Well it finally happened!!! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 58 Old 06-07-2019, 04:49 PM Thread Starter
Still lovin' the 322!
PA318Guy's Avatar
I broke down today and bought a Mig welder, a Vulcan 140 which should meet my needs to do simple repairs rather than having the local welder take my money! And I get to learn a new skill too! First up will be some repair welds on my MacKissic Chipper which I messed up by hooking a chain around the feeder to help lift it on the 322....hmmm the metal there wasn't really as strong as I thought, or subconsciously I needed an excuse to get the welder. Absolutely an area out of my current skillset so I will likely be asking a lot of questions. I am watching a lot of youtube videos but I think this is one of those things that until you start burning metal you'll never really grasp properly.
Current Machine JD 322
PA318Guy is offline
post #2 of 58 Old 06-07-2019, 05:24 PM
Re: Well it finally happened!!!
ChuckE2009 has some pretty good welding videos on his channel on youtube. Plus, he also collects and repairs old tractors. Think he has 11 or 12 now. Also does reviews on tools and all kinds of build projects. It is really refreshing to see a young guy come up the way he has.
https://www.youtube.com/channel/UCJA...b5sg79yld7T3hA
Flaken is online now
post #3 of 58 Old 06-07-2019, 05:24 PM
not quins. but sextuplets
Whirly's Avatar
before u do anything read the instructions first.. get to know what happens when u makes mistakes.. do a lotta welds on scrap metal.. did u get tank of GAS.. or does it use flux- core wire
I bought one before I retired in 2011.. it has a GAS tank.. the tank is now about empty..
more later..
the round fenderd JD's
total tractors is 30..
Whirly is offline
post #4 of 58 Old 06-07-2019, 05:30 PM
First, make sure the metal is clean and rust free before welding (how clean it has to be will vary depending on if you use flux-core or solid wire in your mig welder).
Second, get a good welding helmet. Your eyes are worth more than the cheapest welding helmet available... And cover up, even if it's warm out. It prevents skin burns (both from uv rays as well as flaming hot sparks). Even shoes. You'll feel it when that hot bit of metal falls on your sandal/synthetic shoe, melts through it in 1/2 second, then sits on top of your foot where it's no longer that easy to get out.
Third practice. weld some scrap metal together, of varying thicknesses, cut them apart, see how well you got weld penetration, see how strong the weld is, then weld some more. Read through the manual, and make use of the charts for the settings to use for various thickness of material. You'll need to play with them a bit, to see what works for welding different thickness metals together.
dave_r is offline
post #5 of 58 Old 06-07-2019, 07:09 PM Thread Starter
PA318Guy's Avatar
Flaken, thanks for the link, don't think I've seen any of his videos before. Hoping to do some things to make my 3 pt. hitch more valueable to me like a carrier for tools, pole lift, small forks to lift thing just a bit off the ground, etc... After I retire next year I will probably see if I can get into a welding class close by.
more later..
Whirly, just doing flux core to start, bought the welding hammer and I have a grinder to clean thing up. I plan to do some small welds on things that if I mess up won't cause me any grief. The feeder on the chipper is about the same thickness as a car fender so I suspect you can blow through it with too aggressive of a weld. Somewhere down the road I'd like to re-fab it with some heavier steel or at least reinforce the weak areas. I will try the 20/80 gas a little later, I made sure to buy a welder that allows the use of shielding gas.
Dave, funny you should say that. I watched a guy doing some welding for me and he didn't clean the rust very well and he kept getting poor welds across the item. I asked him if that was normal and he looked at me and said, "no but you didn't clean it very well and I don't have time!" So I never took any work back to him! But I did learn that it really needs cleaned before starting to weld. I have to pick up a long sleeve shirt but I have the gloves, apron, boots, and a helmet, maybe not the best but we'll see. Also picked up some holding vises and magnet holders to help and a set of wire brushes to get areas the grinder can't get to. I will read everything I can and watch several more videos, I was even watching some TiG welding videos although I really don't have any intention of going that far. To me this will be a hands-on learning experience.
PA318Guy is offline
post #6 of 58 Old 06-07-2019, 11:01 PM
spokes100's Avatar
Thumbs up Re: Well it finally happened!!!
As the old joke goes, how do you get to Carnegie Hall? Practice, practice, practice. I welded and fabricated at Eastman Kodak for a few years and can tell you every weld is different, every job is different and you can never be sure you've got the setup until you strike an arc. Set your machine, strike an arc on similar metal to the job and adjust as you go along. The simple act of welding a piece of metal heats it up and it changes the way it welds while you're welding it. Strive to be in control of each puddle.
Enjoy! Welding is an art form that a lot of people do but few really get past the basics. Have fun with it! ...and don't forget to have a fire extinguisher or two handy!
spokes100 is offline
post #7 of 58 Old 06-07-2019, 11:12 PM
Steve Urquell's Avatar
We used these welding sleeves in the trailer shop I used to work in. I ended up with a pair and use them for welding at home. A bit cooler than full gear and fine for welding.
Cutting with a torch needs a bit more coverup to prevent burns so I also had the full shirt like the one below. When I burned up the sleeves I'd take home the shirt and a new sleeve set and the wife would sew them on for me.
ID:	2380671   Click image for larger version
Steve Urquell is offline
post #8 of 58 Old 06-09-2019, 03:40 PM Thread Starter
PA318Guy's Avatar
OK, so got into it today and probably didn't spend enough time setting up the welder at the beginning. Welding 16 guage with flux wire which is just at the limit anyways. The first welds were giving me the pop pop pop sound and I bllew a few holes in the steel. Stopped and went over the welder settings and saw that I forgot to tension the drive pulley for the wire properly. (this was on a video I watched too!) Got that tensioned and then was able to do the recommended tacks about a couple inches apart and even fixed the blow through areas (patting myself on the back for that one). Gun was doing good tacks and I did my first "MiG" welding. Then I was grinding a bit and got my thumb with the grinder (it's in the safety forum). So at a pause because every time I try to do something the thumb bleeds like crazy. Going to have to give it some time. Here are some pics of the job and one of the welder too.
ID:	2380919   Click image for larger version
ID:	2380921   Click image for larger version
ID:	2380923   Click image for larger version
ID:	2380929   Click image for larger version
PA318Guy is offline
post #9 of 58 Old 06-09-2019, 03:54 PM
The largest problem almost all welders have when first starting out is the complete lack of patience that one learns over time. They completely forget that in the videos seen those welders have spent years learning the craft. Usually, in almost all the videos, everything is in pristine condition, the operator knows all the ins & outs of his machine and has practiced.
Don't expect to be making anything even close to mediocre in the first few hours. Scrap metal is there for a purpose!
post #10 of 58 Old 06-09-2019, 04:01 PM Thread Starter
PA318Guy's Avatar
Yeah, but I expect to rebuild this piece completely with heavier steel, so I don't mind practicing on it, I didn't have anything this thin available for practicing on anyways. I suspect that everyone when they start looking at how things are made figure they can do it better. Considering this feeder chute takes a real beating as the limbs pull in they could have reinforced it some and prevented all the cracks this has on it.
PA318Guy is offline
post #11 of 58 Old 06-09-2019, 04:58 PM
Before too long you'll be asking "why did I wait so long to get this". I believe that you will ask yourself the same question whenever you finally get the tank of gas.
I saw your boo-boo from the grinder. Hope you always wear safety glasses with that. Grinding wheels are one of the more common causes of ER visits.
CantKeepUp is online now
post #12 of 58 Old 06-09-2019, 05:16 PM Thread Starter
PA318Guy's Avatar
I always use all the recommended safety equipment, but sometimes you just get caught anyways.
I have to say that I was impressed as well with the welding helmet, it really quickly changed when the welding started. When I was a kid I remember my father wearing those old safety goggles that when you put them on you could barely see anything let alone what you were working on.
PA318Guy is offline
post #13 of 58 Old 06-09-2019, 06:06 PM
My favorite welders quote is :
"A grinder & paint will make you the welder you ain't"..
I need to get more practice with my craptastic Harbor Freight 90 amp "flux core welder"..
So far my attempts to master running a bead with it have been futile,it acts more like a plasma cutter on thin metal..
I think it is partly due to the fact its an AC "wire feed ARC welder",not a "MIG" welder that has argon/co-2 gas and are usually DC ..
I have better luck using 3/32" 6011 rods with my DC arc welder set on about 35-40 amps. than I have using the wire feed ,I've tried fiddling with the wire speed and heat setting (only has "hi & lo")...my friend has an identical welder and he's done pretty good with his welding a new door skin on his car door,so I assume its me that isn't doing something right..he also has a "real" MIG with gas and I've tried using that with not so great results too,I think its because I'm used to stick welding..
Tractor-Holic is offline
post #14 of 58 Old 06-09-2019, 11:01 PM
This is a very useful site for videos and how-to's
Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
Dee_Veloper is offline
post #15 of 58 Old 06-09-2019, 11:31 PM
MARK (LI)'s Avatar
I am kind of surprised that no one mentioned the most common mistake we have all made ...especially in the beginning..
DO NOT GRAB THE PIECE YOU JUST WELDED
Now you have to keep your eyes out on junk night for when you see bed frames and other useful items that can be repurposed in steel fabrication
Good luck with the machine
MARK (LI) is offline
