MyTractorForum.com - The Friendliest Tractor Forum & Discussion Board and Best Place for Tractor Information on the web!!!
Home MTF Gallery Add To Favorites! Set MTF As Your Homepage FAQ
Go Back   MyTractorForum.com - The Friendliest Tractor Forum & Discussion Board and Best Place for Tractor Information on the web!!! > Lawn and Garden Tractors > Electric & Alternative Powered Machinery
Register Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
Old 09-21-2009, 12:16 AM   #1
migraineman
Senior MTF Member
migraineman's Avatar
MTF Member # 26161
Default Scooburban
Restoration fundamentalists be forewarned ... here there be dragons.
I am in the process of converting a 1967 Sears Suburban over to electric drive using readily available scooter parts. Yes, this frankentractor shall be known as the Scooburban. The donor tractor is missing it's engine and was about to be sent to the recycle heap. The steering, frame, and transaxle are all in good working order. I purchased a Currie Technologies scooter motor (600W), 40A speed controller, and twist-grip throttle. The intended uses of this vehicle are:
- allow the wife to haul mulch, dirt, plants, etc without being intimidated by the gas tractors
- haul the kids around the neighborhood at Halloween
- supplement the gas tractors for the upcoming GarageMajal build
- build an EV (something I've wanted to do for years)
The first order of business was to drop the transaxle (yes, I had a little help.)
There's plenty of space under the frame ahead of the transaxle, so I'm fabbing a bracket that mounts directly to the transaxle case. The drive section will be mounted as a unit.
I ran out of daylight today, but you get the general idea. The motor will mount on a plate with slots to allow the belt to be tensioned. I plan to use Group 24 or 27 marine deep cycle flooded batteries. With no pesky motor to get in the way, they should mount up front without issue. The brake starter-interlock switch will be tied into the speed controller's brake switch input. More details as I invent 'em.
A note about the hunk-of-unistrut-bracket - the trans case has draft on the sides. Two 5/16-18 nuts were match-welded to the bracket such that the inner edge of the unistrut contacts the case. The outer edge was shimmed such that the forward face of the bracket is perpendicular to the transmission input pulley. This relationship is easily verified with a large framing square placed across the face of the input pulley. The assembly was fussy to align, but it bolts up really nicely.
migraineman is offline   Reply With Quote
Old 09-21-2009, 01:06 AM   #2
jeepersmitty
Retired Aug.31 2007
jeepersmitty's Avatar
MTF Member # 6130
Default Re: Scooburban
Looking good.It is always nice to have help. Keep us updated as you go along.
__________________
I always know...
God won't give me more than I can handle
There are times I just wish He didn't trust me quite so much.
jeepersmitty is offline   Reply With Quote
Old 09-21-2009, 01:46 PM   #3
walter g
Proud Member of the 1K Club
walter g's Avatar
MTF Member # 9285
Looking foward to this build.Looks like a neat project.
walter g is offline   Reply With Quote
Old 09-21-2009, 01:54 PM   #4
Jim_WV
Senior MTF Member
Jim_WV's Avatar
MTF Member # 241
Quite an unusal project for sure, looks great so far, keep us informed and for sharing .
Jim_WV is offline   Reply With Quote
Old 09-21-2009, 07:09 PM   #5
david doyle
david doyle's Avatar
MTF Member # 8803
Great project. Can you tell us about what you expect in terms of Battery needs etc. Love to learn more about it. a silent run around tractor would be be great!
david doyle is offline   Reply With Quote
Old 09-21-2009, 07:46 PM   #6
Titanium
Senior MTF Member
Titanium's Avatar
MTF Member # 30892
I'd be interested in the cost of materials, if it's not too nosy to ask.
I've been thinking about repowering an oldie, for my youngin to play with.
I hadn't considered going electric!
Bravo!
__________________
Retired from the rat race... the race was fixed by the rats!
Titanium / Dave
Titanium is offline   Reply With Quote
Old 09-21-2009, 09:46 PM   #7
Justin
Father to Triplets + 1
Justin's Avatar
MTF Member # 19622
To add to all the other questions, how much power will that little motor provide? I know its 600 watts, but what does that equate to? How many batteries do you plan on using. Looks really cool, looking forward to future posts.
__________________
74 Sears ST 16 with automotive ignition conversion, 10" moldboard plow, cultivator, hiller, single disk with 2 cinder blocks, 42" MMM, middlebuster, manual 3pt hitch, Ag tires with wheel weights and tri ribs on the front
Justin is offline   Reply With Quote
Old 09-21-2009, 10:02 PM   #8
Big10
Vet-Wrencher
Big10's Avatar
MTF Member # 28454
__________________
Obstical's are those terrible things you see when you take you're eye's off you're goal-Henry Ford
Big10 is offline   Reply With Quote
Old 09-21-2009, 11:57 PM   #9
migraineman
Senior MTF Member
MTF Member # 26161
Please ask questions ... I don't mind. I'm making this up as I go along, so having an opportunity to discuss things is highly desirable. I'm assuming you have the necessary tools for a job like this, so I'm not including them in the "costs" section.
Costs -
- Donor tractor $50
- 600W electric motor $28 from All Electronics (unfortunately, sold out)
- 40A 24V speed control $33 from All Electronics
- 24V twist grip throttle $13 from All Electronics
- 2x Group 24 marine deep cycle battery ~$70 ea. (Sears, WalMart, etc)
- 10ft. Unistrut $18 from Home Depot (near the conduit in the electrical dept.)
- Anderson Power Pole connectors and crimper from Powerwerx.com, not expensive
- 50A battery disconnect switch $5 from Harbor Freight
- in-line fuse socket with 40A fuse, not expensive
- 2" drive pulley $6 from the local TSC
- brass tube from the junk bin
Need to buy -
- 24V battery charger
- more Anderson Power Pole connectors
- 8AWG stranded wire
- ring lugs (I already have an appropriate crimp tool)
- 1/2" drive belt (need to finish the bracketry to determine size)
- battery mount hardware
Performance -
I expect the motor to draw about 25A average. Group 24 batteries have a typical Reserve Capacity (RC) of about 100 minutes. RC is measured at a draw of 25A, so I expect about 100 minutes of operating time (decreasing as the batteries age.) This particular motor is rated for 600W output. With a 24V 36A input (that's what the label says) of 864W, the motor's efficiency is about 70%. Not stellar, but not horrible either. At the full 36A current, the batteries should be depleted in about 60 minutes. Moving up to a Group 27 battery would increase the RC rating from 100 minutes to about 150 minutes.
The motor turns at a little over 2600 rpm. The Tecumseh that powered this beast originally was set for 3600 RPM. I'm running a slightly undersized drive pulley, so I don't expect top speed to be the same. I'm not looking for that, but swapping in a larger drive pulley to match the belt rate isn't out of the question (but I don't think the 600W motor will pull as hard as the 12hp Tec mill.) The brass tube stock brings the motor's drive shaft up to 1/2", at which point I can swap in other pulleys in the future. I'm designing the tension mechanism to account for a future swap opportunity.
Old 09-22-2009, 12:21 AM   #10
migraineman
Senior MTF Member
MTF Member # 26161
Oh, a final comment on why I've chosen what I did. Scooter parts are readily available ... in fact there's a "donor" scooter in the garage with dead batteries. Being mass manufactured consumer goods, the prices are quite reasonable. Most are 24V, though the bigger ones use 36V electrics. At some point I plan to put a sinewave inverter on the Scooburban to supply electricity far from the house. Inverters expect 12V, 24V and 48V inputs. 36V doesn't line up with the long term plans.
Similarly, if I want to step up to a larger electric motor, I can get one as a replacement part for a Black and Decker CMM1000 or CMM1200 (which I also own, and have recently dissected.) This particular motor is available from DeWalt service for about $150. It too is 24V based, and claims 5hp equivalency. I also found another 24V motor from the American Lawn Mower Company for $77 - part number 3610139 that's part of the Earthwise 60020GT 24V electric mower. For any of the upgraded motors, I'd need to move to heavier wiring and a beefier speed controller, but the batteries would translate directly.
Finally, 1hp is roughly 750W. The 600W motor should be equivalent to 8/10hp. Applied properly, that should be quite useful. Consider that farmers used to pull a small plow behind a single mule or horse. A horse trots in the 10mph range. Honestly, I'm eager to see what I can do with "about 1hp."
Old 09-22-2009, 12:51 AM   #11
Titanium
Senior MTF Member
Titanium's Avatar
MTF Member # 30892
Weren't some of the old hit and miss engines under 1 HP?
They did a lot of work!
The mower pictured in my avatar, is about 1.75 HP at top rpm.
But, you wouldn't want to get your toes under it! Ha Ha
__________________
Titanium / Dave
Old 09-22-2009, 12:31 PM   #12
Tractor-Holic
3K Poster!!!!
MTF Member # 8867
Put a starter motor in it,and hang on!... I saw a video of a mini-bike some car techs mounted a ford starter on,direct chain drive to the rear sprocket,and they only had a solenoid and an on off switch--the driver has to just about sit on the handlebars when he hits the switch,otherwise it'll just about flip over backwards!..it only had one battery too!..
With the low gearing a Suburban has,it doesn't take much HP to get one moving..I put a 7 HP Briggs on a SS-12,and I hardly feel any difference in power,as far as pulling goes--probably wouldn't mow that great though..
Tractor-Holic is offline   Reply With Quote
Old 09-22-2009, 02:32 PM   #13
david doyle
MTF Member # 8803
Thanks alot for the info. I have an 12.5/38 MTD without a motor which might be just perfect for this type of project and you have done 90% of the leg work already!
Please post your updates here (time permitting) really enjoy seeing smart people do smart things
Old 09-22-2009, 10:03 PM   #14
migraineman
Senior MTF Member
MTF Member # 26161
We'll see. I'm not above doing stupid things.
I've seen a couple of MTD electric conversions that involve putting a motor in place of the IC vertical shaft engine. Belts to the transaxle and deck are run as stock. Battery placement is an issue, mostly because the motor is sitting in the best place for batteries. I haven't seen anyone hang the electric motor directly off the transaxle, but I don't see why that would be an issue. I actually considered getting an MTD tractor for this effort, simply because all the modern machines are manufactured by MTD ... mostly. I do, however, have a soft spot for the older machines. This Suburban was acquired on a trip to purchase a 3-point hitch for the SS12. Not what I intended, but I learned long ago to seize the opportunities when they are presented. (and yes, I caught hell from the wife for bringing *another* broken tractor home.)
Old 09-22-2009, 11:02 PM   #15
Titanium
Senior MTF Member
Titanium's Avatar
MTF Member # 30892
Quote:
Wiat until you've got it all fixed up and running well. She'll be happy using it!
__________________
Titanium / Dave
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
