Need carb settings for Homelite chainsaw - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 09-27-2011, 07:39 PM Thread Starter
Hi
My friend has a Homelite 10618-A chainsaw. Serial #1G1140642. He messed with the carb and forgot how many turns out the hi and low settings are. Can anybody help us out ?
Thanks Rod
Rodster is offline
post #2 of 8 Old 09-27-2011, 08:03 PM
buffy12590's Avatar
Re: Need carb settings for Homelite chainsaw
Try 1 1/2 turns out from bottom on both needle valves. This will give you a starting point to get it started and then fine tune it.
buffy12590 is offline
post #3 of 8 Old 09-27-2011, 08:04 PM
Deceased October 2017
I'm sure Calvin (lawnmowertech) will be able to help you, if he don't reply try sending him a PM.
Ken in NJ is offline
post #4 of 8 Old 09-28-2011, 11:08 AM
M21BMR's Avatar
+1 to this advice.
turn both needles clockwise gently to where they bottom out, then open each 1 1/2 turns and you should be able to at least start the saw at that setting. You can fine tune from that point, in something close to 1/8 turn at a time. Counter clockwise turns allow more fuel (richer air/fuel ratio), clockwise turns allow less fuel (leaner air/fuel ratio).
2005 John Deere L111
1991 Lawn Boy M21BMR
John Deere E35 Edger
Echo CS-590 Chainsaw
Echo CS-400 Chainsaw
Echo SRM-230 Trimmer
Echo ES-250 Shred-N-Vac
Echo PB-251 Blower
Echo HC-165 Hedge Trimmer
Stihl MS-193T Chainsaw
Toro (Ryobi) powerhead w/ trimmer, brushcutter, edger, pole saw, cultivator, hedge trimmer
Honda F220 Tiller
Troy-Bilt 5000W Generator
Husky 26 Gallon Air Compressor
Campbell Hausfeld Pressure Washer
Craftsman Shredder / Vac
M21BMR is offline
post #5 of 8 Old 09-28-2011, 05:38 PM
lawnmowertech's Avatar
Try 1-1/2 turns if to rich it will need to be turned inward and to lean outward and so on
lawnmowertech is offline
post #6 of 8 Old 09-29-2011, 09:50 AM
johninMd's Avatar
what i was told is once running and warm, adjust it cutting wood, set HI rich enough that saw "burbles" at full throttle, then start cutting, moving it leaner just until engine smooths out and burble stops while cutting. But just just ever so slightly still burble at wide open throttle after the cut/ That way its as rich as it needs to be. All done while cutting , dont matter what it does when not in wood really.
I have saw many people adjust for the most rpm and "fastest" engine speed with the saw not in wood, not good.
I adjust my saw like above, and i can actually tell it runs cooler too.
johninMd is offline
post #7 of 8 Old 09-29-2011, 11:44 AM Thread Starter
Thanks for the info
Rod
Rodster is offline
post #8 of 8 Old 10-27-2011, 11:01 AM
c5rulz's Avatar
I agree!
A saw really should also be set with a tach so it doesn't over rev, (run lean).
From Madsens tech area.
http://www.madsens1.com/saw_carb_tune.htm
Case DX 33 with loader
JD X758 60" HC deck
Dolmar 7900
Jonsered 2159 ported
Echo CS303T
Echo PPT 266
Stihl 028 Super
Echo PPT-266 pole saw
Silvey 510
Oregon 511AX
Nielsen 100B for rakers
c5rulz is offline
