The Little Mule 91 F150 - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Trucks 2 Wheel Drive , 4 Wheel Drive, Big or Small
post #31 of 36 Old 05-15-2019, 07:22 PM Thread Starter
Gravely1964
gravely1964's Avatar
Re: The Little Mule 91 F150
Originally Posted by MacLawn View Post
Now gravely, this is the ticket. An old truck thread will never die. We love old trucks. Keep're going.
Thanks. And more likely this truck will never go anywhere. A vow a made to my grandpa when he bought it for me is I would keep it until there was nothing left. Im very thankful hes still with us and kicking at 88. He came over the one day while the bed is still sitting on patio. I wasn't home but he was happy to see me working on it again / still.
ID:	2376703 I bought a 2015 F250 about a year ago now
ID:	2376705But I'll always be proud of my Little Mule Pic was not to long after reincarnation #1. This will be # 3
Steven Turcheck
current tractors and rigs
1944 WWII L
48 L grw's
52 US navy L, 2 53 Ls
1950's Bready
74 cub 129& case 220
48 Willy's CJ 2A
1991 ford F150 and Bronco
2007 F250 Big White
2010 Sc2450 yanmar
gravely1964 is online now
post #32 of 36 Old 06-07-2019, 12:07 AM Thread Starter
Gravely1964
ID:	2380443Getting things cut fitted and tacked in
ID:	2380447All the rusty stuff I cut out
ID:	2380449Everything cut and tacked. 4 hours of welding ahead of me!
ID:	2380451After all the top welding done. 3 2lb spools threw the welder
ID:	2380453Ok with that done tail gate back on and will flip the bed up when I have time.
ID:	2380455Lets mock that hitch up
ID:	2380457Alright rain storms stopped. Lets try out yannys new toy errr i mean attchment
ID:	2380459Didn't fold up yet anyhow
ID:	2380463Yanny is strong like bull. I don't know what I would do with out this little yanmar now.
ID:	2380465Ding ding lets weld the bottom now yahhhhhh
ID:	2380467Hitch bolted on and all holes drilled
ID:	2380469Hitch and new tips
ID:	2380473Pressure washed the frame. Not bad for 11 year old paint job me and grandpa did
ID:	23804832 of 3 things grandpa gave me that will never go anywhere
ID:	2380485Bumper bolted on and extra metal cut off
ID:	2380487Reason for posting is a big thing was scored. A set of 31x10.50x15 tsl radial super swampers for 400. On chevy 6 bolt rims. But can resell those
ID:	2380489Almost brand new
ID:	2380491 These are gonna make it look awesome!
ID:	2380493Next to worn 33's there about the same height Thought I did really good there.
Next steps are bed liner the bed top and bottom. And paint the frame. Then fuel and brake lines.
Post some vids later
Steven Turcheck
1944 WWII L
48 L grw's
1950's Bready
48 Willy's CJ 2A
2007 F250 Big White
2010 Sc2450 yanmar
post #33 of 36 Old 07-30-2019, 12:10 AM Thread Starter
Gravely1964
ID:	2388643 Ok to new tips, bumper bolted on
ID:	2388645Bottom bed lined
ID:	2388647Bed flipped down
ID:	2388649Bronco I need your rims back
ID:	2388651Bed lined top
ID:	2388653Realized mounting tabs for passenger head light were broke so new shiney head lights
ID:	2388659 Looking great.
ID:	2388661Deathly needed air filter, also changed fuel filter
ID:	2388663Front shocks in, changed all rubber flex lines along with rear brake shoes. Also while checking over in this step found 2 issues. RR axle seal leaking. Just great great axles need to come out. And LF upper ball joint needs changed. UGH bought parts and will get to it here at some point
ID:	2388665 31x10.50 vs worn 33x12.50 are pretty close height wise
ID:	2388669Painted rims black and super swamps look amazeing
ID:	2388673Put together enough to drive it to company party and see what happens. Other than obvious shake from tires not being balanced yet at 55. And ball joint, axle seal and power steering box seal. My only issue was the drives side pipe broke clean off at the muffler. UGH gonna be spending more money there I guess. And when I do the ball joint im gonna put on both new front rotors.
ID:	2388675Objective A complete now tires back on the bronco that use to be on it.
ID:	2388677Re falling in love with it again too
ID:	2388679The body is just so rough on the bronco. Believe me I've thought about fixing it too many times!
So for the moment major wrap on the Little mule project. Will pick away at above noted things and will add vid links here another night
Steven Turcheck
1944 WWII L
48 L grw's
1950's Bready
48 Willy's CJ 2A
2007 F250 Big White
2010 Sc2450 yanmar
post #34 of 36 Old 07-30-2019, 12:57 PM
If its a 4x4 you may as well do all 4 ball joints while its apart..beats taking it all apart again in a short time later to do them..they all are probably worn ..
Tractor-Holic is offline
post #35 of 36 Old 07-30-2019, 09:12 PM
WrongDoug's Avatar
Very nice! That was a ton of welding on that old bed. Kudos for not giving up on it. I love that diff cover and the 8.8 is a very reliable rear axle. I still have my 95 F150. I patched up the frame and replaced all the rusty metal on it, and repainted the whole truck. I ended up replacing the entire bed as mine was in similar shape as yours but my cab floor and rear inner cab corners were the worst parts. I try to avoid driving it in the winter now and I had it undercoated with Fluid Film which really seems to be a great product for corrosion prevention, I'd highly recommend it.
Sorry for the hijack!
Joe in PA
"What you talking about Willis, that him!" -Mr. Chow
WrongDoug is offline
post #36 of 36 Old 07-31-2019, 12:28 AM Thread Starter
Gravely1964
Attachment 2388757
Looks great! I was greatly considering a whole other bed idea, but welding wire was cheaper. With my fairly tight budget Im doing the best I can do with limited money more or less.
Tractors and tractor shows are gonna be very hot and heavy here next 2 months and time will be limited too then. So will be very slow progress from here out
Steven Turcheck
1944 WWII L
48 L grw's
1950's Bready
48 Willy's CJ 2A
2007 F250 Big White
2010 Sc2450 yanmar
