Lets see them welds!!! - Page 120 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1786 of 1794 Old 07-30-2016, 06:02 PM
Rebuilding my First JD GT
N2 Tractors's Avatar
Re: Lets see them welds!!!
I just paid $64.00 shipped for a box of Lincoln Excalibur 1/8 in. x 14 in. 7018-A1 MR Electrode 50 lb. I'm sure it'll last me the next 5 or more years.
Running:
73 140 H1, 75 214, 79 JD 317 Onan P218G, 19xx Wheel Horse D250 550 Arc FEL ARPS Box blade
Not Running:
69 JD 140 H3, 75 JD 300, 79 JD 317 Kohler KT17QS II, 83 JD 420, late 80s JD 316, 90 JD 316,
2x 300 series 3PH, Johnson Workhorse 12, Gannon Earthcavator 32, 2x JD 54 4way blade, 2x JD 33 Tiller + 8" Extension, JD 38 Brass tag mower deck, JD 48 mower deck, JD #30 Hydro Tiller, Disks, Plow, ARPS Angling Backblade,
N2 Tractors is online now
post #1787 of 1794 Old 10-17-2016, 06:35 AM
Heyzipupyourfly's Avatar
A Lobster boat exhaust made of stainless SCH10.
everything was layed out and welded on the bench from measurements taken on the boat. original exhaust went out the turbo and straight up but the Capt wanted to move it to the port side gunwale to make more room to work.
The original, also was not serviceable. This one has 3 custom machined stainless flanges which allow removal for servicing of engine and the flexpipe.
installed a Bung for an EGT gauge which also doubled as a purge fitting during assembly.
Different boat but here is a water mixing manifold i built for a generator which was also stainless.
1986 Kubota B4200. 10hp PTO, Cat1 3PH
Simplicity 16Hp Hydro
Heyzipupyourfly is offline
post #1788 of 1794 Old 10-17-2016, 06:56 AM
SandDawg's Avatar
Very nice work!
SandDawg is offline
post #1789 of 1794 Old 12-15-2016, 10:31 PM
396 big block's Avatar
Welded a steel rod across for support , and beefed up the corners on 2 of the week spots where they snapped on one of my OTC cab brackets.
ID:	1852682   Click image for larger version
Marty 2012 John Deere X500, 1970 John Deere 120
1972 John Deere 140 Acts 10:34 34 Then Peter opened his mouth, and said, Of a truth I perceive that God is no respecter of persons:
396 big block is offline
post #1790 of 1794 Old 05-06-2017, 04:32 PM
This is a piece of 2" sch 40 iron pipe I just welded to the bottom (now top) of a propane tank being turned into a sandblaster. The welder is a Hobart Handler 210MVP running Hobart Flux core .030 E71T-11 with the welder set at 2 for the voltage and 20 for the feed rate on a 240volt circuit.
Any suggestions or pointers for improvement?
P.s. I am perfectly aware of the hazards of pressure vessels and propane tanks. This one was properly purged before beginning and will be hydro tested to 300 psi before being used as a blaster with a max working pressure of 100psi.
Sent from my SM-G930P using Tapatalk
Straick is offline
post #1791 of 1794 Old 05-08-2017, 11:16 PM
CowboyBob's Avatar
Practise your hand control. More steady hand and better weave.
CowboyBob is offline
post #1792 of 1794 Old 05-08-2017, 11:29 PM
CowboyBob's Avatar
Few things I've been working on.
Tractor hitch
Dozer seat
Miller DVI Mig welder
Miller AC/DC arc welder
Miller 165 tig welder
Miller 375 plasma cutter
post #1793 of 1794 Old 05-09-2017, 08:55 AM
Thank you, guess I'll need to grab some scrap pipe to practice on, flat, horizontal, and overhead pieces (no curve) I can do easy and have look good.
It did pass hydro, so all is good there. If I sounded defensive, it was because of what I saw(all these people saying how dangerous it is, which proper testing helps negate)when trying to find out how thick a propane cylinder end walls are.
Straick is offline
post #1794 of 1794 Old 10-09-2018, 05:29 PM Thread Starter
TE Writer!
IHcubguy's Avatar
Surprised to see this thread continued after my disappearance!!
I can honestly say I'm no longer a full time pipe welder after 19 years. I had my fill and cant stand the sight of pipe or fittings but still have the love for welding and fabrication, that'll be with me forever!! I started last year with a company that does mobile railcar maintenance are repair. I do though have a nice Miller w/ air pac combo on my work truck, still welding but only here and there.
Hopefully this thread isnt dead!!
IHcubguy is offline
