k62 very touchy, I need advice - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 33 Old 09-28-2018, 11:18 AM Thread Starter
Hello!
Hey guys, I have a 17 year old JD with a K62 tranny and it really jerks you when either you letting off the gas, go into reverse or forward. It is very touchy.
The oil looks clean and the tranny never gets hot to the touch just warm.
I will eventually try changing the oil but it looks like I will have to take the back half of the body off to get to the fill spots.
There is also a dampening shock attached to the tranny and I am wondering if that is the issue.
Thoughts?
Thanks,
Mike
WildMike is offline
post #2 of 33 Old 09-28-2018, 11:49 AM
JD-285's Avatar
I would take a good look at the shock. It help control pedal movement once the pedals are released. Check of travel movement of pedals. ie grass stuck, linkages needing oiled. Take shock off and see what it does.
So you said something about letting off gas. Do you mean reducing throttle position? The fwd and rev pedals are not a gas pedal.
X500 "Wife's"
285 "The Ames" backup 1
165 "The 165" (Upgrade to FC420V from 170) backup 2
JD-285 is offline
post #3 of 33 Old 09-28-2018, 12:25 PM
Still lovin' the 322!
PA318Guy's Avatar
Re: k62 very touchy, I need advice
JD-285 is giving you good advice. The K62 is very touchy and even the damper only works to some extent. You have to learn to engage them slowly.
Current Machine JD 322
PA318Guy is online now
post #4 of 33 Old 09-28-2018, 12:36 PM
JD-285's Avatar
Thank. That came from the school of hard knocks and RayJay.
X500 "Wife's"
JD-285 is offline
post #5 of 33 Old 09-28-2018, 03:23 PM
Money Pit
Dave Wells's Avatar
Very good advice above. When the damper (mini shock) fails there's no resistance on the FWD REV pedals. This will cause a jerky fast engagement and sometimes not return to neutral when you let off the pedal. Be careful hoods and bumpers aren't cheap.
dave wells
Dave Wells is offline
post #6 of 33 Old 09-28-2018, 03:29 PM Thread Starter
Thx guys, I was hoping you would say the shock.
WildMike is offline
post #7 of 33 Old 09-28-2018, 03:34 PM
JD-285's Avatar
Shocks $130. Still want us to say it?
X500 "Wife's"
JD-285 is offline
post #8 of 33 Old 09-28-2018, 06:45 PM
oldgibsonguy's Avatar
Worth $130 if that's the replacement cost. The shocks only job is to inhibit sudden starts, stops and jerky motion. At slow speeds though, letting off the pedal, especially in reverse, can still result in a sudden stop. Better the shock than something more costly.
oldgibsonguy is offline
post #9 of 33 Old 09-28-2018, 08:12 PM
mikgran's Avatar
Is this the same one?
https://www.ebay.com/itm/New-Genuine...0AAOSw8Atbd3C2
2004 X485- 54 deck, 47 blower
1977 210
1970 110H
1991 Ariens YT12H w/bagger
1986 Kubota B7200HST
mikgran is online now
post #10 of 33 Old 09-29-2018, 10:26 AM
240vtx's Avatar
Originally Posted by mikgran View Post
Good question
240vtx is offline
post #11 of 33 Old 09-29-2018, 11:02 AM Thread Starter
130$ ? yeah I want you to keep saying that all day long. A lot easier to get at and cheaper ,less headaches than messing with that transmission
WildMike is offline
post #12 of 33 Old 09-29-2018, 11:14 AM
JD-285's Avatar
I would agree. You can swap the shock pretty quick if it is like my GT245.
X500 "Wife's"
JD-285 is offline
post #13 of 33 Old 09-29-2018, 01:54 PM
You would have to buy one to find out. The mounting arrangement is for an LT1xx not the LX2xx but the damper itself may have the same stroke and work just fine after removing the retaining clips on the ends.
rayjay is online now
post #14 of 33 Old 09-29-2018, 02:05 PM
JD-285's Avatar
I might gamble for $30 on the replacement shock if it looks like it would work. Verses $130.
What model are you working on?
X500 "Wife's"
JD-285 is offline
post #15 of 33 Old 09-29-2018, 06:44 PM
You can look for a used shock on ebay, and I believe the shock from the 425, 445, 455 is the same size shock. I got one for about $25.
BigGoodJohn is online now
