UNION CARBIDE HDA-200 How purge Gas & Water lines? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 08-03-2019, 09:46 PM Thread Starter
Well got this welder up and running is really nice and got Argon tank today [330 size] and waiting for my Oil to mix with water then will fire up Tig. Miller pump has bronze gears in it.
But I don,t see anything on these for purging gas & water cooling lines before welding? I have a manual but has topic on Post purging is all I see?
I don,t see how you can start welding before the gas and cooling is all threw the lines?
62, Diesel Mechanic, John deere rebuild,Welder, Wood worker, All in All HAndy
Durfman is offline
post #2 of 3 Old 08-10-2019, 07:35 PM Thread Starter
Re: UNION CARBIDE HDA-200 Gas & Water on all the time??
HI, Maybe you can help or point me in right direction? I finally got Argon and cooling fluid and fired it up today [tig part] and all seems to work ok BUT my water and gas are on all the time? If I shut off welder they go off but seems like the solenoids have juice all the time?
I checked the foot control and it is working ok--on and off for two wires going to solenoids. Maybe I thought has something to do with the post purge timer??
Durfman is offline
post #3 of 3 Old 08-11-2019, 07:22 PM Thread Starter
Well got it to work--shut off and on when suppose too--Cleaned the post-purge timmer seemed to do the trick,
One more question--I put one quart of solvable oil in 7 Gal of cooling water to lube the gears in the pump--Does that sound like enough??
Durfman is offline
