Cat 0 Weldable Top Link Socket "HELP" - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 04-03-2019, 03:45 PM Thread Starter
Rebuilding my First JD GT
N2 Tractors's Avatar
I'm not sure the best place to put this so I figured this would be a good place to start.
One of the ball sockets on the top link to my 3 point hitch is damaged and not working correctly. I tried pb blaster, heating it with a torch, beating the snot out of it and I just flat out gave up on being able to free it up and ended up Cutting it off with a zip wheel on the angle grinder.
Does any one know where to get a weldable Cat 0 ball socket that matches the one's Deere used? Maybe Deere sells them? I have looked on line and am not finding anything that looks like the original with out paying almost as much as a complete manually adjustable Cat 0 top link assembly.
The Cheapest I could find is this one that looks like the original but it's really hard to tell from pictures. It's not exactly cheap either considering the whole top link can be had for about twice as much.
https://www.ebay.com/p/Top-Link-Ball...6444001&chn=ps
The price for this one is more like what I think is a fair price when I consider free shipping but it looks like cheap Chinese quality and craftsmanship.
https://www.amazon.com/RanchEx-10203...55873325&psc=1
Running:
‘73 140 H1, ‘75 214, ‘79 JD 317 Onan P218G, 19xx Wheel Horse D250 550 Arc FEL ARPS Box blade
Not Running:
‘69 JD 140 H3, ‘75 JD 300, ‘79 JD 317 Kohler KT17QS II, ‘83 JD 420, late ‘80’s JD 316, ‘90 JD 316,
2x 300 series 3PH, Johnson Workhorse 12, Gannon Earthcavator 32”, 2x JD 54” 4way blade, 2x JD 33 Tiller + 8" Extension, JD 38” Brass tag mower deck, JD 48” mower deck, JD #30 Hydro Tiller, Disks, Plow, ARPS Angling Backblade,
N2 Tractors is offline
post #2 of 9 Old 04-04-2019, 10:57 AM
Re: Cat 0 Weldable Top Link Socket "HELP"
I can't see anything in either of your links but now days it's hard to find/buy stuff made in USA for everything. If it looks close to working and it uses the same pin then it would be better then a frozen one.
You'd probably be surprised at how many parts the are on a new John Deere piece of equipment isn't made in USA.
9297oldram is offline
post #3 of 9 Old 04-04-2019, 11:27 AM
Have you tried Tractor Supply or Northern Tool?
Ariens93GT20 is offline
post #4 of 9 Old 04-04-2019, 03:53 PM
Links are a dud.
A CAT 0 ball will cost you 'bout $20±, a complete CAT 0 top link is going to be $40±, for $20 in the difference I wouldn't even be bothered welding a ball on, I'd get a new link, Just my 2 cents worth.......Mike
Iseki TM 3160
Mike Milburn is online now
post #5 of 9 Old 04-04-2019, 04:28 PM Thread Starter
Oh sorry for the dead links. Here is the ebay link
Here is the Amazon link
I know I could buy a Top link for about $30.00 or so shipped from farm and fleet but wheres the fun in buying when I can build and take pride in repairing it my self for less than the cost of new and the quality will be better as well as it will still be practically OEM once painted up the idea is to not be able to see that it has been repaired.
I'm getting close to finding a good solution.
5974 Ball Joint Assembly | Danuser
I will probably be welding up some steering parts soon as well so I'm getting a parts list going.
Running:
Not Running:
post #6 of 9 Old 04-04-2019, 04:44 PM
SSG
SSG's Avatar
The whole Cat-0 top link is $10-$14 locally for me, or about the same as buying a single replacement end. I can't imagine it would be too much more out on the west coast.
SSG is offline
post #7 of 9 Old 04-04-2019, 05:05 PM Thread Starter
Finding one locally is the main issue. I'll try to find one at the local ag hardware store today. I called 4 places already that should have it but don't. J. Millano, Discount Ag, The Farmers Blacksmith & J.M Equipement. None said they had it. I thought I saw some in J. Millano's a while back so I'm going to go in person just to make sure.
Danuser got back to me and said the .62 hole would be too small for the 5/8" pin. :/ It was a woman that got back to me saying she did not think it would work. She did not try it as far as I can tell. I'm going to follow up with her. It'll be nice to find a good quality cost effective source in case I want to build something else with these.
Running:
Not Running:
post #8 of 9 Old 04-04-2019, 11:53 PM Thread Starter
I found a ball joint locally at J Millano as I suspected for less than $11.00 OTD despite being told over the phone that they don't carry them and they have a whole top link assembly for $26 and some change. So I purchased the $9.80 + tax ball joint then welded it up so I can start using it soon. Not able to post pics from my phone for some reason otherwise I post a few pics.
Running:
Not Running:
post #9 of 9 Old 04-05-2019, 10:48 AM Thread Starter
Danuser got back to me a second time and was able to confirm those ball joints are in fact designed to be used for a 5/8" pin. The first reply I got from them a Lady told me she did not think they would work. So I replied asking her to verify with some one that can test fit a 5/8" pin and this time a Gentleman replied and stated that in fact those are designed to be used with a 5/8" pin.
Here are some pictures of the fabrication and end result as well as how bad the original weld looks and how crooked the ball joint was fit up :/
ID:	2369973   Click image for larger version
ID:	2369975   Click image for larger version
ID:	2369977   Click image for larger version
Running:
Not Running:
Replace cat 0 on my 455? SparkyT19 John Deere Forum 7 02-15-2019 07:15 PM
Kubota L175 L185 L1500 L1501 3pt Top Link Holder Bolt Torque MarkyP The Shed 2 08-05-2018 12:29 PM
"63 Ford 2000 4 cyl Gas top link bracket pin ghallmar Ford/New Holland Tractors 3 05-26-2018 08:08 AM
JD 3032e Top Link holder Brian Zdunowski John Deere 1 04-16-2018 03:16 PM
Hydraulic Top Link lengths/makers? Cat 0 coalminer16 Lawn and Garden Tractor Accessories 15 02-28-2013 09:54 AM
