Mower removal and install BX2660 - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Closed Thread
Thread Tools Display Modes
Old 10-03-2009, 01:06 PM   post #16 of 35
TPS
Senior MTF Member
MTF Member # 5447
Default Re: Mower removal and install
Kylied,
One more tip for you when reinstalling the MMM. I used to try and hold the coupler back and slip it all the way onto the mid PTO. It is far easier to start it onto the shaft and then pull the coupler back and slide it the rest of the way onto the shaft. Just remember to double check and pull on it to be sure it is locked in place or all kinds of things can happen and none are good!
Take care-TPS
__________________
Si Vis Pacem, Para Bellum
TPS is offline   Quick reply to this message
Sponsored Links
Advertisement
Old 10-04-2009, 08:00 AM   post #17 of 35
David M
Senior MTF Member
MTF Member # 28256
I, too, am coming up on 10 hours on my new 2660, so I thank you all, too!
David M.
David M is offline   Quick reply to this message
Old 10-05-2009, 07:48 PM   post #18 of 35
CHDinCT
Proud Member of the 1K Club
CHDinCT's Avatar
MTF Member # 7272
Images: 7
Quote:
Originally Posted by TPS View Post
Kylied,
Take care-TPS
TPS - thanks to a tip a ways back from Volfandt, the coupler will click into and stay in the open position, though it's very sensitive. I have to play with it a bit but have gotten it to stay in the open position while sliding it onto the shaft.
__________________
Chris
BX25, 54" MMM, 5' Rake, Wallenstein BX42 PTO Chipper, Woods Rear Blade, 54" front blade, 48" box blade, Ratchet Rake.
1993 Wheel Horse 520-H, 48" deck & vac bagger.
1967 Wheel Horse 1077 with 36" RD deck (in resto).
Cyclone Rake, and other toys, I mean tools
CHDinCT is online now   Quick reply to this message
Old 10-05-2009, 09:15 PM   post #19 of 35
Kenneth H
Senior MTF Member
Kenneth H's Avatar
MTF Member # 22130
Images: 7
I did not know it would click open...learn something here everyday!! I gotta try that.
__________________
2009 - Kubota BX2660, 60" MMM, FEL
2007 - YTH2654 Husqvarna mower
1995 - Kubota M4700 with FEL
1996 - John Deere GT275 with 48" MMM
Bush Hog Tiller 4'
Fred Cane 8' Bush Hog
Countyline 4' Bush Hog
Countyline 4' Landscape Rake
Kenneth H is offline   Quick reply to this message
Old 10-05-2009, 11:39 PM   post #20 of 35
Sawbuck
Senior MTF Member
Sawbuck's Avatar
Location: Texas Hill Country, Burnet County side of Kingsland
MTF Member # 2221
News to me also - another great tip!
__________________
Sawbuck
Live to Ride, Ride to Live
Kubota BX2660, Cub Cadet Poly Cart; Stihl MS170 Chainsaw, KM55R Combi-Motor, FS-KM Trimmer, HT-KM Pole Pruner, BG-KM Blower
Sawbuck is offline   Quick reply to this message
Old 10-06-2009, 03:59 PM   post #21 of 35
TPS
Senior MTF Member
MTF Member # 5447
CHDinCt,
Thanks, Volfan has all kinds of good info.
The coupling on mine will stay back but when I try to get it on the shaft I always seem to bump it enough to make it close before I want it to. That is why I started putting it onto the shaft first then hold it, pull the coupling back and slip it all the way on and check it. For me that works the best and is easiest.
take care,
TPS
__________________
Old 10-06-2009, 10:07 PM   post #22 of 35
Michael
Retired Mod
MTF Member # 21
Images: 9
I made this thread a sticky so that it remains at the top of this forum. Anyone else have any great tips continue to add them to this thread
__________________
Michael is offline   Quick reply to this message
Old 10-07-2009, 07:18 AM   post #23 of 35
Jimmyjo
Senior MTF Member
MTF Member # 18447
This spring I got a chain hoist at a garage sale and it has been the very handy for deck removal. I unhook everything except the pto and raise the BX about 15 inchs. Unhook the pto and pull the deck out from the front. If I need to service the deck then just lower the tractor and back it up and lift the deck with the hoist. To reinstall I just do this in reverse, works great for me.
Jimmyjo is offline   Quick reply to this message
Old 10-20-2009, 02:49 PM   post #24 of 35
mlange
MTF Junior Poster
MTF Member # 30267
BX2660 lover here also,just did my 50 hour service,and took the deck off for the winter,I also have a fel so lifting the front a little makes it very easy,I also put a note on the seat,before I put the deck back on saying"PTO.so i'll remember to double check it,before start up,a little over kill?? maybe,but usually around my house,I can't start and finish anything,with out being bothered,by someone or something,then when I get back to it I can't remember where I left off,did I mention I LOVE MY BX2660
mlange is offline   Quick reply to this message
Old 10-23-2009, 09:18 PM   post #25 of 35
mike dub
Senior MTF Member
MTF Member # 8644
Quote:
Originally Posted by CHDinCT View Post
I'd start by reading the manual to get the basic procedure down. A few things I do that are not in the manual are that I drive my back wheels onto a 2x6 to gain an inch+ of clearance then use the FEL if on the tractor to raise up the front wheels a few inches. Also, when I turn the gauge wheels 90*, I use the lower hole in the back two wheels which drops the back of the mower to less than an inch off the ground. (You may note there are two holes at the 90* setting on the gauge wheel axles.) I use the top holes on the front wheels since if I use the lower hole, the middle anti scalp roller will drag and prevent the deck from rolling. Having the back of the deck lower helps the mounting adjusting nuts clear the frame of my BX. If I use the top holes, even with the BX on a 2x6, the deck won't clear the frame when I try to roll it out.
By the way, congrat's on your new BX. Pic's are always welcome, some say required.
CHDinCT, driving back wheels onto 2x6s is a great suggestion. I always end up having to remove the gauge bolts from the rear lift link receivers (that stick up vertically from the back end of the MMM) in order to just slide the mower under the rear lift links (even when they're fully raised). Driving onto 2x6 must give just the extra height needed so I can avoid taking off the height-set gauge bolts. Great lil tricks a guy learns on this forum. Thanks,
Mike in NC
mike dub is offline   Quick reply to this message
Old 10-25-2009, 07:54 AM   post #26 of 35
harpoonalt
MTF Junior Poster
MTF Member # 1931
Putting the PTO to rear eliminated a lot of hassle. I use an ATV jack and raise the rear up a few inches to slide the deck under. With the PTO tip I got the deck on in 7 minutes. I use an old rug to lay on while hooking up the PTO. I put it on the floor and up and over the deck to keep as much dirt or grease off me as I can, Much more comfortable for my old bones.
harpoonalt is offline   Quick reply to this message
Old 10-27-2009, 06:28 AM   post #27 of 35
kylied
MTF Junior Poster
MTF Member # 33058
I took the 60'' MMM off for the first time last weekend, came off very easy, last night I reinstalled it, took me about 15 minutes most of time was spent getting the L pins lined up, surprisingly the shaft drive coupling went on very easy, the trick was to put the PTO in rear which allows the mid PTO to spin freely, I did have to lift the deck on each side just a bit to get the L pins to go through the hole, is this normal ??
kylied is offline   Quick reply to this message
Old 01-08-2010, 08:24 PM   post #28 of 35
Valve cap
MTF Member
Valve cap's Avatar
MTF Member # 36946
Wink Re: Mower removal and install
It takes me more time to turn the wheels than it takes to remove or install the mower itself!
Valve cap is offline   Quick reply to this message
Old 05-21-2010, 10:16 AM   post #29 of 35
shrekbelly
MTF Member
MTF Member # 14945
lost my cherry on the bx mower deck install yesterday. i can't say i did it in ten minutes . . . because i did deck and pto maitainence at the same time. my shirt sleeve length is only 32", so i decided to jackup and remove the left rear tire for easier access to the pto.
lost a craftsman socket, hit it to hard with a breaker bar (oh well!). the deck appeared semi level so off to cutting i went. engaged the mower deck and i heard a high pitched whine that i knew wasn't right. stopped immediately. didn't want to take tire off again, so i backed the bx up on oxlite ramps hinged on a guard rail around the driveway.
my initial pto hook up didn't look right, in fact-wasn't clicked in. with the sloppiness of my greasing it, i thought it had muffled my first connection attempt. second time, it worked like a charm and loudly clicked in.
does anyone have any advice or specific 1-2-3 steps for getting the deck right? i bought the jdeere yellow plastic deck leveler tool ($8.95) and need to work on it.
thanks in advance for any and all suggestions. shrekbelly
shrekbelly is offline   Quick reply to this message
Sponsored Links
Advertisement
Old 05-21-2010, 10:33 AM   post #30 of 35
Kenneth H
Senior MTF Member
Kenneth H's Avatar
MTF Member # 22130
Images: 7
Shrek,
I have found that if I run my front tires up on a 2x6, or similar, the MMM will roll right out.
Never thought about taking that tire off, but the Craftsman socket is guaranteed! I can reach the PTO with my left arm so I would not do that.
I can take my mower on and off in just a few minutes. Takes me longer to change the gauge wheels so it will roll, than it does to get deck off.
__________________
Bush Hog Tiller 4'
Sponsored Links
Advertisement
Closed Thread
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
