MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Engine Pulley Size
post #3 of Old 01-04-2017, 09:24 AM Thread Starter
watersteps
Re: Engine Pulley Size
Thank You but I need to know the factory pulley size. This pulley mounts on the engine crankshaft. It has 2 belt grooves one drive the tractor transmission and the other drives the pulley that turns the shaft that operates the cutter bar weed cutter. The pulley is about 2 to 2 and 1/2 inches OD and about 4 inches long. The sizes are standard for some DB tractors. I will try to find a picture and attach it to this post. Thanks again.
watersteps is offline
