post #2 of 16 Old 04-22-2019, 11:27 AM Thread Starter
demonspeed's Avatar
Re: 48C Edge Deck - How bad is this bent? Best way to repair?
I decided to measure the chute opening...
Top opening width is 13-7/8” ID
Bottom is 13-3/8”
That's a half inch tweak... that should be the same top and bottom, correct?
post #3 of 16 Old 04-22-2019, 11:56 AM
AKA Moses Lawnagan
KHodges's Avatar
Bottom is 13-3/8”
That looks about right. My guess is, the whole front of the deck lip, from the front lift mount to the chute got pushed back a little when the previous owner ran into something, and the crack at the front lift bracket is part of that. The right front gauge wheel bracket is probably not moved in relation to where it is mounted, it's just cockeyed because the whole section it's mounted to is bent. Does the right-hand blade hit the inside of the deck along the front?
What I'd do, if you want to fix it, is take the gauge wheel out of the slot, insert a long pry bar, and lever the front edge back out the half inch it's bent inwards. Then weld the crack at the front lift mount.
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
45 Loader
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
KHodges is offline
post #4 of 16 Old 04-22-2019, 12:51 PM Thread Starter
demonspeed's Avatar
No, the blade doesn’t hit anything (at least it didn’t the 10 seconds I had the PTO engaged before the tensioner spring & bracket went). Good idea on the bar at the wheel bracket. I was thinking of a way more elaborate way of doing it so as not to tweak other parts of the deck, but that route may work best.
post #5 of 16 Old 04-22-2019, 01:09 PM
What I use is a 4x6 chunk of pt wood and a floor jack and the 2" receiver hitch under my full size van. Probably had another section of 4x6 on top of the deck. I sandwich the exit area of the deck between the 4x6 wood with the jack underneath the lower 4x6. Then jack it all up but not enough for the van tires to clear the ground. What I am trying to do is fix the deck in place under the back of the van so I can lever on that bent front face. I don't want to bend the horizontal upper exit chute section of the deck. I only want to bend the front face.
If you don't somehow fix the deck in place then when you start levering on the front face you will probably just bend the top of the deck upward.
rayjay is online now
post #6 of 16 Old 04-22-2019, 01:09 PM
Straighten the deck before welding.
post #7 of 16 Old 04-22-2019, 01:18 PM
Merc1973's Avatar
How about rigging a hydraulic bottle jack and some wood blocking to push the front lip forward a bit? That's what I would do...
1981 400- Vanguard 23 HP, 54C deck, 56 blade, 50 snow blower
SOLD-2003 G100- 54", Kohler Command 25, Gator G5 blades
JD 46" snow Blade
Stihl 031AV (WIMA cap, base gasket delete) 20"
Echo CS-590 (MM) 20"
Husqvarna 128LD Trimmer
Giant Vac w/ 6.5HP Predator Engine
Unknown 1980's Japanese backpack Blower with Kawasaki engine
1968 M35A2
Merc1973 is offline
post #8 of 16 Old 04-22-2019, 01:26 PM Thread Starter
demonspeed's Avatar
That’s sort of what I was envisioning. I didn’t want to make anything worse by just having at it. Is that chute exit area on top supposed to be flat, or is that slant normal?
That is the other idea I had. That way I could keep the pressure evenly spread -- I just dont want to push the rear lip out rather than the front!
post #9 of 16 Old 04-22-2019, 02:03 PM
inspectorudy's Avatar
I've had several decks like yours and I just used a big rubber mallet with the deck lying upside down on the lawn. Take aim at the lower part of the bent section and give it a really hard whack. The tin is not that strong and it will move pretty easily. If you overdo it a simple whack on the outside will do the trick. Almost every deck that I have had, and it has to be over twenty, has had a crack around one of the wheel supports or more. Straighten out the chute side and the get it welded. This ain't rocket science. As long as the spindle is not bent and the blade is not touching it's fine.
inspectorudy is offline
post #10 of 16 Old 04-22-2019, 02:10 PM
You'll be shocked at how easily you can bend it back in place (and how easily it can get bent again!). I'd agree with the rubber mallet approach.
So long as your metal isn't too thin (rusted away), it should be an easy weld job.
CantKeepUp is offline
post #11 of 16 Old 04-22-2019, 02:26 PM Thread Starter
demonspeed's Avatar
Thanks guys. Deck repair is new to me. I can take anything apart and put it back together, but I am paranoid with “body” work.
post #12 of 16 Old 04-22-2019, 03:38 PM
Get some of the neighborhood fatties to jump up and down on the top where its bent. Problem solved for the cost of some food.
John Deere X580, 48" deck, rear lighting and electrical distribution
JD Power integral sleeve hitch, 48" JD blade, 30" JD tiller
oldgibsonguy is offline
post #13 of 16 Old 04-22-2019, 05:04 PM Thread Starter
demonspeed's Avatar
I don’t know where you shop for groceries, but I think it may be cheaper to pay a professional, lol
post #14 of 16 Old 04-23-2019, 02:41 PM Thread Starter
demonspeed's Avatar
Before I go wailing on this, can we confirm if the circled area is to be flat or if that is how it is supposed to be? If anyone has a picture of their good 48C deck of the chute side, it would help immensely.
post #15 of 16 Old 04-23-2019, 04:36 PM
Blank Space
I bent my Craftsman deck a while back (long story).. Took it off, flipped it over on the grass and was able to get a large pipe wrench over the bent lip. The leverage of the long wrench handle was enough to bend ... err. 'reform' it to working again.
Obscured_by_Clouds is offline
JD455 54" mower deck rebuild thoughts itsagaas John Deere Forum 9 09-18-2018 08:23 PM
48c deck Chute ?? yzf125 John Deere Forum 15 09-18-2018 08:57 AM
Noisy, Rusty Deere 48C deck Cannon51 John Deere Forum 5 05-11-2018 08:42 AM
48" deck in bad shape hankll Bolens Forum 8 12-02-2012 11:10 AM
