Carb Adjusting Probs - Time for Rebuild? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 10-17-2019, 02:05 PM Thread Starter
hotajax's Avatar
OK, got this old Echo 330 T. It starts, runs fine on low speed. Now, when it's time to cut and you pull the trigger, it dies. I have tried to feather it, adjust the high side in all directions, and still can't get it to go to stay running at high speed. I did have it working the other day after feathering the throttle. Sounds like it might be time for a rebuild, or a new carb. Pretty easy to rip out the carb on this model. I guess this saw is somewhere around 12 - 15 years old.
Come to think of it, it has not been running great for a while, as in 6 mos. At wide open throttle speed fluctuates up and down a lot. Thanks for any opinions y'all may have.
hotajax is offline
post #2 of 9 Old 10-17-2019, 02:17 PM
Professional Homeowner
steddy's Avatar
Re: Carb Adjusting Probs - Time for Rebuild?
Donít forget to replace the diaphragm if it isnít included with the carb kit!
For a fact, thatís all the problem might be...
steddy is online now
post #3 of 9 Old 10-17-2019, 07:37 PM
On engines that old, sometimes the problem isnít actually the carb, but the carb gaskets start leaking air through making the mixture way to lean.
orangetractor is online now
post #4 of 9 Old 10-18-2019, 12:36 AM
dougand3's Avatar
Also, check that the muffler screen isn't clogged. It will idle fine but will bog on throttle up.
dougand3 is online now
post #5 of 9 Old 10-18-2019, 01:29 AM
10 fingers 10 toes
Kubota Ronin's Avatar
Also check your fuel lines... sounds like it might be sucking air. If they've never been replaced they're well past their due date.
Scott
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
post #6 of 9 Old 10-18-2019, 08:21 AM
c5rulz's Avatar
Air leak.
Do not run until a vacuum test is done or you'll burn it down.
c5rulz is offline
post #7 of 9 Old 10-18-2019, 04:18 PM
How do you do a vacuum test?
Ariens93GT20 is online now
post #8 of 9 Old 10-18-2019, 06:25 PM
c5rulz's Avatar
c5rulz is offline
post #9 of 9 Old 10-19-2019, 04:53 PM
Another 50 or 60 spent on tools will not be happening. Will just replace the seals and have it over with.
You may post new threads
You may post replies
