MTD 2 stage - wheels are locked up - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 02-26-2019, 01:58 PM Thread Starter
h2ofwlr's Avatar
Its' a '04 era 2 stage snowblower Ranch King is the brand, 1028, H or K series made by MTD.
The actual wheels will not turn. It does not matter where the shift selector is at - forward or reverse - the wheels will not turn at all. Even when it's off, and you drag the machine - the wheels will not turn.
I took the bottom cover off, nothing obvious that I can see, the gear teeth seem to be meshed up like they should. Photo attached.
So does anyone have any insight of what is wrong? And more importantly - how to fix it?
John Deere 345 & Honda self propelled walk behind.
JD LT190 sold
JD LX188 sold
JD LX176 sold
God, help me be the man that my dog thinks I am. RIP Buzz 2005-2018
h2ofwlr is offline
post #2 of 3 Old 02-26-2019, 07:51 PM Thread Starter
h2ofwlr's Avatar
Re: MTD 2 stage - wheels are locked up
The model # is: 31AE6LHG705 If that helps
JD LT190 sold
JD LX188 sold
JD LX176 sold
h2ofwlr is offline
post #3 of 3 Old 02-27-2019, 03:37 AM
Gravely 2-wheeler
Is the rubber friction wheel lifted off the drive plate with the hand grip released? If not, it may be a linkage issue. See if the drive plate will turn by by hand. If you remove the three bolts from the friction wheel so it is completely loose on the shaft you can separate gear and hex shaft bearing issues from drive and belt issues. Are all of the gears meshing with no debris in the teeth? I once had axle bushings and the frame hex holes so worn that the gears jammed. The wheels wouldn't turn fwd or rev.
Paul L
Gravelys: 1950 L, 1954 L, 1968 Comm 10A, 1969 C8, 1971 C8, 1984 5665
1967 430, 1969 432, 1980 8122
Craftsman 917.270670
PaulL is offline
Lawnboy Replacement Plastic Wheels Smooth Thread Yard Nazi Walk Behind Mowers 5 10-19-2018 11:37 AM
This deserves itís own thread, MTD advertises accessories but they donít ship them... Joe_K Cub Cadet Forum 27 10-16-2018 08:39 PM
Rear wheels locked up hydrodostat ba_50 MTD 25 07-08-2018 09:03 PM
Single stage or dual stage Ariens GT snowblower Curt L. Lawn and Garden Tractor Accessories 3 06-06-2018 02:48 PM
Education needed on Mower Deck Wheels SteveKoz John Deere Forum 43 02-03-2018 08:54 AM
