4x4 Backhoe excavator home made - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 42 Old 10-15-2019, 11:31 PM Thread Starter
snowblower's Avatar
I started in mid September a new 4 x 4 excavator.
Quite simple but powerful enough: 4WD bobcat-style steering
Adjustable stabilizers at the front and leveling blade at the rear that can be used to level, lift the back and anchor the back when working with the backhoe.
Backhoe rotates 200 degrees with hydraulic cylinders and gear, 3500lbs pull force at the bucket
Lifan 2 cylinder engine 688cc 24 hp, hydraulic pump 12.5GPM
27 '' 6-ply tires (industrial machinery tires would have been too steep for the weight of the excavator, which is more important than the weight of a UTV vehicle)
All orders are adjustable in front of the seats (10 spools valves)
Valve to adjust the hydraulic flow without losing the pressure to have the right shoveling speed according to the work and the experience of the operator.
Speed ​​control valve for downhill.
Towing on the road without the need for a trailer.
snowblower is online now
post #2 of 42 Old 10-15-2019, 11:33 PM Thread Starter
snowblower's Avatar
Re: 4x4 Backhoe excavator home made
https://www.brx800.net/
post #3 of 42 Old 10-16-2019, 02:58 AM
20,000 Posts & Climbing
Looking good!!
TUDOR is online now
post #4 of 42 Old 10-16-2019, 07:06 AM
Mark in Portugal's Avatar
Cool work;
I did something similar to the chain sprocket / cog wheel, but a lot smaller.
Mine is now failing; not enough rigidity and too much load caused slip, slight damage, and now increasing slip.
Your's is much, much stronger; but so is your load.
Name:	hedge cutter gearbox big.jpg
ID:	2400797   Click image for larger version
Name:	possitioning sprocket.jpg
Mark in Portugal is offline
post #5 of 42 Old 10-16-2019, 08:19 AM
Nice work, you must have quite a shop for that kind of fabrication.
9297oldram is offline
post #6 of 42 Old 10-16-2019, 09:32 AM
Subscribed! Nice webpage!
Hydronerd is online now
post #7 of 42 Old 10-16-2019, 10:50 PM Thread Starter
snowblower's Avatar
Thank you!
I built it for someone who will take it this spring, I will try it before.
post #8 of 42 Old 10-17-2019, 10:18 AM
I think the wheel base is long and the tires are too grippy for skid steer like a Bobcat. The early Bobcat's had really short wheelbase; shorter in length than width. Now they have increased the wheelbase for stability, but have 60HP engines to power turning. Since you are using the blade and out-riggers to stabilize while digging, the wheels are just for transport. I would consider moving the wheels much closer together.
Use counterbalance valves for downhill speed control; they are available to mount directly on motor depending on motor make/model.
Will you disconnect motors for towing?
post #9 of 42 Old 10-17-2019, 03:56 PM Thread Starter
snowblower's Avatar
I am 55 '' wide and 53 '' wheelbase.
So I proportionally a little longer than the bobcat that would have 44 '' of wheelbase for this width.
This vehicle will not work on pavement, often gravel and dirt, it's easy. Especially since the weight on the rear wheels is lower than the weight on the front wheels, the rear wheels will be easy to derail.
The machine will circulate in the wood, so I wanted it not too late pouring when the terrain is uneven.
For engine power and traction, the Bobcat 60hp is more than 6000lbs without load in the bucket, and my excavator will weigh less than 2400lbs, and will have a lower movement speed, so much torque compared to the weight of the excavator.
I have not seen these motor with valves, are they expensive? My method of 'braking' is not perfect but very affordable.
The excavator tires would not ride well on the road, and the weight on the tow bar would be much too high. It's trailer tires that will be on the ground with trailer hubs, the 4 wheels of the excavator will be 6 '' to 10 '' in the air.
post #10 of 42 Old 10-17-2019, 07:35 PM
Okay, you did your homework. I realized the weight was big factor, but I choose not to mention . About 5.8mph. I have a Melroe Bobcat that's 18HP; I have to set speed at about 3 mph to have enough HP for a 360.
What is pressure rating of hydraulic motors?
post #11 of 42 Old 10-17-2019, 10:10 PM
tracktortag's Avatar
Another great build in the making, Snowblower!
Dave
tracktortag is online now
post #12 of 42 Old 10-18-2019, 10:11 AM
Here is a motor mount counterbalance. Maybe you can find two Case (Ingersol) hill valves.
mmcb-10_520-p-131300-en (1).pdf
post #13 of 42 Old 10-18-2019, 11:00 PM Thread Starter
snowblower's Avatar
Thank you!,
One of the biggest challenges is to manufacture it for less than $ 12,000 CND with hardware, new parts, consumables included and a small profit.
I used a valve that allows to adjust the flow that passes in the valve spools, as on my first excavator, it is very pleasant to be able to precisely adjust the speed of work according to what we do.
I'm going to have more tire torque than my first excavator.
The steering (bobcat) will greatly reduce the turning radius compared to my previous excavator.
On the other hand there will not be 2 moving speeds , limitations of costs.
post #14 of 42 Old 10-18-2019, 11:02 PM Thread Starter
snowblower's Avatar
Thank you, but I just have a small garage of 14 'x 24', a small milling table top, a mini lathle, circular saw, grinders, a hydraulic press of my manufacture.
I have a new mig 275amp welder that saves me time with its big duty cycle.
post #15 of 42 Old 10-18-2019, 11:06 PM Thread Starter
snowblower's Avatar
The engines are capable of 2900psi continuous, 19 CU-IN
The speed will be 6 km / h
Thank you
https://blog.bobcat.com/2016/03/m440...oader-in-1962/
You may post new threads
You may post replies
