John Deere GT Steering Wheel puller Plate - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 21 Old 01-22-2019, 06:15 PM Thread Starter
Rebuilding my First JD GT
N2 Tractors's Avatar
Hi all,
I'm not sure the best place to put this so I placed it here. Mod's please move to appropriate area if required.
So Yesterday I needed to pull a few steering wheels from some tractors to make use of one I got from Jared and because... well just being able to pull a steering wheel from any of my JD tractors with out damaging either the steering wheel or scratching the column is something I wanted to be able to do.
Being as how I am cheap-horses backside, I decided I would use some left over 1/4" Mild Steel scraps from other projects.
I started out by measuring the steering column and that is 1.5" in Diameter. Next I needed to know the widest circumference around the hub of the wheel to determine how wide I would need the piece of scrap to be. I measured 2.5" at the widest or thickest part of the steering wheel hub. With that information I set out to find a piece of scrap to fit the bill. I found the perfect piece "OK maybe not perfect but good enough" to get the job done.
I found the center of the scrap piece and center punched a divot to use for drawing out the circles. Then I marked an inner circle for the steering column radius 1/8" over sized for wiglge room and errors followed by an outer circle for the wheel hub. Then marked two straight lines so I could cut out the area that will slide around the steering wheel column and under the wheel itself.
Next I marked and center punched two spots wide enough for two puller bolts to just fit outside the steering wheel hub. I am going to be using this plate along with a OEM Gear Puller I use to pull flywheels off of the motors.
Once I had the plate all laid out and marked for cutting and drilling I went to town. It went pretty smooth and once the cutting and drilling was done I tapped the holes for 5/16 NC18 threads. I put it to use right away thinking it might bend if one of the wheels is on pretty good and stubborn. Sure enough the first wheel I used it on caused it to bend. So I had a back up plan anticipating this. I beat on it with a steel mallet on the anvil base of my bench vise to make it straight again and welded on some more scrap pieces I had laying around. This added some strength to the plate by using right angles around the outside to stiffen it up a bit. It's not perfect but in a hurry it's a lot better than nothing and a little flat black paint should make it look half decent.
Pictures will explain the rest.
ID:	2357989   Click image for larger version
ID:	2357991   Click image for larger version
ID:	2357993   Click image for larger version
ID:	2357997   Click image for larger version
ID:	2357999   Click image for larger version
ID:	2358001   Click image for larger version
ID:	2358005   Click image for larger version
ID:	2358007   Click image for larger version
ID:	2358009   Click image for larger version
Running:
‘73 140 H1, ‘75 214, ‘79 JD 317 Onan P218G, 19xx Wheel Horse D250 550 Arc FEL ARPS Box blade
Not Running:
‘69 JD 140 H3, ‘75 JD 300, ‘79 JD 317 Kohler KT17QS II, ‘83 JD 420, late ‘80’s JD 316, ‘90 JD 316,
2x 300 series 3PH, Johnson Workhorse 12, Gannon Earthcavator 32”, 2x JD 54” 4way blade, 2x JD 33 Tiller + 8" Extension, JD 38” Brass tag mower deck, JD 48” mower deck, JD #30 Hydro Tiller, Disks, Plow, ARPS Angling Backblade,
N2 Tractors is offline
post #2 of 21 Old 01-22-2019, 07:27 PM
Still lovin' the 322!
PA318Guy's Avatar
Re: John Deere GT Steering Wheel puller Plate
And how much are these going to cost?? Great idea!
Current Machine JD 322
PA318Guy is offline
post #3 of 21 Old 01-22-2019, 08:14 PM Thread Starter
LOL I thought about producing these but thought that there is probably something Chinese made already out there that would work just as good at a better price than I could offer. I would think If I made a bundle of these I could probably get em made unfinshed “no paint” for $15+$hipping. Haven’t really done the math.
Edit: thank you for the nice compliment PA.
If any one just has to have one of these send me a PM.
Running:
Not Running:
post #4 of 21 Old 01-23-2019, 12:06 PM Thread Starter
Guess $15.00 is too much lol.
Running:
Not Running:
post #5 of 21 Old 01-23-2019, 12:20 PM
great piece of work thanks for the post
northbama is offline
post #6 of 21 Old 01-23-2019, 01:37 PM Thread Starter
Thank you northbama
Running:
Not Running:
post #7 of 21 Old 01-23-2019, 03:13 PM
wow from looking at your list you have a nice collection of JD'S
post #8 of 21 Old 01-23-2019, 03:38 PM
I've mounted a 5/8" flange bearing for the top end of the steering shaft to a metal plate just below the plastic consul. Made the steering smooth and not all wobbly like it was before.
L120 is offline
post #9 of 21 Old 01-23-2019, 04:02 PM Thread Starter
@ northbama, I have a couple more not listed in my sig. The list is up to 3x 317's 3x 140's a 314 and a F935.
Only a couple of them run and none are restored. So basically all work horses that I don't have to worry about getting dirty or sitting outside. I should probably start thinning the lot. Recently in the last yearI have come accross several good deals that were to hard to say no too. You could say I have Deere Fever.
Running:
Not Running:
post #10 of 21 Old 01-23-2019, 04:15 PM Thread Starter
I have never experienced a wobbly steering on one of these from the column not being securely mounted.
Running:
Not Running:
post #11 of 21 Old 01-24-2019, 02:24 PM Thread Starter
Well I am going to make a batch of 5 to see how long it takes and one of them is already sold.
Running:
Not Running:
post #12 of 21 Old 01-24-2019, 02:35 PM
that is great and American made also
post #13 of 21 Old 01-24-2019, 02:41 PM Thread Starter
Yeah the funny thing is I'm using an American designed and Chinese built welder and I will be buying some chines punches later today to number these starting with 1
Running:
Not Running:
post #14 of 21 Old 01-24-2019, 09:12 PM Thread Starter
Ok I made version 2 earlier today. What do ya'll think does it look more better? In the last two pictures you can see how I used a mirror to make sure I had adequate clearance around the steering column.
ID:	2358331   Click image for larger version
ID:	2358333   Click image for larger version
ID:	2358335   Click image for larger version
ID:	2358339   Click image for larger version
ID:	2358341   Click image for larger version
ID:	2358343   Click image for larger version
ID:	2358347   Click image for larger version
ID:	2358349   Click image for larger version
Running:
Not Running:
post #15 of 21 Old 01-24-2019, 10:09 PM
Smalljob's Avatar
Very nice
1988 332 with 49 blower , 54 blade and 3 pt hitch
X500 w/48 deck and 44 blower
1023E H120 loader, B260 BH, 54D deck
Moved on to new home
1962 IH Cub Cadet Original
1963 110 Round Fender... Restored
1963 IH Cub Cadet 100, plow, deck, weigh box, 3 point hitch
1965 110 Round Fender with Model 38 deck..Restored
1966 110H Round Fender with Model 42 Blade..Restored
1967 112 Round Fender with Model 36 blower
1967 112 Round Fender with Johnson Model 10 Loader
1971 120 with 48 deck and 49 blower and OTC cab
1973 140H3 with 41 deck
1987 318 with 46 deck, 54 blade, 49 blower, 3pt hitch
1987 332 with 46 deck
Smalljob is offline
