John Deere X728 Filters? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 04-10-2019, 11:53 AM Thread Starter
Hello all,
Do any of you use WIX filters on your x728. I cross referenced the hydraulic filter to WIX 51394, but am struggling to find the engine filter. Can anybody help me out?
Thanks!
kz5rt2 is offline
post #2 of 7 Old 04-12-2019, 10:24 PM
Re: John Deere X728 Filters?
I don't have a x728 but I have a 955 which has a hydrostat. I would be careful about using a Wix hydrostat filter. I did that because it was 1/2 the price and the numbers X refd. Shortly after changing it I started having problems, like very slow hydraulics, slower on the road and it seemed like there was more pump noise. Changed the filter back to a JD and no change. All kinds of thoughts went my mind busy. Long story short, I put a gauge on the scavenger pump out put and found that at low rpm pressure was ok but the higher rpm the pressure dropped off. So, checked the pick up screen and found most of the wix filter plugging my pick up. Cleaned it out and problem solved. Do as you please but for me, never cheap out on a filter.
greenjohn is offline
post #3 of 7 Old 04-15-2019, 07:39 AM Thread Starter
Thank you for the valuable advice. I will be sticking with JD!
Thanks Again...
kz5rt2 is offline
post #4 of 7 Old 05-14-2019, 06:25 AM
Wix filters are some of these best filters made. I have been using them across all applications for decades. There is no reason to stay with stock filters. I have wix oil, fuel, and hydraulic filters on my 2025. No problems.
Go to Wix website to find the proper filter for your application.
crna is offline
post #5 of 7 Old 05-14-2019, 09:52 AM
Here was a filter change I did last year.
crna is offline
post #6 of 7 Old 05-15-2019, 12:00 AM
UnRetired Mod
Michael's Avatar
I moved this thread to the proper forum for better exposure and I used Wix, NAPA Gold (made by Wix) and John Deere filters intermixing the filters whenever I got a good price on whoever gave the best price
https://jdparts.deere.com/partsmkt/d...awnTractor.pdf
Oil Filter JD. AM107423 Wix 51394, or 51394XP
Fuel Filter AM117584
Air Filter Paper M152049
Air Filter Foam M148207
Trans Filter AM131841 Wix 57103
My John Deere Collection
2009 John Deere 2305 with Front End Loader, Backhoe and 62C Mower
2017 John Deere X590 with 54" Accel Deep Mower
Michael is offline
post #7 of 7 Old 05-15-2019, 02:15 AM
mrbeef's Avatar
Both WIX and Deere offer good filters. Depending on the source for your Wix filters double check the price at Deere. Recently the two local auto parts stores have been running 15-25% higher on filters than Deere. This time of year some dealers run specials on filters/blades/etc.
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
John Deere Kohler K241, K301, K321 stator, points, condenser, gaskets (CT) bmwpowere36m3 For Sale & Wanted to Buy (Your Location) 0 02-09-2019 01:30 PM
1979 John Deere 317 ... Southwest Wisconsin GreenGabby For Sale & Wanted to Buy (Your Location) 1 02-09-2019 12:52 AM
John Deere 14SB questions bwdbrn1 Walk Behind Mowers 36 10-03-2018 09:08 PM
What do you own? A Running list... simple_john Backyard Round Table - L & G Tractor Related Topics 232 02-21-2018 11:49 PM
John Deere 4720 PTO Problem billboyce2 The CUT Hut: General discussions of Compact Tractors 8 12-26-2017 04:05 AM
