Millermatic 211, ESAB Rebel or Lincoln 210 MP - Page 4 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #46 of 59 Old 04-30-2016, 09:09 AM
MI GT's Avatar
Re: Millermatic 211, ESAB Rebel or Lincoln 210 MP
20cfh should be good on your low pressure. Maybe a bit higher if outside or if you have a draft in the shop.
Inconsistent weld can come from a lot of things, how fast you are moving, try to keep the same speed, wire stick out, try to maintain 1/2" or less. To long the wire will wander. Wire speed, temp can also do it. Sometimes on lighter metal settings to the lower end may be better.
2014 1025R 7 Iron deck auto connect& Mulch kit,with Gator blades.
H120 FEL 53" bucket and Ken's bolt on hooks.
RB2060 60" rear blade
I-Match
Ballast box w/ 600# pea stone
Super Heavy Hitch
8 suitcase weights
2 75# Starter wheel weights and 4 50# add ons
25 gal. tractor mounted sprayer
42" Brinley sweeper
Stihl 026 Pro saw
Stihl blowers and trimmers
It's a good day when the police don't come
to the door and I didn't have to hide any bodies.
MI GT is offline
post #47 of 59 Old 04-30-2016, 11:49 AM Thread Starter
Rebuilding my First JD GT
N2 Tractors's Avatar
Thank you MI GT. The gas was set at about 30 cfh . The welder itself changes the Amps and Volts while I'm welding. They fluctuate up and down. When the volts drop off is when I get the inconsistent welds. Basically I am listening to the buzz and it gets very choppy almost like the welder is turning off and on multiple times like I have a bad ground or something. The ground clamp and cable are not hot so I don't think bad ground is the issue. I even tried to put the welder in Manual mode to set my own perimeters and the same thing the amps and volts fluctuate up and down. So far this is only happening on 1/8" steel. When I practice on 1/4" the buzz and welds stay very consistent with a nice frying bacon sound.
I'm pretty sure I'm staying consistent with my stick-out depth from material and travel speed. Only thing I have noticed is my angle is not always the same but I can't see why the welder would be changing the amps and volts because of that.
I'll get some pictures of my welds and show you what I'm talking about.
this is quoted from an ESAB REP on the Welderweb forum.
Some people were asking about the functionality of the machine, so I put some of the main features below.
Overall
User Manual Built Into Machine
Wear Parts List Built in Machine for Mig Gun and Feed Roll
Built in parameter guide for each process
4 memory positions for each process
110v/230v
240 amps
5 handle design for portability ease (pulling in and out of truck) handles also act as a bumper
4.3" Screen (larger than any machine in its class)
40lbs
8" or 4" spools
Tweco Fusion gun (tweco connection), Tweco Ground Clamp, Electrode Holder, Tig Torch, and Victor Regulator
3 year warranty
100 day 100% satisfaction guarantee
Mig
Smart Mig- set wire diameter and plate thickness, the machine sets itself and adapts to how you weld. You change your stick out, the machine changes for you to keep you dialed in. This is something that we had on the Caddymig 200i called Qset. Qset was developed and improved further and the name changed to Smart Mig or SMig
Voltage Trim on SMig- welder hotter or colder based on SMig settings
Regular Mig-- set wfs and voltage
Inductance Control
Pre and Post Gas Flow
Burn Back Control
Spot Timer
Trigger Lock
FC Wire Selector
4 memory positions
Tweco Mig Gun Connection
Spool Gun Option
Stick
you can whip 6010 electrodes
6010/6011 electrode selector for fine tuned settings
Arc Force Control
Hot Start
4 memory position
Tig
DC Lift Tig
Slope Up/Down
Trigger Lock
5-240 amps on 230v
Foot Control Option with pin connector
4 memory positions
Rebel
End Quote :
So it may be me changing my stick-out depth but that don't explain why I have very consistent welds on 1/4" then weld 1/8" and it's all over the place.
Edit: I just registered for FABTECH 2016 in Las Vegas
Running:
73 140 H1, 75 214, 79 JD 317 Onan P218G, 19xx Wheel Horse D250 550 Arc FEL ARPS Box blade
Not Running:
69 JD 140 H3, 75 JD 300, 79 JD 317 Kohler KT17QS II, 83 JD 420, late 80s JD 316, 90 JD 316,
2x 300 series 3PH, Johnson Workhorse 12, Gannon Earthcavator 32, 2x JD 54 4way blade, 2x JD 33 Tiller + 8" Extension, JD 38 Brass tag mower deck, JD 48 mower deck, JD #30 Hydro Tiller, Disks, Plow, ARPS Angling Backblade,
N2 Tractors is online now
post #48 of 59 Old 04-30-2016, 02:18 PM Thread Starter
This is about 2 hours of time playing with smig and mig settings on 1/8".
ID:	1663394   Click image for larger version
post #49 of 59 Old 04-30-2016, 02:21 PM Thread Starter
Then after all the 1/8" I decided to try 1/4" in smig mode. Boom nice consistent beeds.
ID:	1663418   Click image for larger version
post #50 of 59 Old 04-30-2016, 05:22 PM
MI GT's Avatar
Shouldn't make a difference, but what dia wire are you using? Maybe the smart mode doesn't like your wire for 1/8".
Second picture of the 1/8" doesn't look to bad. Try some butt welds ,lap welds and filet welds and see what happens.
There's a thing in welding to help you get better it's called practice. I'm sure it will all fall together, and you'll be like duh!
You're doing good for just starting out.
Jim
I-Match
Super Heavy Hitch
8 suitcase weights
42" Brinley sweeper
Stihl 026 Pro saw
MI GT is offline
post #51 of 59 Old 04-30-2016, 07:29 PM Thread Starter
I took sheet metal and welding shop in high school so I have basic fundamentals with oxy acetylene and arc welding
post #52 of 59 Old 04-30-2016, 08:56 PM Thread Starter
Oh I'm using the .030 wire
post #53 of 59 Old 05-01-2016, 04:48 AM Thread Starter
OK it's official, this welder rocks when used as intended. I was doing everything correctly except for using adequate 1/8" material. I was using old sitting outside rusting away 1/8" x 4" x 4" square tubing thinking I could grind the rust off and lay down some nice beads. Boy was I wrong.
So any way i decided after picking up a 3 drawer mini file cabinet on CL for next to nothing intending to use as the base structure in the design of a welding cart I'm conjuring up in my head to stop by home Depot for a few things. I ended up getting a Milwaukee portaband saw and some clean 1 1/4" x 1/8" x 36" to test my theory on why the welder was so I'll behaved last night on 1/8" material.
Am I ever glad I did. I proved my theory right and established 100% confidence that I picked the right machine for my intended uses.
Figured I'd share my makeshift temporary welding cart and table. Oh and the Hobart 10# spool and channel lock mig pliers were waiting for me when I got home from retrieving the file cabinet and home Depot items
Last is a few different types of welds I tried after cutting up six 1 1/4" x 1/8" x 2" coupons using the new band saw.
ID:	1664642   Click image for larger version
ID:	1664650   Click image for larger version
ID:	1664658   Click image for larger version
ID:	1664674   Click image for larger version
ID:	1664682   Click image for larger version
ID:	1664690   Click image for larger version
ID:	1664706   Click image for larger version
ID:	1664714   Click image for larger version
ID:	1664722   Click image for larger version
ID:	1664738   Click image for larger version
ID:	1664746   Click image for larger version
ID:	1664754   Click image for larger version
ID:	1664770   Click image for larger version
ID:	1664778   Click image for larger version
ID:	1664786   Click image for larger version
ID:	1664802   Click image for larger version
post #54 of 59 Old 05-01-2016, 09:16 AM
MI GT's Avatar
There ya go, easy resolution.
I-Match
Super Heavy Hitch
8 suitcase weights
42" Brinley sweeper
Stihl 026 Pro saw
MI GT is offline
post #55 of 59 Old 05-02-2016, 01:28 AM Thread Starter
I'm glad it was an easy solution to the problem.
Tonight I used the new saw to cut 2 x 18" sections from a 5'6" barb wire post and added those to two other identical posts to give me 2 x 7' posts for use with an apple tree we planted in the front yard that was developing a lean to one side.
post #56 of 59 Old 05-02-2016, 01:33 AM Thread Starter
Results.
ID:	1666362   Click image for larger version
ID:	1666378   Click image for larger version
ID:	1666386   Click image for larger version
ID:	1666410   Click image for larger version
post #57 of 59 Old 05-05-2016, 01:41 AM Thread Starter
I got started on the welding cart. I would start a new thread but most of the info relating to why I'm making the cart is already in this thread. .
ID:	1669442   Click image for larger version
ID:	1669450   Click image for larger version
ID:	1669458   Click image for larger version
post #58 of 59 Old 05-07-2016, 01:02 PM Thread Starter
I made some progress the other night. I'm finding it difficult to make precise cuts to length as well as square.
ID:	1671737   Click image for larger version
ID:	1671745   Click image for larger version
ID:	1671753   Click image for larger version
ID:	1671769   Click image for larger version
ID:	1671777   Click image for larger version
ID:	1671785   Click image for larger version
ID:	1671801   Click image for larger version
ID:	1671809   Click image for larger version
ID:	1671817   Click image for larger version
ID:	1671833   Click image for larger version
post #59 of 59 Old 02-02-2019, 01:51 AM Thread Starter
Looking back to this thread. Wow, it's been a minute and my welding cart still never got finished. I moved on to other things and never got back to finishing this cart :/
As far as my review on the machine. It did have some problems that I was able to work through by making an adjustment while in smig mode. Basically if I tried to use the same settings with out making any changes after shutting the machine down and powering back on the machine would weld like doggy do do with all kinds of inconsistencies unless I changed the parameters from the last setting either down or up then back to where I need them. I was able to work with through it for a few years with the little bit of welding I do but my warranty period was about up so I decided I better get it checked out. I reached out to a member on another forum that repairs welders for a living with in a 30 min drive from me and he suggested I have the software updated. I did and have been welding with it smooth sailing ever since.
I love this machine.... It makes welding fun.
Running:
Not Running:
