JD 140 not charging - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-16-2009, 10:02 PM   post #1 of 10
don17x
MTF Junior Poster
MTF Member # 33851
Default JD 140 not charging
I just bought this and it only puts out 9.6-10.0 volts. Not sure of the year the serial #065841-M and engine#k321as Any ideas would be great. Thanks Don
don17x is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-16-2009, 10:25 PM   post #2 of 10
johndeere
3K Poster!!!!
johndeere's Avatar
MTF Member # 207
Images: 7
Default Re: JD 140 not charging
Dead cell in a battery is the first thing to check for.
johndeere is offline   Reply With Quote Quick reply to this message
Old 10-16-2009, 10:56 PM   post #3 of 10
don17x
MTF Junior Poster
MTF Member # 33851
It needed a battery when i bought it. So i installed a new one and check the charging and it is around 10 volts.
Old 10-16-2009, 11:01 PM   post #4 of 10
johndeere
3K Poster!!!!
johndeere's Avatar
MTF Member # 207
Images: 7
Should have 12 directly from the battery without it running?So if its 10 and the battery has a full charge its a bad battery.
Old 10-16-2009, 11:34 PM   post #5 of 10
don17x
MTF Junior Poster
MTF Member # 33851
When it's running the charging system only puts out between 9.6-10 volts.
Old 10-16-2009, 11:42 PM   post #6 of 10
johndeere
3K Poster!!!!
johndeere's Avatar
MTF Member # 207
Images: 7
What does it put out not running?
Old 10-18-2009, 11:48 AM   post #7 of 10
don17x
MTF Junior Poster
MTF Member # 33851
Not running the battery has 12.5 volts. But when it's running the volts gauge is on 10 volts. I checked it with my multimeter and its between 9.6 and 10 volts. With the same battery in my other tractor running my multimeter says 13.2 volts.
Old 10-18-2009, 01:58 PM   post #8 of 10
grnspot110
3K Poster!!!!
grnspot110's Avatar
MTF Member # 4515
Images: 21
Garage
Start engine. Remove3-prong connector from regulator. Use AC voltmeter to check outer two wires (from stator). Check at full speed (no load), you should get 28 to 32 volts (AC). If voltage is sustantually below 28 volts AC, the stator is bad.
If you get more than 25 to 28 volts the stator is OK,the regulator must be bad!
My 69-140 had a 10 AMP system, with a bad stator. I was able to get a used 15 AMP stator & flywheel & new regulator off Ebay to replace the system.
Not sure what serial number they changed to the newer 15 AMP system. ~~ grnspot110
__________________
Home of the JD L/60 "Custom" & the 70 I!
grnspot110 is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 04:10 PM   post #9 of 10
don17x
MTF Junior Poster
MTF Member # 33851
O.K. i just checked and the voltage went as high as 38.2. So does this mean my voltage regulator must be bad? I just don't want to buy parts i don't need. Thanks Don
Sponsored Links
Advertisement
Old 10-18-2009, 08:55 PM   post #10 of 10
grnspot110
3K Poster!!!!
grnspot110's Avatar
MTF Member # 4515
Images: 21
Garage
There are people here who know more than I do, but it sounds like it's the regulator, or a loose connection some where! The new one I bought was from EMS (Electric Motor Service), 800/697-6070. If I remember right, it was around $40.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
