Oil in the air filter??? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 11-06-2019, 08:43 PM Thread Starter
I have an 26 year old 5000 watt Generac generator that has a Tecumseh HM100 159436P engine that was manufactured in 1992 with 460 hrs on it. I recently went to change the air filter and noticed that it had some oil on it and a small amount of oil had also collected on the bottom of the air filter housing as well. Aside from this recent oil issue the engine and generator run perfectly.
I was thinking it was most likely a tired reed valve or a clogged drain hole in the breather assembly. I wanted to get some input before I started taking things apart. Am I going in the right direction or should I be checking something else? Your thoughts are much appreciated.
Thanks to all.
wml52 is offline
post #2 of 8 Old 11-06-2019, 09:08 PM
Jack of All Trades Guru!
Bassguitarist1985's Avatar
Re: Oil in the air filter???
Valves leaking, valve guides worn, worn piston rings, blown head gasket. Plenty of things for crankcase pressure to make oil be drawn into the breather hose. May be time for a new engine, or at the least a rebuild.
Sent from my SM-N910V using Tapatalk
Bassguitarist1985 is offline
post #3 of 8 Old 11-06-2019, 09:18 PM
10 fingers 10 toes
Kubota Ronin's Avatar
I dunno... with only 460hrs I'd think the engine might well still be sound.
As long as it's running good and not drinking oil I'd clean it up and see what happens.
Scott
Kubota AMX-3
Shibaura LT16B
Kubota Ronin is online now
post #4 of 8 Old 11-07-2019, 06:48 PM
Joe
micah68kj's Avatar
Location: Pa. Transplant from the the great state of Wv.
Yep. If it ain't broke don't fix it.
Joe
micah68kj is offline
post #5 of 8 Old 11-07-2019, 07:07 PM
Parts collector
mopar65pa's Avatar
If it's not dripping out keep running it.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #6 of 8 Old 11-07-2019, 10:36 PM
FWIW, I had an old Tecumseh HH60 that would literally pour oil out of the air filter. I replaced the breather (reed I think), and totally cured the problem.
That said, if it ain't broke, don't fix it. But even if it does get worse, don't jump to the conclusion that the engine is toast.
Good luck, keep us posted.
Mike
TRACTORS:
OTHER (NOTABLE) EQUIPMENT:
Echo PB751T backpack blower
Husqvarna 350 chainsaw
RETIRED TRACTORS:
mikeinri is offline
post #7 of 8 Old 11-07-2019, 11:24 PM
Make sure the dipstick tube seal is good. I haven't seen a Tecumseh do it but had a vanguard twin that spit a lot of oil into air cleaner assembly until I fixed the o-ring at the bottom.
TobyU is offline
post #8 of 8 Old 11-08-2019, 09:09 PM Thread Starter
Thanks for all your thoughts, it is very much appreciated. After taking another look at the engine my gut tells me it's most likely the breather assembly. To replace all the parts is less then $15.00. I figured for $15.00 it's worth giving it a try and see if that solves the issue. Not going to give up on the old Tecumseh just yet...lol
wml52 is offline
