JD 430 with 48-inch tiller working poorly - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 2 Old 04-05-2019, 12:50 AM Thread Starter
RedDogJeff's Avatar
Had my JD 318 set up with rear PTO and 48-inch shaft drive tiller. Rear PTO, clutch, and tiller worked super, lots of power but tiller was too big for the 318. Moved the clutch, rear PTO, and tiller to my JD 430 and now the tiller seems to spin at about 2/3 the speed as when on the JD 318. The JD 430 runs strong, but the tiller runs weak. Any ideas why or suggestions?
RedDogJeff is offline
post #2 of 2 Old 04-08-2019, 08:12 AM
Wfburton159's Avatar
Re: JD 430 with 48-inch tiller working poorly
Likely the RPM on the 430 is less than the 318 was and that is why you are noticing a difference. Lower engine RPM will result in lower rear PTO RPM.
2003 John Deere X485
647 tiller
54c deck w/ mulch kit and power flow bagger
75# wheel weights and chains
John Deere 14SB
Wfburton159 is offline
John dere 48 inch 2000 rpm tiller warburtonplayer Lawn and Garden Tractor Accessories 2 09-19-2018 05:54 AM
Wanted: John Deere 430 Lawn & Garden Tractor 3-Point Hitch and Rotary Tiller (AL) Tide For Sale & Wanted to Buy (Your Location) 1 04-30-2018 08:18 PM
30 inch Mechanical Tiller and GT242 MattTheSharp John Deere Forum 2 04-29-2018 09:37 PM
Modifying a 42 hydraulic tiller? mithesaint John Deere Forum 4 02-12-2018 06:18 AM
430 vs 30" hydraulic tiller doug430 John Deere Forum 16 11-04-2017 04:06 PM
