A landowner who was real fussy about the poor quality of bar oil found Service Pro bar and chain oil I split an order of 6 cases, (6 gallons case) of Summer weight. The company delivered it and it came to $7/gallon. Very tacky oil
Another one I like a lot is Essence. It might even be better and that also was in the $7-8 dollar range.
Years ago the Poulon green jug was good too.
Service Pro:
SERVICE PRO® BAR AND CHAIN OIL
Manufactured with virgin base oils
Association of Independent Oil Distributors •
www.service-pro.com • P.O. Box 1861 • Montrose, CO 81402 USA
Updated: 09/15
SPWNBCOIL
DESCRIPTION: SERVICE PRO® Bar and Chain Oil is a premium lubricant designed especially for the lubrication of bar
and chains on chain saws, and all types of link chains that require lubrication, including motorcycles and
bicycles, as well as farm and industrial uses.
SERVICE PRO® Bar and Chain Oil is formulated with highly refined base stocks and an additive package
to assure excellent performance as a chain saw bar and chain lubricant. A special tackifier is added to the
oil, which promotes good adhesion to moving parts and minimizes oil throw off. These oils are designed to
prevent rusting and reduce wear and link breakage thus extending bar and chain life. Penetration into
rivet holes and the bat channel is assured. Down-time and cutting interruptions are minimized.
• Extends bar, chain and sprocket life
• Reduced throw off
• Reduces heat build-up
• Excellent rust and corrosion protection
• Different viscosity weights for various ambient temperatures
Winter Summer
20W 40W
Gravity, API 30.8 28.9
Density, 0.8708 0.8808
Viscosity
@40 Deg. C, cSt 51.29 118.56
@100 Deg. C, cSt 8.21 13.47
Viscosity Index 132 109
Pour Point Deg. F -36 3
