Removing Bolens Steering Shaft - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-24-2009, 09:14 AM   post #1 of 5
wrpratt
MTF Junior Poster
MTF Member # 32848
Default Removing Bolens Steering Shaft
I have a Bolens ridiing 42" mower with the teeth striped at that bottom of the shaft. I have taken the deck off and the wheel off but can't remove the shaft. I see that there is a phillips head screw/bolt that attaches it underneath but is there a special way to get it off as it won't turn?
wrpratt is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-24-2009, 10:21 AM   post #2 of 5
JustinR
Proud Member of the 1K Club
JustinR's Avatar
MTF Member # 10838
Default Re: Removing Bolens Steering Shaft
The model number would help us help you. Also, are you just wanting to fix this or is this a restoration?
__________________
Original Bolens 1250 - Restored Bolens HT-18 - Rebuilt 1886 to 1386 Diesel Loader w/ Powersteering Restored FMC Bean Cutler - Project 1477 - Troy Bilt GTX 20
http://huskylargeframes.blogspot.com/
http://www.youtube.com/user/jtube76?feature=guide
JustinR is offline   Reply With Quote Quick reply to this message
Old 09-24-2009, 10:39 AM   post #3 of 5
wrpratt
MTF Junior Poster
MTF Member # 32848
Not sure of the model number right now as I'm at work. I bought it in 2002 and am trying to fix it. Thanks.
Old 09-25-2009, 02:48 AM   post #4 of 5
walter g
2000 Posts and climbing!!!
walter g's Avatar
MTF Member # 9285
wrpratt
Welcome to MTF. The newer Bolens are MTD made, so you would get more answers in that subforum.
But I can answer your question. The slightly older MTD's used a bolt instead of that screw. Put it back with the correct length bolt.
There are 2 bolts that hold the sector gear plate in. Remove them. Now you can move the gear out of your way. Hold the screw with a phillips head socket on a rachet.Do not try to turn it.
Now have someone else turn the steering wheel, and it should come loose.
The gear and shaft is sold as one piece. I believe they run around $45.
Check the plastic hex bushing the steering shaft goes into. They are almost always bad. Price $3.49.
There ia a bushing under the steering sector gear. Make sure it is good. It is only a couple bucks to replace.
But please post your model number info. Incase yours is slightly different.
Post the entire number so I can look it up. Sticker should be under your seat.
Pinion gear failures are caused by something. So check all bushings and joints in the steering and front-end.
If you have any questions please ask.
Walter
walter g is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-25-2009, 09:25 AM   post #5 of 5
Troybilt Fanatic
Senior MTF Member
MTF Member # 21926
You may try either a short phillips or a 90 degree phillips for cramped spaces works well. Ideal if someone was holding the steering wheel to remove these.
Troybilt Fanatic is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
