Weight for 317 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 02-11-2019, 08:24 PM Thread Starter
Ed Galicic's Avatar
Weight for 317
A few years back, I posted about my neighbor who had problems plowing his steep concrete driveway with his 317. Overall consensus was that he needed more weight in the rear, more than the cast iron wheel weights he already had. Well, since there is not a built-in weight bracket on the tractor, we looked at a weight bracket designed specifically for the 317 offered by someone on eBay. I think it was $150 plus $30 shipping. Then he was considering 4 suitcase weights for the rear. Total investment = $447 after taxes for 168 pounds of weight. I told him before he pulled the trigger on the expensive setup, we should just try to make our own. I told him that I thought I could design a weight out of concrete, with a sleeve hitch for under $30. A savings of $420 solely to be used on beer! The weight would be easily removed and stored come grass cutting season. I had some scrap 2” square tube, some unistrut, some angle, and a crappy welder. All we would need to buy is is a sleeve hitch, some concrete, some rebar. I welded all the pieces together to create a rigid frame within the concrete, formed a box around the 2” square tubing. Leaving the top open for the “handles”. All went well. Used two 80 pound bags of concrete to make a block 13.5” x 13” x 13”. It weighs in at 183 lbs and I even painted it JD green from left over paint I had from a set of cornhole boards I made. Total cost = $28. Here’s the set up.....
ID:	2361377   Click image for larger version
ID:	2361379   Click image for larger version
ID:	2361381   Click image for larger version
ID:	2361387   Click image for larger version
ID:	2361389   Click image for larger version
ID:	2361391   Click image for larger version
Ed Galicic is offline
post #2 of 10 Old 02-11-2019, 09:32 PM
Cat385B's Avatar
Re: Weight for 317
Crack another beer, you deserve it. Well done.
Cat385B is online now
post #3 of 10 Old 02-11-2019, 09:36 PM
Re: Weight for 317
That is really clever and well made.
Tractor Beam is online now
post #4 of 10 Old 02-11-2019, 09:37 PM
Tracs's Avatar
Re: Weight for 317
Any pics/info on how the sleeve hitch mounts to the tractor?
Tracs is offline
post #5 of 10 Old 02-11-2019, 09:39 PM Thread Starter
Ed Galicic's Avatar
I just took off the hitch plate that was already on there and reused the 5/8 carriage bolts. Here is a pic of it on the machine. Don’t mind my crappy weld job. I am in the market for a stick welder and then I will modify the harbor freight flux core to DCEN for better penetration.
That is 3/16 angle. I really wanted to use 3/8 plate and make a setup like the second picture, but that would have added to the cost. The whole point was to do it under $30, just to say I did it. If the hitch (welds) ever fails, I’ll just make a new one with thicker stock.
ID:	2361415   Click image for larger version
post #6 of 10 Old 02-11-2019, 09:54 PM
Tracs's Avatar
Re: Weight for 317
Very nice. The frame has no problem holding the weight?
Tracs is offline
post #7 of 10 Old 02-11-2019, 10:01 PM Thread Starter
Ed Galicic's Avatar
No, not at all. We tested it before I poured the concrete. It was able to hold me bouncing on the end of the 2” tube and there was no flex in the frame at all.
post #8 of 10 Old 02-11-2019, 10:10 PM Thread Starter
Ed Galicic's Avatar
The only thing I would have done differently is to have the weight a little closer to the frame. But then if you get it too close, then you might have clearance issues with your arms trying to insert the hitch pin.
post #9 of 10 Old 02-12-2019, 07:25 AM
Re: Weight for 317
Sweet setup. He got a receiver out of the deal too...nice to be able to mount a carryall for a lot of jobs the rest of the year.
Soon to be former:
JD x300 42"
Former:
JD F910 60" deck
Ford 1910 4WD Loader Backhoe
Jacobsen GT14
cnymowinplowinsailin is online now
post #10 of 10 Old 02-12-2019, 09:20 AM
Rebuilding my First JD GT
N2 Tractors's Avatar
Re: Weight for 317
Running:
‘73 140 H1, ‘75 214, ‘79 JD 317 Onan P218G, 19xx Wheel Horse D250 550 Arc FEL ARPS Box blade
Not Running:
‘69 JD 140 H3, ‘75 JD 300, ‘79 JD 317 Kohler KT17QS II, ‘83 JD 420, late ‘80’s JD 316, ‘90 JD 316,
2x 300 series 3PH, Johnson Workhorse 12, Gannon Earthcavator 32”, 2x JD 54” 4way blade, 2x JD 33 Tiller + 8" Extension, JD 38” Brass tag mower deck, JD 48” mower deck, JD #30 Hydro Tiller, Disks, Plow, ARPS Angling Backblade,
N2 Tractors is offline
weight capacity question - rear weight box rfuerst317 John Deere Forum 6 08-25-2018 05:05 AM
New owner of a 425. Weight question Cubcadetmax John Deere Forum 10 06-11-2018 12:24 PM
Ballast Weight FordTractors John Deere SCUT 6 02-19-2018 11:53 PM
Wheel Weight Adapter write-up coolwind57 Case_Ingersoll_Colt Forum 5 07-26-2013 01:22 PM
Adding weight to balance snowblower chucker8 John Deere Forum 23 01-30-2013 07:48 AM
