Mini dozer + - Page 7 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #91 of 105 Old 11-19-2016, 10:11 AM
Re: Mini dozer +
Originally Posted by snowblower View Post
I installed a platform on the mini dozer for my construction. This makes a strong and mobile scaffolding. In addition to the lift can lift materials.
If you have a winch on each end,you could hook the cable from one or both and drag the machine to the new location ,using the remote winch control..no climbing up & down!..
Tractor-Holic is offline
post #92 of 105 Old 11-22-2016, 02:36 PM
Re: Mini dozer +
Thanks!
I had no problem with the pump.
The internal relief valve does its job.
The only problem I had was the wheels in front of the track, the hubs ripped off. I leave it replaced by a much more robust bushing wheel. The central wheels is OK, They do not undergo the big traction force through the tension of the tracks
I have used 13.9 In / Cu hydraulic wheels motor directly connected to 11 "sprochets. This gives teorically a maximum speed of 6km/h and a maximum intermittent torque of 1500 lbs / ft (the sum of the two track, 2 motor)
On the grass, if I try to load a load too heavy (like pulling a garage) The front of the mini doser will rise in the air before the tracks begin to skid on the back end.
We can also use a smaller hydraulic motor with sprockets and chains to increase the torque (I did this with my excavator) The ideal is not to be at the upper or lower limit of the specifications of the hydraulic motors in terms of flow (GPM).
Awesome, thanks for the info. I'm still in the drawing/modelling stage for my project and you've already solved a lot of the problems I'm facing. Your ideas for the linkage to the pump and control panel are going to be a huge help too. Thanks again!
Mandres is offline
post #93 of 105 Old 02-11-2017, 07:49 PM Thread Starter
snowblower's Avatar
Re: Mini dozer +
snowblower is offline
post #94 of 105 Old 09-03-2017, 06:10 AM
Re: Mini dozer +
I am glad youtube still works. I really wanted to see this. Nice machine!!!
Is there a class action lawsuit against PB? They ruined the web!!!!
1963 John Deere 2010 diesel model 48 F.E.L.
1967 Sears Custom 6HP
1971 Sears Custom 10XL.
1972 Honda XL250Motorsport*Still looking for parts*
1987 John Deere 1050 w/model 80 F.E.L.
2009 Husqy YTH2454
xj35s is offline
post #95 of 105 Old 09-03-2017, 02:02 PM Thread Starter
snowblower's Avatar
Re: Mini dozer +
Yes Photo buscket has destroyed hundreds of hours of my work on different forums !!
I had changed last year for image stack which requires very small fees and works much better than photobucket, but rebuilding all my posts would require a crazy job.
post #96 of 105 Old 09-16-2017, 11:33 PM
Re: Mini dozer +
Thank you for adding these. I love how nice everything fit inside. perfect little machine.
2009 Husqy YTH2454
xj35s is offline
post #97 of 105 Old 01-12-2019, 09:17 PM Thread Starter
snowblower's Avatar
Re: Mini dozer +
It's snow that I unloaded from the roof, so it is very compact hard. A hand snowblower would never have wanted to enter this snow!
post #98 of 105 Old 01-13-2019, 09:56 AM
Re: Mini dozer +
Nice build, I also like making things that no one else has. I like the way you faced the radiator in front of you so that in the winter time it keeps you warm.
Did you do a build on your backhoe, i'm doing a similar build? If you do have a build could you link me to it?
9297oldram is offline
post #99 of 105 Old 01-13-2019, 11:50 AM
tracktortag's Avatar
Re: Mini dozer +
Very neat dozer, and excellent build! There are a lot of things to like. Is the frame in place for a eventual removable winter enclosure?
Dave
tracktortag is offline
post #100 of 105 Old 01-13-2019, 02:05 PM Thread Starter
snowblower's Avatar
Re: Mini dozer +
Thank,
The polycarbonate front window is removed quickly (secured with Velcro)
post #101 of 105 Old 01-13-2019, 02:08 PM Thread Starter
snowblower's Avatar
Re: Mini dozer +
Thanks,
By setting the engine in this direction, I did not need to put a drive shaft below the engine to bring power to the snowblower.
https://www.mytractorforum.com/119-h...ackhoe-14.html
post #102 of 105 Old 01-13-2019, 02:19 PM Thread Starter
snowblower's Avatar
Re: Mini dozer +
post #103 of 105 Old 01-13-2019, 06:09 PM
Still lovin' the 322!
PA318Guy's Avatar
Re: Mini dozer +
That's some serious snow removal, looks like it handled it well.
Current Machine JD 322
PA318Guy is offline
post #104 of 105 Old 02-25-2019, 10:35 PM Thread Starter
snowblower's Avatar
Re: Mini dozer +
Thanks!
More Snow
post #105 of 105 Old 04-24-2019, 11:23 PM
Re: Mini dozer +
Well done Bob
airlinemechanic is offline
