My Deutz Ultima 1920 (Sunstar) Full Build - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 06-17-2019, 10:30 PM Thread Starter
Was never a GT guy but into cars. Built my house and dreamed of building a tractor with a FEL for almost 16 years now. Finally figured my back is shot I need something to help me lift things. I found a Deutz local and decided to just buy it and see what can be done. It was a basket case and in the end I wish I would have passed on it. Blown engine, blown Sundstrand, dents and rust. It was listed as garage kept and waxed often and looked good in the craigslist pictures.
So my fist mistake was the engine choice 4A032 Military surplus engine. Its 32 CI flat 4 air cooled it spins the wrong way and air flow is the wrong way. I flipped everything so coolers were now in the grill and air went threw the engine and out the hood. Also Sundstrand was flipped and I converted to pedals to make room for the FEL controls. It fit so nice and everything was built around that motor. Problem is the tractor got out of hand and I had a 13GPM pump that would stall that little motor anytime any cylinder hit end of stroke. Also this little Deutz got very heavy close to 3000 LBS with the backhoe and that little engine struggled just to move it. So after 3 years I pulled the engine and put a Kohler EFI 26.5 HP and that thing has more power than I can use. Never wanted a diesel and this EFI puts out more torque then any diesel I could fit in this thing.
The loader is a L360 Case loader off of the Case / Boomer 55hp tractors and I cut it down to fit this little GT. Also has the QDQA front end so I can quick attach any john deere front accessories like my forks. The back hoe is a Kubota BT600, was going to build one but then found this cheap. It takes seconds to change out the bucket or forks and 3-5 minutes to take off the 3pt arms and attach the backhoe.
ID:	2382345   Click image for larger version
ID:	2382347   Click image for larger version
ID:	2382349   Click image for larger version
ID:	2382353   Click image for larger version
ID:	2382355   Click image for larger version
ID:	2382357   Click image for larger version
ID:	2382361   Click image for larger version
ID:	2382363   Click image for larger version
ID:	2382365   Click image for larger version
bkb94 is offline
post #2 of 6 Old 06-17-2019, 10:49 PM
Still lovin' the 322!
PA318Guy's Avatar
Re: My Deutz Ultima 1920 (Sunstar) Full Build
Wow, now that is some fabrication to get it set up like that! One of the only other "Green" Tractors I'd like to own, came close to getting one and missed it. That has to be the biggest ballast box I've seen on any GT! Kudo's on the work you did to get it personalized for your use!
Current Machine JD 322
PA318Guy is offline
post #3 of 6 Old 06-17-2019, 11:10 PM Thread Starter
The yard cart weighs 475lbs empty, I have put two big people in it and its still goes up at 975lbs. Have lifted 1200lbs with the forks but the 6 ply tires pretty much flatten out.
bkb94 is offline
post #4 of 6 Old 06-18-2019, 09:59 PM
That's a beast!
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #5 of 6 Old 06-19-2019, 05:48 AM
Country1966?'s Avatar
Completely impressed... Nice work!
Massey GC2400
Gravely ZT HD 60" 24hp Kaw.
Old Troy Build Horse Tiller
Husky Snow Blower 24" 6hp
Not Enough Barn
Country1966? is offline
post #6 of 6 Old 06-19-2019, 04:57 PM
Parts collector
mopar65pa's Avatar
Wow! Nice work!
I wouldn't mind having one of those "green" ones and a red and gray Massey.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
