Best value flux core welder? - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 30 Old 11-19-2018, 04:28 PM
Choke's stuck on!
robhay2's Avatar
Re: Best value flux core welder?
Originally Posted by coxhaus View Post
I bought a bottle with C25 years ago. The C25 makes pretty welds. I am now thinking of getting a CO2 bottle. I think it will be cheaper to run and buy. I am no pro welder so I have no experience using CO2 but from what I read it has better penetration with a little more splatter. Anybody know?
The other thing I have figured out is with C25 you cannot spray weld. You need C10 to spray weld. Any comment.
So give your bottle buying some thought. There seems to be a lot to it which I did not realize when I bought my bottle.
Right on the CO2 vs. C25. I ran out of C25 on a Sunday so I grabbed the CO2 cylinder from my kegerator. It worked quite well.
Significantly cheaper and higher capacity per tank size tank to boot. There is more smoke and spatter than C25. Nice to have both so you are covered on that Sunday... You still have C25 for welds required to be pretty. I cannot comment on the C10, as I've not attempted spray welding.
robhay2 is offline
post #17 of 30 Old 11-19-2018, 04:36 PM
ex spelling bee champ
Ingersoll444's Avatar
One thing to watch out for if you dont weld a lot... most times you get a bottle, and the place does a exchange. Well i failed to check the date on the bottle they gave me, and now that its been laying around a few years becouse of my light use, the bottle has expired... So check your dates!!
Paul
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #18 of 30 Old 11-19-2018, 04:53 PM
Money Pit
Dave Wells's Avatar
I highly recommend any Lincoln, Miller, or Hobart 110 welder for the novice hobbyist. They are very forgiving easy welding machines made with good parts such as the gun and leads. I'm a professional welder and would only recommend a no name import cheap welder for the experienced. You have to know what your doing to get them to weld good. Spend a little extra and you wont be disappointed.
dave wells
Dave Wells is offline
post #19 of 30 Old 11-19-2018, 05:43 PM
Parts collector
mopar65pa's Avatar
Originally Posted by dave_r View Post
Yeah, I also bought a Miller 211 (older version which was taller), only use it with flux-core, but it works fairly well for the majority of stuff I do. For this stuff (below 1/8") it doesn't work great for me, and for larger stuff (longer welds where the pieces are over 1/4") I'll use a old buzz-box stick welder.
I have to get a bottle and try welding some thin stuff with solid wire, as it's supposed to weld better.
oh my my 211 is a dream with the bottle, does sheet metal awesome even on the auto setting. You really need to get a bottle. I have an OLD Lincoln tombstone stick welder for the really heavy stuff.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #20 of 30 Old 11-19-2018, 08:26 PM
As long as you go back to the same place with their bottle they will exchange an expired bottle for you. That has been my experience in the past with my acetylene tank. I have not owned my Mig tank long enough for it to expire. I am a slow user also. I have projects from time to time but not continuous use. Also when I have my tank filled I wait for them to fill my tank. I don't like exchanges. As I get older I may change my mind as my local welding supply has a Friday delivery for exchange tanks and then they just bill you.
I am thinking of moving over to C10 and a CO2 tank and skip C25 tank. They may be able to put C10 in my C25 tank.
Power King 2414 garden tractor
coxhaus is offline
post #21 of 30 Old 11-19-2018, 10:17 PM
Ive had harbor freight 115v mig/flux for years.Only use for thin metal and for repairs away from home.Perfer stick welder,but it cant go anywhere.If I ever upgrade mig/flux ,it will still be 115 volt.
slow wrench is offline
post #22 of 30 Old 11-19-2018, 10:41 PM
Duane4238's Avatar
I had about the same requirements as the OP. After looking at all the options, I opted for a 135 model that's sold by the Eastwood Company. You can check it out at Eastwood.com. They sell all kinds of auto restoration equipment and tools. They have setup and basic welding videos on youtube that really helped me in the beginning. I bought my unit on sale and it had free shipping and a full 3 year warranty to boot. Came with everything needed to start welding including a cart and an automatic helmet. The only thing I had to get locally was the shielding gas. I've used it to repair mower decks, tractor frames, and also some sheet metal work. They were great when it came to warrenty, too. Last spring I used it for the first time in over a year and the gas regulator wasn't registering right. I called them and had a new one on the porch in 2 days. They told me to throw the old one out. Check them out if you really want an affordable quality 110v mig welder. Good luck and Happy Thanksgiving!
Duane
Duane4238 is offline
post #23 of 30 Old 11-20-2018, 02:08 PM
I heard the Hobart 125 EZ welder runs a pretty good bead using flux wire. I am not sure they sell them any more. Look around.
coxhaus is offline
post #24 of 30 Old 11-24-2018, 09:23 PM
Tractor Nerd
Justy37's Avatar
Personally... If I was starting new looking for a welder.. I would probably skip my everlast welder and buy a harbor freight 200 titanium or 220 vulcan multi-process unit. Can mig, stick, and tig - steel... No AC option for aluminum... You can dc tig aluminum with helium, just not as good as ac can. Both machines will run on 110 or 220, or off a generator 110/220.
1963 953 wheel horse hydraulic lift 54" dozer blade, 420cc Predator 60340.
2003 Dixon ztr.
2001 John Deere from Denmark 415 diesel 54" deck.
1998 2020LC 60" deck.
2016 Cheetah zero turn 61" Kohler fuel injected.
And a lot more...
Johnny Popper collector
Member of Red Square forum
Justy37 is offline
post #25 of 30 Old 11-25-2018, 12:52 PM
I really like my Hobart 190, got it on sale 5 years ago. I just used flux core wire but it has everything to use gas with it except for the tank.
9297oldram is offline
post #26 of 30 Old 11-26-2018, 09:01 AM
c5rulz's Avatar
The comments regarding Harbor Freight cheap welders is unwarranted. Sure the more expensive are better, but for a novice it has got me welding and fixing things that before would be impossible.
Here is a video
Case DX 33 with loader
JD X758 60" HC deck
Dolmar 7900
Jonsered 2159 ported
Echo CS303T
Echo PPT 266
Stihl 028 Super
Echo PPT-266 pole saw
Silvey 510
Oregon 511AX
Nielsen 100B for rakers
c5rulz is offline
post #27 of 30 Old 11-26-2018, 12:15 PM
My main gripe about the HF welder is the fact once anything fails on it,it's most likely not going to be possible to obtain any parts for it,and due to the low price,it is considered "disposable",that is the biggest drawback to HF tools....that and the fact it wont weld thin stuff without blowing holes,or anything thicker than 3/16 ,the penetration just isn't there..
I'm glad I didn't pay their full price for it at the store,I'd have been much more disappointed with it if I had..I haven't used it much,perhaps if I practice with it I'll get better at using it..
I know you cant expect miracles for under $100,but you shouldn't have to open it up and modify one with a DC rectifier in order to make it work better either..
I suppose they are better than having no welder,but I consider the $50 I spent on an old AC/DC arc welder off craigslist a better bargain..you can do so much more with it..
I know guys who bought the larger 220V Harbor Freight MIG welders and they seem to be working well and holding up good for them,one uses his in a repair shop often,sometimes daily--his biggest fear is if he'll be able to get a new "gun" and other parts for it once things start wearing out..the new Vulcan welders they recently introduced do look promising though..
Tractor-Holic is offline
post #28 of 30 Old 11-26-2018, 09:23 PM
My friends new black H.F.mig/flux has better working wire feed than my older blue model.Or mine was a lemon.
post #29 of 30 Old 11-27-2018, 01:21 PM
The one I have is a black one,90 amp model...probably 2-3 years old..
I see HF is now selling them as a "125 amp" now,I wonder if they upgraded anything inside like the transformer,or if they added a rectifier?...
post #30 of 30 Old 12-09-2018, 12:31 AM
The Miller blue models have pretty good wire feeds.
coxhaus is offline
