Gravely Engine Swap - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-22-2009, 01:21 PM   post #1 of 20
gburnett
3K Poster!!!!
MTF Member # 9399
Default Gravely Engine Swap
I have a 430 Gravely with a 12HP Kohler that runs good and a 816 Gravely with a bad engine.Can I put the 12HP Kohler out of the 430 in the 816?
gburnett is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-22-2009, 01:24 PM   post #2 of 20
Bushbuck
Proud Member of the 1K Club
Bushbuck's Avatar
MTF Member # 30486
Default Re: Gravely Engine Swap
when you remove the two engines if the shaft and the mounting plate is the same than yes you can.
Bushbuck is offline   Reply With Quote Quick reply to this message
Old 10-02-2009, 02:30 PM   post #3 of 20
gravelymay
Senior MTF Member
gravelymay's Avatar
MTF Member # 20627
Hi
Short answer is NO
The 400 engines will fit the 2 wheel tractors with turned down Crank.
The 800 8000 and all the 8 speed trans are a like
Their Cranks are 1 1/8 X 3 1/2 to 4.00
Thanks Bruce g
gravelymay is online now   Reply With Quote Quick reply to this message
Old 10-02-2009, 08:03 PM   post #4 of 20
eveled
2000 Posts and climbing!!!
eveled's Avatar
MTF Member # 28747
Images: 8
[QUOTE=gravelymay;834941]Hi
Short answer is NO
/QUOTE]
The 400 series engines will work on a walkbehind but not on an 800 or8000 series. Those engines are worth something as they are getting harder to find and there is no replacement. There are lots of engines that will fit an 800. Ed
__________________
Here's to our veterans past present and future
Machine of The Month link
eveled is offline   Reply With Quote Quick reply to this message
Old 10-02-2009, 08:41 PM   post #5 of 20
gburnett
3K Poster!!!!
MTF Member # 9399
Thanks for the information.So the run of the mill engines will fit the 800 series? I have an 816 that needs an engine and I had the good engine in the 430 I thought I might use.
Old 10-03-2009, 12:52 AM   post #6 of 20
bluegoose
bluegoose's Avatar
MTF Member # 23010
Gravelymay is the resident guru on replacement engines for the 800 tractors and others. He's had great success mounting Honda engines to these machines - he's well-versed in the needed adapter/bushing parts.
bluegoose is offline   Reply With Quote Quick reply to this message
Old 10-03-2009, 01:34 AM   post #7 of 20
gm1276
MTF Member # 26660
So you can't just put any K series on a walk-behind? I thought they all had the same shafts?
gm1276 is online now   Reply With Quote Quick reply to this message
Old 10-03-2009, 01:48 AM   post #8 of 20
bluegoose
bluegoose's Avatar
MTF Member # 23010
The shafts are roughly the same size, but the crankshaft gears are different between the 400 series riders/walk-behinds and the 800 series. The first being a two piece stepped gear and the latter being more a "spider" shaped gear. On the walk-behinds, I believe the adapter plates are the same for most of the common K-series engines. That might include up thru and including the 16HP models, but I'd have to check on that.
Old 10-03-2009, 07:39 AM   post #9 of 20
Ingersoll444
ex spelling bee champ
Ingersoll444's Avatar
MTF Member # 16
Images: 14
Quote:
Kohler made many diferent cranks, blocks, and oil pans for the old K's to fit diferent spec's.
__________________
Paul B
Visit The Case Ingersoll Colt Forum.
SUPER Of The Month 10/2011
Ingersoll444 is offline   Reply With Quote Quick reply to this message
Old 10-03-2009, 07:34 PM   post #10 of 20
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
My crank for my 430 is stepped down for a polite bearing..
__________________
Kbeitz is online now   Reply With Quote Quick reply to this message
Old 10-04-2009, 12:42 AM   post #11 of 20
bluegoose
bluegoose's Avatar
MTF Member # 23010
The Tulsa Small Engine Warehouse is a pretty good source for replacement engine information - all the specs for the different K-series engines (and a whole bunch of others) are listed there.
Old 10-04-2009, 03:59 AM   post #12 of 20
eveled
eveled's Avatar
MTF Member # 28747
Images: 8
Quote:
mine is too. Ed
__________________
Old 11-03-2009, 01:36 AM   post #13 of 20
gravelymay
Senior MTF Member
gravelymay's Avatar
MTF Member # 20627
They are completely different
The walk behind Kohler and the 400 or 4 Speed is a step down shaft 7/8 to 3/4 on 3/4 of the end.
The 8 speed transmissiom takes a 1 1/8 X 3 3/4 to 4. in long
The Rider has a larger counter bore also.
Thanks Bruce g
Name:	DSC08134Briggs  16 Hp with out adapter.JPG
ID:	81222   Click image for larger version
Old 11-03-2009, 08:11 AM   post #14 of 20
Kbeitz
Kbeitz's Avatar
MTF Member # 86
Images: 4
I did find a place that sell new engines with step down shaft for the 400's on the net...
__________________
Sponsored Links
Advertisement
Old 11-03-2009, 08:13 AM   post #15 of 20
Fla Don
Gravely bug bit.
MTF Member # 33720
Quote:
Current largest HP engine that will fit the 800/8000/-G transmissions is the B&S Big Block Vanguard 35 HP Then you can go down from there to anything larger than a 10 HP with the right crankshaft size. It isn't hard to make an adapter plate for the 8-speed tranny. You also need to make sure that the adapter will seal the cranksaft to engine area or adapter to crankcase areas.
Fla Don is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
