detroit diesel - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Trucks 2 Wheel Drive , 4 Wheel Drive, Big or Small
post #1 of 8 Unread 05-13-2019, 01:35 AM Thread Starter
forkz
forkz's Avatar
detroit diesel
country in her soul but she loves to rock n roll charlie daniels
forkz is offline
post #2 of 8 Unread 05-13-2019, 10:58 AM
Re: detroit diesel
They have yet to build a better sounding engine than the Detroit Diesel 2 cycles in my opinion..
This one is one of my favorites...
Tractor-Holic is offline
post #3 of 8 Unread 05-13-2019, 12:49 PM
Senior MTF Pollster
Austen's Avatar
Re: detroit diesel
https://www.youtube.com/watch?v=gWrg3cFod7Q
If only they made the kind of power to match the sound they produce...
Bolens HDT1000 #11- Coming eventually!
1977 Economy Tractor
Hydraulic lift conversion
24" model front king pins
48" Belly mower
32" tiller
3pt hitch
”What joy for those whose strength comes from the Lord." - Psalm 84:5
Austen is offline
post #4 of 8 Unread 05-13-2019, 08:37 PM
JohnW's Avatar
Re: detroit diesel
Oh, they make the power... but only if you keep em' wound tighter than a fiddle. Not an engine made to be babied or lugged.
IF you really want to see the power one has, be on one that is a runaway and the emergency shutdown has been disconnected.
Logic is most useful. If only more humans would learn it and embrace it.
JohnW is offline
post #5 of 8 Unread 05-13-2019, 10:12 PM
tdipaul's Avatar
Re: detroit diesel
Spot-on assessment!
It's a great engine to wow all the youngsters at the truck show. A true aural delight.
But to drive one for work was pretty scary. There were rules to driving an old DD...
DD Rule #1: Never let off of full throttle. EVER. Its a requirement that's eerily similar to riding an 80 or 125cc 2 stroke motocross bike, up a cliff.
Rule #2: Never go below 1600rpm if under any kind of load. The 6-71 5+2 '80 Brigadier I drove did not tolerate lugging AT ALL and would protest by overheating in seconds. Seriously, in like only 5 seconds!
Rule #3: Plan uphills in advance. With zero torque rise to pull you out meant hitting the beginning of a hill at full tilt or else there was no chance. (due to what happens in #2)
Rule #4: Make sure the 4 ways were functioning. Top speed of that loaded rig (consisting of a full 7 yard dump body and a 580B Case behind it) was 48-52 mph flat out on the NJ Turnpike. Flashers on for the entire trip! Back then (early 90's) I think the 425 Cat was top dog, and as they blew by me I dreamed about doing 68
rule #5: Carry spare gallons of oil. Not quarts, but gallons.
All that got tiring real quick.
The 300 Macks of the day were so much better. Still see many of them on the road today, which tells you something.
But the DD's are cool to show off now I guess. So unique, and full of character the trucks of today just dont have.
Simplicity GTH20
Craftsman FF20
Scag SW61
Wright Stander B
Toro 5/24 SB
Stihl BR700
Stihl FS94
tdipaul is online now
post #6 of 8 Unread 05-13-2019, 10:25 PM
Steve Urquell's Avatar
When I was in diesel school we had a 6V53 on a test stand to set the overhead on. It would howl like a banshee. Fun lil motor to thumb the rack on just to hear it.
Steve Urquell is offline
post #7 of 8 Unread 05-13-2019, 10:29 PM
tdipaul's Avatar
Re: detroit diesel
Try holding that rack open for 90 minutes at a clip. Its just insanity
Simplicity GTH20
Craftsman FF20
Scag SW61
Wright Stander B
Toro 5/24 SB
Stihl BR700
Stihl FS94
post #8 of 8 Unread 05-14-2019, 12:31 PM
Senior MTF Pollster
Austen's Avatar
Talking Re: detroit diesel
Originally Posted by tdipaul View Post
Spot-on assessment!
Well put! You said it. I think owning a piece of equipment that has one would be great fun from a hobbyist perspective today however -depending on the type of application- I would probably choose an alternative power plant to use in my profession on a daily basis for work.
You are 100% correct about their power bands and gave a good example. The comparison really is like a small 2-stroke dirt bike where there's no power down low, then all of a sudden you get a similar light switch-like effect and you get power but only for a short window of time up at the top. Because of the lack of low end torque, they were really not all that efficient to run in a manual trans config as you would have to slowly wait for the torque to build up again between each shift; it's part of the reason why you see old dump trucks and semi tractors that have these engines always going so slow (in particular, city driving situations) because they lose quite a bit steam and MPHs between gears- especially on hills. Like you said, you really had to prepare and work around the power band because if you missed a shift or didn't climb into that power band soon enough before a hill, things were not going to be looking up for you. They're not at all like an inline-6 4 stroke such as a CAT or Cummins where they make massive amounts of torque as soon as you let out the clutch and practically drive themselves in comparison. It's part of the reason why a lot of cases drivers would get worn out from driving them because it was like a marathon operating them combined with the noise; you never really got a break. I think they work more efficiently in applications like tour buses (or big gen sets and boats for that matter) were they can run at sustained RPMs on the freeway near or in their power bands with an automatic transmission. In this type of scenario, their power band type works great and is always accessible but in a dump truck for example where a lot of the driving may be around town and you need low end torque.... I'll take an inline 4-stroke diesel variant, yes please.
The old adage for these was "slam the door on your finger" to get you in the right mood so that you could then "drive it like you stole it."
You really felt like you were beating on them but that was the only way to drive/operate them.
They were also just as slow in heavy equipment too that had them. I ran a Clark Michigan loader with a 6-71 and it was always an effort just to get the machine rolling from a stop. You'd hit the pedal, RPMs would rise and nothing would happen, press the pedal a lot more this time and then finally you'd begin moving at a crawl and you'd think you're already half way through the RPM range by the noise output. When you'd come up to a pile to grab a load you were always standing on the pedal for all it was worth. If ground was loose enough, you might even break a tire loose going into the pile only it would spin verrrry verrrry slowly. If you were driving it on the street and put it into the high gears it would actually get up to a pretty good clip but that lack of any low end torque for actual dirt moving work on a job site meant lots of noise and very little speed, especially, again, to get moving or while going into a pile. I remember an operator of the same machine telling me about how one time somebody who could hear the machine from a distance complained and said "the workers are speeding around the job site!" gauging by the noise output when it reality that was not the case at all.
48" Belly mower
32" tiller
3pt hitch
Austen is offline
Diesel Fuel Additives CCMoe Backyard Round Table - L & G Tractor Related Topics 13 11-03-2018 11:55 PM
Diesel stains on plastic parts marksandsoy John Deere 0 07-23-2018 01:24 AM
455 Leaking Diesel k91 John Deere Forum 4 02-09-2013 03:03 PM
Thinking About Making A Diesel Version Of The Homemade Tractor 98Murray Home Made Tractors, Implements and Accessories 2 01-31-2013 06:00 PM
Diesel fuel in crankcase question?? dreher The Barn 4 11-11-2012 05:41 PM
