John Deere 420 charging light - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-04-2009, 10:24 PM   post #1 of 12
verybadace
Senior MTF Member
verybadace's Avatar
MTF Member # 2416
Images: 22
Default John Deere 420 charging light
Hi,
I have seen a subject post on the charging system of the John Deere 420. Just can't seem to find it. My battery light on the dash comes on once in awhile. It will sometimes blink on and off. Then sometimes stays on for short periods of time. Lately, it has been more. Also, now when you kick on the PTO the battery light comes on and stays on. Just started doing that. Anyone have any ideas?
verybadace is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-04-2009, 10:32 PM   post #2 of 12
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Default Re: John Deere 420 charging light
You have a problem with your charging system. My first recommendation would be to disconnect and clean EVERY electrical connection.
Next charge your battery fully, start the tractor and measure the output voltage of the regulator. If it's below tolerance, then check the output of the stator (using the AC scale). It should be minimum of 30 volts I beleive - closer to 50 ideally.
Maybe just dirty connections if your real lucky, maybe a regulator if you're not so lucky, and maybe a stator if you're not lucky at all.
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 10-04-2009, 11:43 PM   post #3 of 12
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
The regulator is more than likely going south. Mine did what yours is doing and the regulator was the problem.
__________________
1983 318.
2009 X729 with 54" deck & 54" blade, oh and 45 loader
__________________________________________________ __
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
saleen49 is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 08:56 AM   post #4 of 12
whiskeykilo
whiskeykilo
whiskeykilo's Avatar
MTF Member # 15730
Had same issue with my 430. Turned out to be the alternator.
__________________
"Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it" - Mark Twain
2008 JD x740 w/PTO & 3-point: 62" deck w/PowerFlow & Bagger; 2008 Taylor Pittsburgh 922 48" Tiller; Zimmerman Cat 1 Rear Weight Bracket; 5' landscape rake
1989 JD 430 w/3-point: Johnny Bucket Sr. w/tooth bar & bucket doubler; JD 80 Dump Trailer; K&W Mfgr. 48" box scraper w/scarifier kit; Zimmerman Cat 0 Load Lifter
whiskeykilo is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 02:45 PM   post #5 of 12
Stash
Senior MTF Member
Stash's Avatar
MTF Member # 20758
The charging system could be the problem, or the PTO field coil is pulling too many amps.
I would do as suggested by D-Dogg. Then if the problem persists, check the output voltage at the middle termain of the regulator. You should be getting 13.5 to 14+ VDC at full throttle with no load.
If not, post back your reading. If the voltage is less than adequate, it is either the stator, the pickup coil, or the regulator. If the reading you get is in the range above, then more likely the field coil is bad.
__________________
http://zoyathehusky.webs.com/
Stash is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 06:55 PM   post #6 of 12
KHodges
AKA Moses Lawnagan
KHodges's Avatar
MTF Member # 23296
Images: 6
Quote:
Originally Posted by verybadace View Post
Hi,
I'm not saying you don't have a problem, but my '02 GT235 has been doing that for two years or more. I still have my original battery, the tractor has about 450 hrs, and it will sit for a couple of weeks at a time without being run. Whenever I do use it, it starts right up, runs fine, but the symptoms are just as you describe. I wonder how sensitive the charge light is; can the charging system be doing its job, but just a bit below the threshold that the charge light senses too little voltage, or current, whatever?
__________________
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
Simplicity 10" plow adapted to 3-pt hitch
45 FEL
'02 JD GT235, 48C deck
'86 JD 214, 46" deck
I've always had a problem with kleptomania.
When it gets really bad, I take something for it.
KHodges is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 07:07 PM   post #7 of 12
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
Quote:
It may be common for the charging light to flicker at low RPM, but not at high RPM, or WOT. Put a volt meter on it and monitor the output through out the RPM range. It should be at least 14v Ac at high RPM.
__________________
1983 318.
Old 10-05-2009, 10:03 PM   post #8 of 12
Upper5Percent
5000 Strong & Climbing
Upper5Percent's Avatar
MTF Member # 8602
Hi,
http://www.mytractorforum.com/showth...harging+system
__________________
The answer is 42
Upper5Percent is offline   Reply With Quote Quick reply to this message
Old 10-06-2009, 06:01 AM   post #9 of 12
hgl1
Senior MTF Member
hgl1's Avatar
MTF Member # 20597
Garage
Hey VBA
I had the same problem with mine and it was one of the fuses. On mine there are 2 fuse holders behind the dash panel and I cleaned the contacts and replaced the fuses. Problem has not returned.
hgl1 is offline   Reply With Quote Quick reply to this message
Old 10-06-2009, 08:49 AM   post #10 of 12
ZeroJunk
Senior MTF Member
MTF Member # 67364
Mine comes on for a few seconds some times at WOT on my 318, but when I check the voltage it's 13.5 or better. I think I will just cover it up with black tape.
ZeroJunk is offline   Reply With Quote Quick reply to this message
Old 10-06-2009, 08:52 AM   post #11 of 12
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Quote:
Originally Posted by hgl1 View Post
Hey VBA
Lots of problems on these older machines are nothing more than dirty connections.
Sponsored Links
Advertisement
Old 10-06-2009, 10:07 PM   post #12 of 12
verybadace
Senior MTF Member
verybadace's Avatar
MTF Member # 2416
Images: 22
Thanks for all the suggestions. Sure enjoy all the response. The doctor is back with the problem. I put on the voltage meter and was getting 11 volts +. So had a new spare regulator. Sure enough the voltage went up to nearly 14 volts. The new regulator came with new connections with crimp ends. Should I put these on? Guess I should but wanted to try the new regulator. Here are some pictures of the old regulator. See the greenish blue corrosion under the electrical connections. Not the best picture. Didn't see the corrosion until I pulled out the regulator. Once again thanks for all the responses. The light is staying out. Also, the light goes out after a quick blink, like what was stated earlier, when you turn the key on before starting it and the battery is at full charge.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
