Won't Run, Idles Rough - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-19-2009, 03:43 PM   post #1 of 5
x485 aws
MTF Member
x485 aws's Avatar
MTF Member # 33785
Default Won't Run, Idles Rough
Hello. My X485 AWS has the 25hp Kawi. Just recently (last couple of mowings) it started to cut out a little but would then run fine. Well, about two ago I was about half way through mowing and it coughed a couple of times and then died. Now it will sometimes start and idles very rough. when I try to idle up, it dies. I replaced the fuel filter and also put new gas in. With the fuel linie unhooked, the pump will shoot gas several feet, so I'm guessing fuel pressure is good? Any help would be appreciated.
x485 aws is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-19-2009, 04:38 PM   post #2 of 5
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
Default Re: Won't Run, Idles Rough
When you say cough, do you mean the engine is bogging (fuel), or does it shut off and on sharply (ignition)??
__________________
1983 318.
2009 X729 with 54" deck & 54" blade, oh and 45 loader
__________________________________________________ __
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
saleen49 is offline   Reply With Quote Quick reply to this message
Old 10-20-2009, 09:11 AM   post #3 of 5
x485 aws
MTF Member
x485 aws's Avatar
MTF Member # 33785
Almost like you turned it off and back on again, but no back back fire.
Old 10-20-2009, 09:21 AM   post #4 of 5
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
Quote:
Based on that, I might start looking for an easy ignition issue first. Take the panels off and look over all wiring, and grounds. Grab the connectors and see if they can be pulled apart.
__________________
1983 318.
Sponsored Links
Advertisement
Old 10-20-2009, 02:33 PM   post #5 of 5
x485 aws
MTF Member
x485 aws's Avatar
MTF Member # 33785
Give it a try. Do you think it may be a vaccum line?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
