Johnson Loader Project - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 208 Unread 11-10-2018, 01:05 PM Thread Starter
oaks1450's Avatar
Well it finally happened. There's a Johnson Loader in my shop just waiting to be mounted up to my 110. At the moment I have two 1964 round fenders, one that I am restoring and one that I can use, not restored. If it wasn't for forums like this I wouldn't even know that they even made a FEL for this tractor. So after extensive searching and patience I was able to make a deal happen on craigslist. So I wanted to share my project the best I can also. I am pretty sure I have all the parts I need except for some bolt and maybe some pins. It also looks like I may have too replace some hydraulic hoses right off the bat too. Not really sure how the ballast box is supposed to bolt up either, but I'm sure that will the least of my worries.
Are there any issues installing this onto a 64 110? Most loaders I have seen, have been on 112's with 10hp motors and 5 bolt hubs.
What was the original color of this loader? previous owner said it was a goldish/yellow. I've seen some that were white.
This will be a slow project as I have been working all the time lately, but any help or input is greatly appreciated!
ID:	2345765   Click image for larger version
ID:	2345767   Click image for larger version
ID:	2345771   Click image for larger version
ID:	2345775   Click image for larger version
ID:	2345777   Click image for larger version
ID:	2345779   Click image for larger version
1964 110
1964 110 w/Johnson 10 loader
1987 318
1991 420 w/ 44 Loader
2007 X300 w/bagger
oaks1450 is online now
post #2 of 208 Unread 11-10-2018, 01:15 PM
Hangin with the cool kids
poncho62's Avatar
Re: Johnson Loader Project
Nice.....kind of interesting how that big bucket attaches to the smaller one.
Ford LGT100
Ford LGT125
Ford LGT165
MTD 990 Wizard
MTD 960
John Deere STX38
poncho62 is offline
post #3 of 208 Unread 11-10-2018, 01:59 PM
The Admin from... Nowhere
littletractorguy's Avatar
So, the biggest problem you'll have mounting the Johnson 10 to a '64, I figure, is going to be the fact that you'll have to pull your footrests and space them out so you can fit the rear mounting frame for the loader onto the tractor. The '67 frame had slots cut for the loader mount... Here's what my '67 112 footrest looks like.
So with the slots in there, you can do up the front, then just slide the mount up into the slots and do up the rear carriage bolts.
Lemme see if I can find my pix of how I mounted my ballast box... Here's one that shows the straps I made to attach the sides of the box to the tractor:
And then I dropped a very short but pretty massive bolt into the hitch plate hole and tightened it up...
post #4 of 208 Unread 11-10-2018, 03:58 PM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
Welcome to the Loader Club....... once you've had one, there's no going back to the wheel barrow.
Larry ( in Southern Ontario )
Larry LGT 165 is online now
post #5 of 208 Unread 11-10-2018, 05:00 PM
inspectorudy's Avatar
I've got a PDF of an original Johnson 10 manual if you think it would help you. It's for a Cub Cadet but it has a lot of specs and pictures in it. Send me a PM with your email address and I will send it to you.
Rudy
inspectorudy is offline
post #6 of 208 Unread 11-10-2018, 05:59 PM
Parts collector
mopar65pa's Avatar
Good deal I wold love to have a FEL for one of my tractors.
1970 140 H1
1977 300 H2
1983 314 H1
110 parts tractor
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #7 of 208 Unread 11-10-2018, 06:04 PM Thread Starter
oaks1450's Avatar
Ok thanks Littletratorguy for the info. Guess I値l have to figure out some sort of spacer for the foot rests. Also nice to see how the ballast box is mounted to you tractor and explains the holes in the side of my box.
Thanks Inspectorudy for the manual
Took the mower deck off and hangers off the 110 today after work and moved the 318 out to the shed for more room and brought the 110 in.
1964 110
1987 318
2007 X300 w/bagger
post #8 of 208 Unread 11-10-2018, 07:22 PM
poncho62's Avatar
Would a loader not be more suited to a 318?.....Power steering and all that jazz.....just wondering
Ford LGT100
Ford LGT125
Ford LGT165
MTD 990 Wizard
MTD 960
John Deere STX38
poncho62 is offline
post #9 of 208 Unread 11-10-2018, 08:11 PM Thread Starter
oaks1450's Avatar
I知 sure power steering would make things easier, but I知 hoping with the size of this loader being so small it痴 not such a burden to steer. We値l see soon enough.
Just got done taking off the floor boards and was able to do a temporary mock up with some spare nuts and bolts I had laying around. Plan on getting what you see here bolted up tomorrow after work. Also try and figure out what i知 gonna use for a spacer between the frame and floor boards.
Also took off the PTO. I imagine the hydraulic pump bolts up somewhere in this area.
ID:	2345829   Click image for larger version
ID:	2345831   Click image for larger version
ID:	2345833   Click image for larger version
1964 110
1987 318
2007 X300 w/bagger
post #10 of 208 Unread 11-10-2018, 08:35 PM
lotsofspareparts's Avatar
The only downside to installing the Johnson 10 on a '64 is the front axle.
It states in the 10 manual that if you are going to install on a '64 that the front axle should be swapped out for the cast axle from the '65-'67. I think in your case it would depend on how you plan to use the loader. Is it more for looks/light duty or are you going to load it to the max every time you use it.
I too have a Johnson 10 on my '65 110. It is the original gold color, which you can see if you look at your subframe and pump bracket. It's great you have a ballast box too, my loader didn't come with one but I have the dimensions to make one (thanks LTG).
Spacing out the footboards was easy, I bought a strip of 1" x 1/4 flat stock steel and just cut them to length. I also replaced all of the carriage bolts since the footboards were now spaced out.
Jared
ID:	2345839   Click image for larger version
ID:	2345841   Click image for larger version
ID:	2345843   Click image for larger version
ID:	2345847   Click image for larger version
Currently in the stable
'97 LX188 - '83 216H - '82 317 - '81 317 - '79 317 - '71 120 - '70 120 - '70 120 - '70 112H Sunset Orange - '70 112H Patio Red - '68 140H3 "Side Tag" - '68 140H3 - '69 140H3 - '68 112H "Side Tag" - '68 112H - '67 112H - '67 112H - '66 110 - '65 110 - '64 110 - '64 110 - '47 Model A
2014 Kubota GR2120
'74 Homelite T-10
'79 Case 446
"Deerely Departed"
'03 GT245 - '84 318 - '83 318 - '74140H3 - '72 140H3 - '70 140H1 - '68 110H - '67 112H - '67110H - '65 110
lotsofspareparts is offline
post #11 of 208 Unread 11-10-2018, 08:48 PM
Hahn Star
MikMan48's Avatar
Everyone loves a loader project! Best of luck and I am excited to follow along
Sent from my SM-A520W using Tapatalk
Challenge Met
Have you met "The Fahn" yet?
https://www.mytractorforum.com/189-o...meet-fahn.html
MikMan48 is offline
post #12 of 208 Unread 11-10-2018, 09:13 PM
Been reading thru this thread with interest.
I don't think anyone has mentioned that the Johnson Workhorse 10 with the single bucket curl cylinder was also known as the Johnson "Midget" Loader.
Johnson themselves named it as such and this may help with your searches for pics or info.
They later became the Johnson Workhorse 10TC, TC being twin cylinder.
post #13 of 208 Unread 11-10-2018, 09:20 PM
Oh yeah, the PTO clutch can't stay on there, as that's where the pump mounts...
I wound up using one of those jointed adjustable size belts since I couldn't find one the right length. Let me know if you need any pics of the pump mount, I can go out and fire some off...
post #14 of 208 Unread 11-10-2018, 09:28 PM Thread Starter
oaks1450's Avatar
Thanks for the pic. I may hit you up later for another pic when I get closer to mounting up the pump. Thanks!
1964 110
1987 318
2007 X300 w/bagger
post #15 of 208 Unread 11-11-2018, 10:11 AM
No problem! How different IS the front axle on a 64 versus a 65 and newer? I can't tell from the new JD parts site. I may have a spare cast axle from a '66 hanging around...
