john deere 111carb floods - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 02-14-2019, 12:30 PM Thread Starter
it runs fine when it runs but when i shut it off the gas drains down into the crankcase. it just started doing this last fall.
green dream machine is offline
post #2 of 10 Old 02-14-2019, 01:50 PM
surfed2death's Avatar
Re: john deere 111carb floods
sounds like its time for a carb kit.
1978 John Deere 316
1980 John Deere 317 (Series 1)
1985 John Deere 116 Hydro-static
1992 John Deere LT150 5-Speed
surfed2death is offline
post #3 of 10 Old 02-14-2019, 02:10 PM
Carb Floats aren't adjusted right - or they are sticking - or the float needle isn't seating against the seat.
CantKeepUp is offline
post #4 of 10 Old 02-14-2019, 05:18 PM
What era 111? Gravity fed fuel tank under the hood or is tank under the seat and uses a pump?
JDDottie is offline
post #5 of 10 Old 03-27-2019, 01:33 PM Thread Starter
gravity fed under the hood. i already put a shutoff valve but i have to be quick and it still drains the carb into the crankcase.
post #6 of 10 Old 03-27-2019, 05:40 PM
Understand - don't want gas in the engine's crankcase oil.
I/we have redone the carburetor in our 1980 JD 111 3-4 times. Gave up.
Installed a shut off valve on the fuel line between the gravity fed fuel tank & carb.
Done with work - turn off fuel flow & let engine run at idle 'till the carb's outta gas
& the engine stops running. Then remember to turn start key to off.
Next time, remember to turn on the fuel flow when wanting to restart the engine.
Been working just fine this way for us for over 17 yrs. now.
JDDottie is offline
post #7 of 10 Old 03-28-2019, 12:06 AM Thread Starter
that sounds easier than putting in a new needle and seat. that and i am not sure of the 13.00 carb from e bay.
post #8 of 10 Old 04-24-2019, 12:02 PM Thread Starter
fixed it. i took the carb off and it was full of rust and crud. sonic cleaned it and put it back together and no more flooding for now.
post #9 of 10 Old 04-24-2019, 04:23 PM
"for now" -- read/review a prior post. Is yours, so do as you wish.
JDDottie is offline
post #10 of 10 Old 04-25-2019, 12:28 PM
240vtx's Avatar
I just purchased one of these carbs and it works great. The original carb was cleaned and rebuilt but never worked. The China carb did the job.
240vtx is offline
John Deere Kohler K241, K301, K321 stator, points, condenser, gaskets (CT) bmwpowere36m3 For Sale & Wanted to Buy (Your Location) 0 02-09-2019 01:30 PM
1979 John Deere 317 ... Southwest Wisconsin GreenGabby For Sale & Wanted to Buy (Your Location) 1 02-09-2019 12:52 AM
John Deere 14SB questions bwdbrn1 Walk Behind Mowers 36 10-03-2018 09:08 PM
What do you own? A Running list... simple_john Backyard Round Table - L & G Tractor Related Topics 232 02-21-2018 11:49 PM
ever wonder what the MSRP of your john deere model when it was new ? jimbo316 John Deere Forum 12 12-10-2017 05:54 PM
