Brinly 3point plow. PP-1200 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 19 Old 04-19-2019, 07:41 PM Thread Starter
rcguyfarms's Avatar
I was final able to find one locally and got a great deal on it. Plus sides it’s painted Deere green and came with a 14” plow instead of the 12”. Once my garden dries out again I will take action shots.
2011 Z645
1979 400 w/ 20 loader
1979 35 tiller
1965 110 round fender
rcguyfarms is online now
post #2 of 19 Old 04-19-2019, 08:02 PM
Re: Brinly 3point plow. PP-1200
Great find, I don't know much about the plow but why is the side bar longer on 1 side then the other, the side bars that connect to the cross bar.
stanley55 is offline
post #3 of 19 Old 04-19-2019, 10:18 PM
L120/G110 Hybridizer
ryanpf's Avatar
Because the plow is supposed to be mounted canted about 17 degrees to the left. That way, when the right tractor wheel is in the previous plowed furrow, the plow will be riding straight up. The easiest way to do this for BH was to mount the pins at different levels.
Paul
Massey GC1710 - A little red diesel with a loader in front, a backhoe in the rear and a big smile in the middle -
John Deere L120/K66 with Berco 30" tiller, John Deere 44" Snowblower, Johnny Products Sleeve Hitch and
JB Jr bucket. Plus Brinly-Hardy 10" plow, 7-Tine Cultivator, 40" Plug Aerator, 40" Dethatcher, E-I-E-I-O...
ryanpf is offline
post #4 of 19 Old 04-19-2019, 10:27 PM
That should also give a little more ground clearance when out of the ground also. I tilted the mounting bracket on mine but like the looks of that design better.
Ariens93GT20 is offline
post #5 of 19 Old 04-20-2019, 11:04 AM Thread Starter
rcguyfarms's Avatar
The managed to hook up the plow to rf 110h in between rain today
2011 Z645
1979 35 tiller
post #6 of 19 Old 04-20-2019, 11:29 AM
THAT is a very large blade. I pity the poor ground.
John Deere X580, 48" deck, rear lighting and electrical distribution
JD Power integral sleeve hitch, 48" JD blade, 30" JD tiller
oldgibsonguy is offline
post #7 of 19 Old 04-20-2019, 09:10 PM
ryanpf and Ariens93GT20, Thanks for the information, I just got a plow and made myself a sleeve hitch, I have no experience on the plow so that will help, my hitch is almost done just need to weld it and to set it up for the plow.
post #8 of 19 Old 04-20-2019, 09:20 PM
oaks1450's Avatar
Very nice! I like how you have a three point hitch set up on the RF. Hydraulic too boot! I am working on getting my plow hooked up to my RF in the next couple of weeks. Looking forward to seeing yours in action.
1964 110
1964 110 w/Johnson 10 loader
1987 318
1991 420 w/ 44 Loader
2007 X300 w/bagger
oaks1450 is online now
post #9 of 19 Old 04-20-2019, 10:16 PM
ryanpf's Avatar
That's impressive compared to my BH 10" plow. Should work great for you.
Paul
ryanpf is offline
post #10 of 19 Old 04-21-2019, 03:07 PM
AKA Moses Lawnagan
KHodges's Avatar
Nice plow. I'd recommend adding a brace from the top bolt above the share to the hole beneath where the top link goes. I converted a 10" Simplicity plow, which has the same doubled curved bar yours has, to a 3 point hitch that looks somewhat similar to yours. If you snag the plow tip on a root or large buried rock, the curved bar may bend. Don't ask how I know (see picture)
Luckily, I found a second plow, and then added a brace. No more issues. Now I have an extra share, looking to make a double bottom for the X748 some day.
Name:	bent plow 4-8-10.jpg
ID:	2373139   Click image for larger version
Name:	completed plow 2.jpg
ID:	2373141   Click image for larger version
Name:	brinley plow_LI.jpg
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
45 Loader
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
KHodges is offline
post #11 of 19 Old 04-21-2019, 08:58 PM
Can someone tell me what size are the lift arm pins for a cat 1, I thought they were 7/8 but a buddy of mine says 3/4.
post #12 of 19 Old 04-21-2019, 11:27 PM
Cat1 is 3/4
'92 332
With 455 spring seat suspension
Left-sided brake swap with right-sided foot control
3PH, rear PTO
Kwikway loader, earthcavator, 42" hydro tiller, 50" belly mower, 50" rear grooming mower, 48" Haban 402d sickle, and 54" 4 way plow.
Kris OK is offline
post #13 of 19 Old 04-22-2019, 08:21 AM
Originally Posted by Kris OK View Post
Cat1 is 3/4
Thanks, But after searching on google it seems to be 7/8, I'm talking about pins for a cat 1, but would the pins for a limited cat 1 garden tractor be the same as the cat 1 sub compact tractor be?
post #14 of 19 Old 04-22-2019, 10:56 AM
AKA Moses Lawnagan
KHodges's Avatar
Cat 1 pins are 7/8" diameter, and 3" long, more or less. The "limited" doesn't matter, that has to do with weight limits and lift height. It will be interesting to see how well the 110 can pull that large share with it buried, looking forward to some action shots. I wish I still had my RF110, it was my first JD and I didn't know much about them then. Did yours come with hydraulics?
Proud owner of :
?? 60" box blade
45 Loader
KHodges is offline
post #15 of 19 Old 04-22-2019, 12:09 PM
Looks like cat1 is a 3/4 top link and 7/8 lower links. I never knew they were different sized. That’s info straight from HeavyHitch’s site.
'92 332
3PH, rear PTO
Kris OK is offline
Brinly Plow and Intregal Sleeve Hitch oaks1450 John Deere Forum 10 05-17-2019 01:42 PM
Brinly 3 point plow on JD tractor royalton10 John Deere Forum 5 12-08-2017 11:36 AM
Brinly plow question farmerall Lawn and Garden Tractor Accessories 7 03-05-2013 03:16 PM
Brinly PP 1200 Plow ? michael11 What Is It Worth ? 3 02-18-2013 07:56 AM
