425 fan - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 12-19-2018, 08:26 AM Thread Starter
Wink 425 fan
Is possible to reverse the fan on 425 motor to push heat into the cab. The tractor is only used to blow snow in winter not a summer driver.
millwright3000 is offline
post #2 of 14 Old 12-19-2018, 09:58 AM
Jimbochap's Avatar
Re: 425 fan
I would think turning it around , it would then hit the belt on the water pump.
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is offline
post #3 of 14 Old 12-19-2018, 10:02 AM
Re: 425 fan
even if you could turn it around I think you would be asking for more problems that its worth...possible over heating ...sucking in moisture from melted snow.. dirt dust...ect..
12ultra is offline
post #4 of 14 Old 12-19-2018, 11:02 AM
Kish JD 318/420/430
RussKish's Avatar
Re: 425 fan
Some have added small generators on the back of their tractors to power some small electric heaters with fans (110VAC). They did this because the engines could not generate the needed amps to power the additional load. So built a mounting box on a sleeve hitch mount and strapped the small generator on to that, it acts as weight too for traction.
Russ
Proud Owner of: 318/420/430
RussKish is online now
post #5 of 14 Old 12-19-2018, 12:09 PM
Re: 425 fan
Turning the fan around will not reverse the airflow. One would need a fan with the blade pitch reversed.
antiqueetc is offline
post #6 of 14 Old 12-21-2018, 02:01 AM
no2498's Avatar
Re: 425 fan
fumes kill one small leak you die
have a good day
john
no2498 is online now
post #7 of 14 Old 12-21-2018, 05:13 PM
ggsteve's Avatar
Re: 425 fan
have a good day
john
I was wondering when someone was going to mention that.
ggsteve
80 Cart
78 JD 316K 49 blower
Woods box blade
ggsteve is offline
post #8 of 14 Old 01-05-2019, 09:39 PM
830King's Avatar
Re: 425 fan
I just recently did this to my x475. I bought a fan online and made it fit. Have not had a opportunity to put it work to see how it does until next the snowfall. I have fired it up and ran wide open throttle with no issues, but that's all it's done so far. I'm currently searching online for a small cheap battery powered carbon monoxide tester to keep in the cab. If I need to use the machine before I have a tester I'll just take a door off or something for ventilation. So far I have around $40 into this modification not counting the used bracket and pulley i just bought off Ebay to mount the summer fan onto. That way i can just swap the whole assembly in spring and fall.
Another option is a electric pusher fan. Like what's on a car, can be found online for ~$50. Seen them with no sensor meaning you'd have to watch the gauge and turn the fan on/off as needed(could just leave it on all the time too), or some have a temp sensor that slides into the radiator fins for automatic on/off. I went with mechanical only because I'm using most of what my alternator can handle already with my lights and fan for the heater.
Sent from my SM-G930V using Tapatalk
830King is offline
post #9 of 14 Old 01-05-2019, 10:05 PM
jensenkennels's Avatar
have a good day
john
have a good day
john
Darwin Award contender in the making.
jensenkennels is offline
post #10 of 14 Old 01-07-2019, 06:48 PM
Re: 425 fan
What I would do, is purchase a self contained 12v heater that uses heated coolant. Put a T and shut off valves to the radiator hoses, and plumb the heater into the T's. This way you can partially bypass the radiator. You can partially close the valves until you start getting good heat. Since the heater core is also a radiator core itself, it will be able to maintain temp especially in a colder climate
matt167 is offline
post #11 of 14 Old 01-07-2019, 07:20 PM
830King's Avatar
Re: 425 fan
Mine overheated with the radiator plumbing in tact, with my heater core on high, but I did have the radiator fan removed. I've been experimenting with different options. So per my experience the heater core is not enough cooling for the engine.
830King is offline
post #12 of 14 Old 01-07-2019, 08:13 PM
Re: 425 fan
It's not enough on it's own. That's why you would put in a restriction to block only some of the coolant across the radiator. But also, on a vehicle that goes no faster than 7 mph, the radiator fan is basically required, since it cannot dissipate heat with no air movement. Also if you don't block some flow, the heater core would get very little coolant moving through it, hindering the cooling performance even more
matt167 is offline
post #13 of 14 Old 01-07-2019, 08:35 PM
830King's Avatar
Re: 425 fan
At first I tried blocking the radiator by placing vinyl over the screens where it takes air in. It still sucks air thru the dash and wherever it can, so the cab acts like a wind tunnel. And almost all of the heat from the heater core gets sucked into the radiator right away.
830King is offline
post #14 of 14 Old 01-07-2019, 08:59 PM
830King's Avatar
Re: 425 fan
830King is offline
