cheaper cost washer - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 22 Old 04-20-2019, 09:31 AM Thread Starter
Question cheaper cost washer
I am looking at item 23 in this diagram: https://partscatalog.deere.com/jdrc/.../pgId/20572627
Do you happen to know where I could find a non-Deere replacement for this washer? Or is the reason it seems to be expensive (to me, anyway) is because only Deere makes this specific size?
thanks
iowguy is offline
post #2 of 22 Old 04-20-2019, 09:46 AM
Re: cheaper cost washer
This not your typical flat washer, it is cupped by .059" to help keep the bolt tight witout using a lock washer.
Zebra5 is online now
post #3 of 22 Old 04-20-2019, 09:49 AM
Here's what is available on eBay,
https://www.ebay.com/sch/i.html?_fro...e+blade+washer
If you measure the one you have, you may find something on McMaster Carr.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #4 of 22 Old 04-20-2019, 10:13 AM
CCMoe
Measurements are:
A .641"
B 2.5"
C .250"
D .309"
See drawing in post #2
post #5 of 22 Old 04-20-2019, 11:24 AM Thread Starter
CCMoe
That's part of the issue. I think the repair shop put the wrong washers back on my deck so I can't rely on the measurements.
Thanks for the measurements Zebra5.
iowguy is offline
post #6 of 22 Old 04-20-2019, 12:08 PM
iowaguy,
I did a quick look at McMaster Carr, nothing came up with OD 2.5" with .641 ID.
I would buy up the eBay ones, might save you $10.00 per washer.
CCMoe
P.S. Find another repair shop.
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #7 of 22 Old 04-20-2019, 12:22 PM
MARK (LI)'s Avatar
It looks like my dealer has it for $1.61...that is chief in Hicksville New York...see if you want it....if you do let me know...I will get it an mail it to you..probably a dollar or so to send by regular mail
MARK (LI) is offline
post #8 of 22 Old 04-20-2019, 12:35 PM
Mark,
If you can get it for $1.61 from your dealer, buy them (M123522) all and put them on eBay for $10.00 a piece.
I think he also needs three of them, maybe not but if he does this would be a great help to him.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #9 of 22 Old 04-20-2019, 12:42 PM
Another place one can try would be Fastenal.
Flaken is online now
post #10 of 22 Old 04-20-2019, 01:59 PM
They're called "Belleville Washers". BE careful when buying though. OD (B) and material thickness (C) make a difference!
Hmm, just checked my dealer, 1 in stock at $12.01 each! Bob
rwmeyer is offline
post #11 of 22 Old 04-20-2019, 06:52 PM
oldgibsonguy's Avatar
This right here from rwmeyer!!
And although the dimensions of another washer may be the same, the properties will not. Bellville washers are designed to specifically provide equal force to a large area, hence the cup, and are often a much harder steel than "just another washer". If you want to have a blade that wobbles and maybe takes out a spindle before the end of the summer, then go cheap. If not spend the money and buy the OEM washer.
John Deere X738 4wd
48" mower deck
oldgibsonguy is offline
post #12 of 22 Old 04-20-2019, 07:00 PM
I don't think it's actually a Belville spring. I think it's just a rigid cupped washer intended to make sure the contact point is out a bit from the center shank of the spindle.
As for the price, it's less than $40 to repair the mower deck and they should last forever if somewhat maintained [ i.e. not left out in the weather 24/7 and the blades removed every so often for sharpening ].
rayjay is online now
post #13 of 22 Old 04-21-2019, 09:54 AM
Cannon51's Avatar
I'm as cheap as anybody but blade fastening hardware is not where I would try to save money. I agree that the price is to high.
Cannon
Cannon51 is offline
post #14 of 22 Old 04-21-2019, 06:19 PM
iowaguy,
If you would, let us know which direction you take, it let's us know our efforts are worthwhile.
Thanks,
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #15 of 22 Old 04-22-2019, 11:14 AM
Mark,
CCMoe
I'll bet he miss read the price and the dealer really wants $11.61 each.
Generac pressure washer runs high rpm PaulM12 Pressure Washers 16 01-13-2019 12:47 PM
Did I really just buy an old pressure washer with a suspect pump? Austen Pressure Washers 14 11-12-2018 06:40 PM
Pressure Washer Carb Probelms bmurph44 Small Engines and Repair 3 07-02-2018 05:03 PM
Washer direction suzukizone John Deere Forum 1 06-22-2018 12:54 AM
Dealer cost -2012 X748 whbob John Deere Forum 25 02-09-2013 01:12 PM
