Project: 1962 Willys Pickup - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Trucks 2 Wheel Drive , 4 Wheel Drive, Big or Small
post #1 of 188 Old 09-24-2018, 10:59 AM Thread Starter
BEWARE...I'm a Cranker!
tiretrx's Avatar
And awaaaay we go! Again. As some know, I recently picked up this '62 Willys p/u. Bought it on the BaT auction site, and had it shipped from the great state of North Carolina. The truck visually is a classic 30 footer, paint/finish wise. Fortunately, it was well represented in the auction pics and there were no real surprises. The reason I liked this particular truck was the engine, features and chassis/body integrity. The engine is the L head, 6-226, Continental straight six "Super Hurricane". I believe as '62 was the last year of production, that this rated @ 115hp and 190 fpt. IMO, the engine is a legend. And this one purrs. The features are, this is a FWD version, with the very desirable Warn over-drive. You can split shift it with the stock 3spd. for a total of 6 spds. or use OD, as I mostly have, as an effective 4th gear on the highway, or when breaking 35 or 40mph. It is something I wouldn't want to live without. Lastly, the tin/steel on this one is super solid all around. Very little filler, no rot/holes etc. anywhere. It lived in SoCal the vast majority of it's life. In short, close up aesthetics aside, this puppy has great bones. Appearance is overrated anyway
This weekend I did a pretty thorough going over, and assessed things. Made a punch list. Lots of little things. Mostly easy, cheap fixes.
At 30 feet.
Mechanically, the only thing that needed immediate attention was the brakes, and the driver's front hub had a fair amount of end play. The brakes didn't firm up until 3/4's to the floor. Upon inspection the master cylinder was basically devoid of fluid. Several toppings and and three rounds of old school bleeding led to nice, firm brake pressure a little north of halfway. And happy to report.....no leaks.
The hub end play was simply poor installation of the spindle jam nuts. Tightened about a turn and a half, locked together, fixed. This however led us to pull both hubs and inspect the inners and the brakes themselves, as we weren't real confident in the prior work. Checked out well, buttoned up. Wish they all worked out that well.
Aesthetically, I thought we'd spruce up the engine and bay area. I want to see as much motor as I can. Needs uncluttering, cleaning, wires/cables re-routed and shortened.
Here's what we got. Way too much spaghetti. Shorten, and reroute, wiring to make a cleaner look. Too many colors. Some orange, not all, is going.
Other issues.
It's dirty. Here's a fender well with spot I cleaned. This finish is actually pretty nice. Time to see it again.
This is just wrong in so many ways. Nuff said.
And now for the one that's really driving me crazy. The whole alternator was attached by a single 1/4" bolt to the engine. And the alternator was super sloppy in the bracket. This was the prior solution.........a slab of orange steel bolted to the head. Ummm, bye-bye.
More pics and progress coming.
.....just call me Ellis
Folks say I'm lazy, drunk and stupid. Well, I got news for them......they're only 2/3 right.
tiretrx is online now
post #2 of 188 Old 09-24-2018, 11:08 AM
MTF CSI
poncho62's Avatar
Re: Project: 1962 Willys Pickup
Cool truck.....I watch the TV show Mountain Men. One of them has a Jeep truck like that, would love to find something like that just to putt around in.
The alternator looks like a GM 1 wire, great alternator. It just needs a stronger mount on the bottom and you could lose that diagonal piece.
Ford LGT100
Ford LGT125
Ford LGT165
John Deere STX38
poncho62 is offline
post #3 of 188 Old 09-24-2018, 11:41 AM
Signing on for this one also Ellis. Nice find and I'm confident you will do it justice
Just call me Larry
2012 JD X729, 62C deck, 45 loader, 54" front blade, Quick Hitch, Cat 1 3PH, Heavy Hitch. Heavy Hitch Forks. Heavy Hitch Sub Soil Ripper. Heavy Hitch sleeve hitch. 8 JD suitcase weights. 2-50# cast rear wheel weights. 4 home made 63# wheel weights. Front fork frame for 45 loader.
197? Economy Power King Model 1614 with tandem transmissions, hydraulics and 3PH and 48" mower deck.
Thread for 110 RF build https://www.mytractorforum.com/12-john-deere-forum/287161-66-110-rf-rebuild.html
1966 JD 110 RF, 580 TracVac, Home built log splitter, Stihl MS260 Pro Chain Saw,
Stihl BG85 Leaf Blower, Echo GT2400 Weed Whacker, 20KW Generac standby generator.
KWDAILYD is online now
post #4 of 188 Old 09-24-2018, 12:05 PM
10,000 +posts!
Ericjr16's Avatar
Sweet Ellis! Ready with popcorn to see the progress!
Challenge Met
John Deere 180 yard tug
John Deere LX172 with bagger
1997 John Deere 345 with snowthrower
1971 Bolens 1256 snow caster
1967 Sears Suburban SS10
Many more!! changing by the day!!
John 3:16 Psalm 28:7
"Complain and remain, praise and be raised!
Ericjr16 is online now
post #5 of 188 Old 09-24-2018, 12:29 PM
Hahn Star
MikMan48's Avatar
Climbing aboard the next Ellis thread! Should be another good one!
Sent from my SM-A520W using Tapatalk
Challenge Met
Have you met "The Fahn" yet?
https://www.mytractorforum.com/189-o...meet-fahn.html
MikMan48 is offline
post #6 of 188 Old 09-24-2018, 12:44 PM
I'll never get to 10,000
lt230s's Avatar
Looks like a nice project and not too much to get it right. Will be following.
John
'66 WH lawn Ranger (in progress-still),
'67 JD 112
'72 JD 110 w/ 39 mower, 43 blade, 37A blower
'73 JD 140 w/ deck
'86(?) Kubota L2550 w/ FEL
'69 JD 112H waiting patiently to come back to life
lt230s is offline
post #7 of 188 Old 09-24-2018, 12:58 PM
Senior MTF Pollster
Austen's Avatar
Thatíll be a fun driver for you! Glad ya got it and all the best with it.
Bolens HDT1000 #11- Coming eventually!
1977 Economy Tractor
Hydraulic lift conversion
24" model front king pins
48" Belly mower
32" tiller
3pt hitch
"So I say to you, ask, and it will be given to you; seek, and you will find; knock, and it will be opened to you." - Luke 11:9
Austen is offline
post #8 of 188 Old 09-24-2018, 03:12 PM
tracktortag's Avatar
You, and Mike are off to a great start. It seems like you got the brake situation under control in no time. The other things you mentioned seem like they are things that you will also correct quickly.
It will be a lot of fun driving it around, even for your wife. Lots of fall activities coming up that you could drive it to.., early, before the crowds show up.
Dave
tracktortag is offline
post #9 of 188 Old 09-24-2018, 03:25 PM
MARK (LI)'s Avatar
Talking Re: Project: 1962 Willys Pickup
My brother and I chipped in and bought our first car in 1967...it was a 1960 CJ3a...we both learned a lot about basic automotive work...you could fix anything on it with a screwdriver, an adjustable crescent wrench and a pair of water pump pliers ( now called channel locks)...
I would love to see more pictures as you go forward with it...I would love to get another Willys...either an Overland or a Jeepster....but I did something about 30 years ago that prevents me from being able to do that now...I got married
MARK (LI) is offline
post #10 of 188 Old 09-24-2018, 05:13 PM
We all make mistakes...
Dave
post #11 of 188 Old 09-24-2018, 05:50 PM
MARK (LI)'s Avatar
Thank you for being so understanding
post #12 of 188 Old 09-24-2018, 06:03 PM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
Gotta love it !
I had a '55 p/u identical but red. Drove it to high school and used to park it in with all the guys rods. To me it was the coolest vehicle there. For some reason I brush painted it dark blue later on.
Same flat head 6 and FWD, had Warn Hubs and bench seat.
Converted it from 6v to 12 using the generator from a '55 Chev and a Dodge ballast resistor. The starter was never an issue on 12v.
Installed the complete heater assembly from the '55 Chev Belair but the vaccum wipers were always a bummer.
Don't even know if I have any pics as that was almost before cameras.
Wish I still had it ! Please keep the pics coming as I can't get enough of it.
Larry ( in Southern Ontario )
Larry LGT 165 is offline
post #13 of 188 Old 09-24-2018, 06:49 PM Thread Starter
tiretrx's Avatar
New mount is in the works. It is indeed a GM alternator.
Thanks guys, I'm glad to hear you're come along for the ride!
Can't wait. Should be back in action by this weekend.
Originally Posted by Larry LGT 165 View Post
Gotta love it !
Thanks Mark and Larry. Even in the few times we've had it out, everyone, it would seem, is stirred to memories, or thumbs upping, waving or just plain smiling. I've had a couple cool rides, but none ever got this level of reaction.
You know guys, I'm the last guy to encourage folks to chase a dream and buy something really cool that the day they get it, they'll probably remember it as the happiest day of their life, because hey, life's short, and you can buy those quonset garages for like 180 bucks on Amazon if you didn't have enough storage for it, but as I said it's just not something I do.
post #14 of 188 Old 09-24-2018, 07:11 PM
Ellis, we had a used car dealer's licence in the family for years so I have bought, driven and then resold a lot of different vehicles over the years.
My '55 Willy's Pick Up was without a doubt, and still is my most favorite vehicle of all time.... and I never even got lucky in it.
post #15 of 188 Old 09-24-2018, 07:34 PM
JohnW's Avatar
Those old Continental straight six engines are tough, the fours were darn good as well and will run forever if given any care at all. Many, many pieces of our old construction equipment had those engines, I do not think there is any old engine anywhere that is as smooth at all rpm's as the old Continentals.
Logic is most useful. If only more humans would learn it and embrace it.
JohnW is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
