Kevlar belt for the 445's 60" deck AND High Lift Blades - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 04-01-2019, 07:38 PM Thread Starter
mowergene's Avatar
Look what I found that Uncle John won't provide!
REPLACEMENT for JOHN DEERE M120381 DOUBLE "V" 60" DECK BELT made with KEVLAR
Item price $42.75
AND
Stens 330-357 3PK Hi-Lift Blade/John Deere M141785 Compact Tractor 60"Mower Deck
Item price $91.10
Quantity 2 (that's six blades!)
Kevlar belts last just about forever and High Lift Blades clean up the leaves and mow wonderfully!
I must admit that the "standard" blade for the 60" deck does a darn nice job throwing out the grass, but, I know there will be an improvement with the High Lift blades.
In the past:
In use:
mowergene is offline
post #2 of 13 Old 04-03-2019, 03:49 PM Thread Starter
mowergene's Avatar
Re: Kevlar belt for the 445's 60" deck AND High Lift Blades
That new belt was tough to get on....but I made it. I checked the angle on the blades and found them to be the same as the standard JD blade. Difference? The price! Of the six blades, I ended up balancing three of them. They weren't far off, but still off. Same heavy blade as the JD, though, so I'm happy.
In the past:
In use:
post #3 of 13 Old 04-03-2019, 04:09 PM
I just bought a used Z655 JD and was looking to see where the best place was to get parts and I found Amazon has some good prices. Also found the Kevlar belt there for about 1/2 the price of a JD's.
9297oldram is offline
post #4 of 13 Old 04-03-2019, 04:24 PM Thread Starter
mowergene's Avatar
JD has good parts, but not always the best but you can bet their price will be darned high. I go between Amazon, Walmart and simply googling. Any belts I buy must be Kevlar.
In the past:
In use:
post #5 of 13 Old 04-04-2019, 02:42 PM
Gene, Keep a close eye on your belt adjustment. Although the ad states it's a JD replacement, it's probably not. JD uses a 32º included angle on the belts and a standard V-belt is 40º. It'll work, but it will ride high on your pulleys until it eventually conforms to the different groove angle. As it conforms, it will run lower & lower in the groove and require frequent adjustment in the beginning.
Good find though and everyone wants to save $$$, Bob
rwmeyer is online now
post #6 of 13 Old 04-04-2019, 02:59 PM Thread Starter
mowergene's Avatar
Bob, On the cardboard package it say: A-M120381 Kevlar John Deere 5/8" X 124" and it's a double V.
It's a little tighter than the OEM I took off and it's quieter. I'm believing it is the right one.
The "high lift" blades actually have the same angle as the JD standard blade. However, the actual cutting edge goes considerably further than the OEM.
My guess is that A&I products may make the belts for JD. The blades are Stens and work fine.
In the past:
In use:
post #7 of 13 Old 04-04-2019, 03:39 PM
Gene, On the JD parts page, the A-M120381 is listed as an actual "Alternate Part"...for $55.19! As I said, good find! Bob
post #8 of 13 Old 04-04-2019, 04:33 PM
Wfburton159's Avatar
Why was it tough to put on? Did you loosen the bump stop and adjust that? Shouldn't be tough to install unless it is really too short.
2003 John Deere X485
647 tiller
54c deck w/ mulch kit and power flow bagger
75# wheel weights and chains
John Deere 14SB
Wfburton159 is offline
post #9 of 13 Old 04-04-2019, 04:47 PM
Blank Space
Originally Posted by mowergene View Post
Kevlar belts last just about forever.
I've got a collection of snapped and 'slicked' (don't go no mo') ones that say otherwise.
post #10 of 13 Old 04-04-2019, 07:44 PM
kershner's Avatar
Send a message via Skype™ to kershner
Awesome info. Thank you.
Cub Cadet Pullers, JD318, JD425, Oliver 1800, Stihl 361C, Vintage 041 Farm Boss.
kershner is offline
post #11 of 13 Old 04-04-2019, 07:44 PM Thread Starter
mowergene's Avatar
It was tight getting it between an idler pulley and two beltkeepers. At that point I was worn out wrestling with the 300 pound deck!
In the past:
In use:
post #12 of 13 Old 04-04-2019, 07:47 PM Thread Starter
mowergene's Avatar
It's true that some machines are hard on belts. I've known guys who had cars (before serpentines) that would go through fan belts. I suppose their pulleys were out of alignment or had rough edges.
In the past:
In use:
post #13 of 13 Old 04-10-2019, 02:23 PM
Yes I forgot about those little posts. They are tough.
647 tiller
John Deere 14SB
Gator Blades. Are they hard on deck parts? TEXUN Backyard Round Table - L & G Tractor Related Topics 15 04-04-2019 07:59 PM
JD High Lift blades part # ? yzf125 John Deere Forum 4 09-29-2018 12:14 PM
Love My 44M Piranha Deck PChem John Deere Forum 5 06-12-2018 01:00 PM
Gator blades on 42” deck - work great C2H8O Bolens Forum 2 11-12-2017 05:03 PM
Suburban scissor deck won't lift high enough hartkem Craftsman/Sears Forum 5 02-22-2013 09:28 AM
