Why walk when you can ride ?.. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 01-13-2019, 07:41 PM Thread Starter
Hmmm ..thought this was pretty clever!..
Not sure how the "transmission" will like hauling a person around on top of propelling the snowblower though...if it has the rubber friction disc drive,it wont last long..
Tractor-Holic is offline
post #2 of 9 Old 01-13-2019, 08:04 PM
Re: Why walk when you can ride ?..
I must say I am impressed with how well that is working... BUT as you mentioned a friction disk won't hold up. Very cool idea though!
Mrlunchbox is offline
post #3 of 9 Old 01-13-2019, 10:42 PM
tracktortag's Avatar
I'll bet he'd like this.
Dave
tracktortag is offline
post #4 of 9 Old 01-13-2019, 11:06 PM
I love it, and think as long as he stays on that nice smooth drive, the disk will be OK,
and I might have put a little larger wheels on it but that's all.
It may not last as long as without but it's cheap and easy to change.
Dan
Bolens / TroyBilt GTX20
MF / Snapper 1855
Bolens / Iseki G152
JD 116 - sold
DL-North is offline
post #5 of 9 Old 01-14-2019, 09:21 AM
Joe
micah68kj's Avatar
Location: Pa. Transplant from the the great state of Wv.
I had a Lawn Boy RER mower back in the early 80's, that had the disc drive and it performed very well for years. I don't see why it wouldn't work with this setup.
Joe
micah68kj is offline
post #6 of 9 Old 01-14-2019, 12:21 PM Thread Starter
It will work,the video proves that...just the lifespan of a disc drive might be shortened considerably with the extra load on it..
The sulky idea has been around for decades--Gravely used them long before I was born..a neighbor next door to me in my home town made one for a self propelled reel mower so he could ride instead of walking behind it--I remember he hammered nails into the solid rubber tires so it would have enough traction to pull him behind it!..
I've had a Snapper RER that had the friction disc drive setup and was surprised how good it worked--but it had a much bigger disc than a snowblower...and if it got wet or oil on it,it slipped badly..once the rubber wears down or gets wet or oily,they fail to propel it well enough..not the ideal setup,but it works well enough for lighter duty use..
I saw a home made wood hauler a guy built using an old disc drive rear engine rider mower--he made a large triangle shaped platform big enough to hold a cord of wood out of plywood and 2x4 studs and he used only the rear half of the rider to propel it by bolting it to the rear of the platform,and he put the front half with the steering axle & steering wheel up front at the "point" of the triangle..it was only like 6" off the ground too..
When my friend and I saw him loading at least a cord of firewood on it,we laughed,said "that thing will never budge that load--or get stuck instantly"...
Our jaws dropped when he got in the seat and put it in gear,and it took off like it was empty!--it even pulled the load up a decent grade that was pretty muddy and slick without getting stuck too..he said he used it for several years too!..
He used a grinder to make grooves in the drive wheel so the friction disc wouldn't slip under heavy load..and put a stronger spring on the friction disc so it had more pressure against the drive wheel..he said the hardest part of making it was figuring out how to make linkages for the shifter and clutch pedal..
I love seeing things people have invented like this on YouTube..some are quite ingenious--others are good for a laugh when it is a miserable "fail"!..
post #7 of 9 Old 01-14-2019, 01:50 PM
Senior MTF Pollster
Austen's Avatar
Clever sulky setup!
1985 Bolens HDT 1000 #11
1977 Economy Powerking Tractor
"So I say to you, ask, and it will be given to you; seek, and you will find; knock, and it will be opened to you." - Luke 11:9
Austen is offline
post #8 of 9 Old 01-14-2019, 02:23 PM
Parts collector
mopar65pa's Avatar
Now that's thinking.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #9 of 9 Old 01-14-2019, 04:41 PM
yyy
Nice idea to build one for single sb.
yyy is offline
