X540 doesn’t stop - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 04-19-2019, 09:42 AM Thread Starter
Shacker
papashelby's Avatar
X540 doesn’t stop
Out visiting my SIL and he has an X540, 2010, 650 hours. After taking it for a ride, I notice it rolls to a stop, both forward and reverse. Not the instant stop like my 345 and X728. Is there an adjustment or something else going on? All fluids were changed less than 10 hours ago.
2012 X728
48C deck
MC519 collection system
3 point hitch
47" blower and suitcase weights
54" blade
Curtis ROPS soft side cab
Front bumper and fenders
Front mounted thatcher
45 Loader
1997 345
48" deck
snow thrower
2 bag bagger
1984 420 with 50" deck - sold
1968 112 all original, from my dad, with:
deck, snow thrower, white patio blade, cab, 1966 #80 cart with vac system, all shop manuals
papashelby is offline
post #2 of 10 Old 04-19-2019, 09:58 AM
rudedawg's Avatar
Re: X540 doesn’t stop
Not being familiar with JD but does it have a pedal dampener kinda like a mini gas strut that returns the pedals to the neutral position? My Cub had one that broke on one end that connects to the pedal lever only allowing it to coast to a stop unless the rev. pedal was lightly feathered. Good luck.
rudedawg is offline
post #3 of 10 Old 04-19-2019, 11:36 AM Thread Starter
Shacker
papashelby's Avatar
I think you are correct. Upon further investigation, I see exactly what you’re talking about. Looks to be an easy fix. Thank you.
2012 X728
48C deck
3 point hitch
54" blade
45 Loader
1997 345
48" deck
snow thrower
2 bag bagger
post #4 of 10 Old 04-19-2019, 12:03 PM
rudedawg's Avatar
Yvw.
rudedawg is offline
post #5 of 10 Old 04-19-2019, 12:24 PM
Before you drop the $100+ on replacing that damper, its function, at least on my GX345 and the other tractors I have looked into, is to slow the return of the pedals to the neutral position to prevent the tractor from jerking to a stop.
I suggest disconnecting the damper to see if it resolves the issue before replacing it as they are not cheap.
denverguy is online now
post #6 of 10 Old 04-19-2019, 01:46 PM
jgayman's Avatar
I have a X500 which I purchased new and it acts the very same way. My previous tractor was a 175 Hydro and when you would move the hydro control it would stop instantly. In fact, it would even slide the tires if you moved the lever too quickly. I never ever needed to use the brake pedal or parking brake on the 175 because unless you pushed in the bypass lever it would not move. The X500 on the other hand rolls to a stop more gently and will in fact roll away on a hill if you don't set the parking brake.
jgayman is offline
post #7 of 10 Old 04-19-2019, 03:49 PM Thread Starter
Shacker
papashelby's Avatar
Good point. And yeah, $100 is correct. I will disconnect and see what happens.
Both of my tractors would do this if I’m not gentle with the pedals.
2012 X728
48C deck
3 point hitch
54" blade
45 Loader
1997 345
48" deck
snow thrower
2 bag bagger
post #8 of 10 Old 04-20-2019, 07:41 AM
m_boone's Avatar
There is a section in the tech manual called "Transaxle Neutral Adjustment" that says to lift rear wheels and turn "eccentric nut forwards and backwards until the wheels stop turning." I'm not as knowledgeable as the other posters on this thread but I thought it might help in some way.
____________
2003 X485, 54C, 54" front plow, 17P cart, Agri-Fab 42" smart sweep, 14 Bushel Power Flow bagger
m_boone is offline
post #9 of 10 Old 04-20-2019, 08:00 AM
JD-285's Avatar
Yes, take dampener off and test unit.
285 "Wife's"
285 "The Ames"
165 "The 165" (Upgrade to FC420V from 170)
111H "Baby B."
445 “Braille”
X500
JD-285 is offline
post #10 of 10 Old 04-20-2019, 08:26 AM
The "Transaxle Neutral Adjustment" will not help you with this. It only needs adjusted if you have fwd or rev creep while in neutral (although the root cause for that creep is usually worn bushings).
CantKeepUp is offline
Snowblower-attachment for x300 -series fit x540 ?? bamsefar1 John Deere Forum 19 10-29-2018 11:20 AM
Blades spin on startup, but eventually stop... Anyone one what is going on? johndeerefan16 MTD 1 06-13-2018 11:13 PM
Releasing Hydro Pedal does not always stop tractor instantly Joelk Cub Cadet Forum 7 03-29-2018 12:07 AM
Depth stop spring popping off aucivil John Deere Forum 14 03-20-2018 06:17 PM
3000 Series Deck Stop On A 60" Deck Lonstar Cub Cadet Forum 12 01-22-2013 08:35 PM
