316 electromagnetic clutch - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 04-15-2019, 03:35 PM Thread Starter
Jd316
MrDooder's Avatar
Needing help on my 316, front pto clutch isn’t engaging. It was working before I swapped the motor out, took it apart and cleaned all the oil out of it and reassembled. Now with the clutch plugged in I get no light and the motor dies but when I unplug the clutch the pto light comes on. The field coil passes all of the tests in the service manual.
MrDooder is offline
post #2 of 3 Old 04-15-2019, 04:47 PM
Kish JD 318/420/430
RussKish's Avatar
Re: 316 electromagnetic clutch
Seat switch and the PTO switch have to work including the wiring. Check those, check all grounds since you swapped motors, and check the TDCM plugs for dirt/corrosion.
Russ
Proud Owner of: 318/420/430
RussKish is online now
post #3 of 3 Old 04-21-2019, 02:36 PM Thread Starter
Jd316
MrDooder's Avatar
ended up just being a crushed wire behind the clutch! boy did i feel dumb, been messing with this thing for 3 or 4 months now! a little bit of heat shrink and electrical tape and she works like new! now to get the blades sharpened and the deck mounted!
MrDooder is offline
Unable to adjust front PTO clutch on 322 Teen with 318 John Deere Forum 25 03-27-2019 06:58 AM
53 NAA clutch and starter stuck jsdesign Ford N's 9N/2N/8N 4 05-14-2018 07:46 PM
More Ford 3000 Dual Clutch adjusting questions dustiebutt Ford/New Holland Tractors 0 11-24-2017 12:28 PM
Lawn Tractor, 90's - 2000 Vintage, Blade Clutch Problems andyjw Backyard Round Table - L & G Tractor Related Topics 0 03-05-2013 06:54 AM
Rider PTO Clutch Disassembly yamato72 Gravely FAQ and Stickies Section 12 10-07-2012 09:06 AM
