Finally, got a 318 Project! - Page 6 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #76 of 120 Old 06-16-2018, 04:18 PM Thread Starter
Knoxville36's Avatar
Originally Posted by REdington View Post
Go to your local NAPA (or any good auto parts store) and they can make you new hoses.
All the actual hydraulic lines are good. I am talking about the plain rubber black hosing in some places. For example the "T" fitting right under the battery tray. Looks like plain rubber hose and 3/8" size.
2005 John Deere GX 255 - 48" Edge Deck
1999 John Deere JX75
2006 John Deere JX75
2017 John Deere X758
-54" HC Deck
-54" Blade
-mc519 Collection System
Knoxville36 is offline
post #77 of 120 Old 06-16-2018, 04:19 PM Thread Starter
Originally Posted by N2 Tractors View Post
Power steering and oil cooler is the last piece of the puzzle I need to convert a 316 into a 318. I am interested in the power steering and hydro oil cooler connection.
Sorry N2, I will be reusing everything once I paint and reassemble.
-54" HC Deck
-54" Blade
post #78 of 120 Old 06-16-2018, 04:37 PM Thread Starter
Got some good time last night. Got all of the steering box out. Also got the 4 hydraulic couplers in the front out. They were completely rusted over and completely stuck. They are not reusable and I ordered 4 new ones. Got the hydraulic lines unscrewed from the SCV. I could not get 2 lines out of the tractor and looks it will be a lot easier once I drop the front axle out of the way. Also went to the Deere dealer and got some Blitz black paint and thinner. I got a few parts that I might test my spray gun out in since I have never used one.
ID:	2314489   Click image for larger version
ID:	2314497   Click image for larger version
ID:	2314505   Click image for larger version
-54" HC Deck
-54" Blade
post #79 of 120 Old 06-16-2018, 10:21 PM
Re: Finally, got a 318 Project!
Then your talking about the return line that doesn't have all the pressure on them. Just get some regular hydro hose then. Don't use fuel line as it will degrade faster than hydro hoses will.
Rodney
'68 140 H3 Will have a 4 way 54" blade on it for snow removable.
'69 140 H1 "Ole Faithful" My main mower with 48" replacement deck K341 powered (this is in my signature photo)
'71 120 H1 Haban sickle mower will live on it once I get it restored
'72 140 H3 Lives with a 33 tiller with both extensions on it
'73 140 H3 tore apart Being restored
'74 140 H3 tore apart Being restored
'81 314
'88 332 Wife's Tractor
'95 445
REdington is offline
post #80 of 120 Old 06-17-2018, 01:06 AM
Rebuilding my First JD GT
N2 Tractors's Avatar
Sorry I meant I am interested is seeing how it is all hooked up. Not in purchasing your steering parts.
Running:
‘73 140 H1, ‘75 214, ‘79 JD 317 Onan P218G, 19xx Wheel Horse D250 550 Arc FEL ARPS Box blade
Not Running:
‘69 JD 140 H3, ‘75 JD 300, ‘79 JD 317 Kohler KT17QS II, ‘83 JD 420, late ‘80’s JD 316, ‘90 JD 316,
2x 300 series 3PH, Johnson Workhorse 12, Gannon Earthcavator 32”, 2x JD 54” 4way blade, 2x JD 33 Tiller + 8" Extension, JD 38” Brass tag mower deck, JD 48” mower deck, JD #30 Hydro Tiller, Disks, Plow, ARPS Angling Backblade,
N2 Tractors is offline
post #81 of 120 Old 06-17-2018, 08:30 AM Thread Starter
Got you! Let me go though my pictures and see if I have a good picture.......
-54" HC Deck
-54" Blade
post #82 of 120 Old 06-17-2018, 11:35 AM
No hurries, I don't have the parts yet. Just putting it out there in case you don't have any pics you may be able to get some later on when you put it all back together.
Running:
Not Running:
post #83 of 120 Old 06-17-2018, 03:00 PM Thread Starter
No hurries, I don't have the parts yet. Just putting it out there in case you don't have any pics you may be able to get some later on when you put it all back together.[IMG class=inlineimg]https://www.mytractorforum.com/images/MyTractorForum_toucan//smilies/tango_face_smile.png[/IMG]
I did not go through the whole system but I did go through a little this morning and very lightly reassembled.
1. There is a hydraulic line that runs from the top port on the back of the SCV and runs up the driver side frame rails and connects to the top left portion of the "T" fitting.
2. On the "OUT" port of the steering box, there is a short hard lined "u" shaped connection with a few inches of rubber hose and this feeds into the bottom of the "T" fitting with regular hose clamps.
3. The final piece of the "T" fitting is the small piece of rubber hose that runs from the upper right "T" connection, and connects to the port on the oil cooler facing toward the middle of the tractor.
4. There is connection that is the return line from the cooler on the right (passenger side) that is pointing down. There is a few inches of rubber hose coming off this and it hooks into a hard hydraulic line. This line runs along the passenger side frame and runs over the transmission/pump and connects to the left side (drivers side) port by the relief valves.
5. There is a hydraulic line that runs from the out port of the pump (passenger side) of the pump and basically runs through the middle of the tractor and connects to the "IN" port on the steering box.
6. A hydraulic line connects to the bottom port of the SCV. This line also runs along the driver side and comes up and connects to the "AUX" port on the steering box.
7. The last 2 ports on the steering box are the "Right" and "Left" for the steering hydraulic lines. Looks like the "Right" port will connect to the rear port of the sterring cylinder. The "Left" port line will be connected to the front of the steering cylinder.
I have to be honest, I really should have made more notes on the front hard hydraulic lines, might have to study and take a look on which ports on the SCV they connect to......
I hope this will help a little, and help me for assembly
ID:	2315449   Click image for larger version
ID:	2315457   Click image for larger version
-54" HC Deck
-54" Blade
post #84 of 120 Old 06-17-2018, 09:49 PM Thread Starter
Man it was hot today! Did not feel like crawling under it and pulling the transmission so I did a lot of cleaning! Started with our small garage. Cleaned it up so I have room to lay parts out and organize.
1. Broke out the power washer and hose and went to town on small parts. Cleaned the TDM, hydraulic oil cooler, degreased the 4 front hydraulic lines, front axle, and cleaned up the gearbox. All of these are completely degreased and ready for tear down, sanding, primer and paint. Spent almost 2 hours cleaning these parts!
2. Rookie painter here so I actually messed around with the small bracket that the TDM mounts to on the gear box. Broke out the air sander and roughed it up and smoothed our. Cleaned it up with alcohol and proceeded to get 3 coats on this morning. Combination of a little wind and baking in the sun all day it was dried out. I wet sanded it down with 240 sand paper. Then laid down 2 light coats of Blitz Black. Looks really good and smooth. More coats tomorrow. Then practice wet sanding and buffing before tuning to the large pieces!
ID:	2315785   Click image for larger version
ID:	2315793   Click image for larger version
ID:	2315801   Click image for larger version
-54" HC Deck
-54" Blade
post #85 of 120 Old 07-10-2018, 09:57 PM Thread Starter
Well, I have been very busy with work and kids!!! Been working a little bit and got the whole tractor tire down. Started with the engine. Degreased and painted. Brand new intake manifold, exhaust gaskets and some new exhaust clamps. Some stainless steel hardware to button everything up. I have all the Tim painted except the large rear piece of tin. I sanded that tonight and got 2 coats of primer on. I am going to sand it tomorrow and start painting. It should be completely buttoned up and engine will be ready to go back in......
I was waiting on a TON of parts, paint, tires. All same tonight so I should have everything I need to start getting everything blasted and start painitning and assemble.
ID:	2322819   Click image for larger version
ID:	2322821   Click image for larger version
ID:	2322823   Click image for larger version
-54" HC Deck
-54" Blade
post #86 of 120 Old 09-12-2018, 09:51 PM Thread Starter
Just wanted to update the build. I had intentions to document every step of the process but I am a busy man! I have a lot of hours in this thing and am having a lot of fun learning and building this tractor. I am replacing a lot of hardware and parts as I go along!
As I have went, I have decided that this is not a show piece and never will be. Just a really nice toy and worker here and there. I have everything painted as far as the frame and hardware goes. I got a lot done in the past couple days. The SCV is in, rock shaft pump and lines installed, front axle is in. All hard lines have been ran. Tomorrow I hope to get the steering pump and new hydraulic hookups on the front installed tomorrow.
After that I will be ready for a lot of the "Green" parts soon!!!!
ID:	2334305   Click image for larger version
ID:	2334307   Click image for larger version
ID:	2334309   Click image for larger version
ID:	2334315   Click image for larger version
ID:	2334317   Click image for larger version
ID:	2334319   Click image for larger version
-54" HC Deck
-54" Blade
post #87 of 120 Old 09-26-2018, 07:24 PM Thread Starter
All of the body panels and rims have been completely cleaned and blasted. John Deere Buff Primer was applied. I am going to start sanding and smoothing and getting ready for paint this weekend!
ID:	2337139   Click image for larger version
-54" HC Deck
-54" Blade
post #88 of 120 Old 09-26-2018, 07:54 PM
lotsofspareparts's Avatar
That's some amazing work, and ALOT of it!!
Really looking forward to the end result!!
Keep it up!!
Jared
Currently in the stable
'97 LX188 - '83 216H - '82 317 - '81 317 - '79 317 - '71 120 - '70 120 - '70 120 - '70 112H Sunset Orange - '70 112H Patio Red - '68 140H3 "Side Tag" - '68 140H3 - '69 140H3 - '68 112H "Side Tag" - '68 112H - '67 112H - '67 112H - '66 110 - '65 110 - '64 110 - '64 110 - '47 Model A
2014 Kubota GR2120
'74 Homelite T-10
'79 Case 446
"Deerely Departed"
'03 GT245 - '84 318 - '83 318 - '74140H3 - '72 140H3 - '70 140H1 - '68 110H - '67 112H - '67110H - '65 110
lotsofspareparts is offline
post #89 of 120 Old 09-26-2018, 08:07 PM
Still lovin' the 322!
PA318Guy's Avatar
Yep, a lot of attention to detail going on there Knox! Nice to see it being brought back to like new condition. Think your painting skills exceed my spray can talent! Looking forward to the green paint work to see how it comes out.
Current Machine JD 322
PA318Guy is offline
post #90 of 120 Old 09-26-2018, 09:26 PM Thread Starter
I have used rattle cans on many things and I am always amazed at the results to be honest. I was scared to death of a spray gun but not as bad as it seems and seems to get really good coverage and smoother than a spray can to be honest!
-54" HC Deck
-54" Blade
