MyTractorForum.com - The Friendliest Tractor Forum & Discussion Board and Best Place for Tractor Information on the web!!!
Home MTF Gallery Add To Favorites! Set MTF As Your Homepage FAQ
Go Back   MyTractorForum.com - The Friendliest Tractor Forum & Discussion Board and Best Place for Tractor Information on the web!!! > Tractor Talk > Home Made Tractors, Implements and Accessories
Register Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Home Made Tractors, Implements and Accessories For you guys handy with a blow torch, welder or a wrench.. show us what you can do....
Reply
Thread Tools Display Modes
Old 09-11-2009, 08:18 PM   #1
pesimann
MTF Junior Poster
pesimann's Avatar
MTF Member # 23103
Default building a potato Digger
bin tanking a about building a potato digger.
I sow some pic from Sonny on this forum and it gave me some idea of hat I wanted
It worked ok for the first time but I need to put more sand in may garden for better result(to much clay and water mix to together and you have lumps )
The attachment is for may simplicity sunstar 20hp and the idea is to scope 1 row of potatoes and sake the dirt out of it and the live the potatoes lain on top
Well hear are some pic of the work.
ID:	76700  Click image for larger version
ID:	76701  Click image for larger version
ID:	76702  Click image for larger version
pesimann is offline   Reply With Quote
Old 09-11-2009, 08:22 PM   #2
Justin
Father to Triplets + 1
Justin's Avatar
MTF Member # 19622
Default Re: building a potato Digger
Looks good. Is that a motor on top to shake the dirt through the screen? what powers it?
__________________
74 Sears ST 16 with automotive ignition conversion, 10" moldboard plow, cultivator, hiller, single disk with 2 cinder blocks, 42" MMM, middlebuster, manual 3pt hitch, Ag tires with wheel weights and tri ribs on the front
Justin is offline   Reply With Quote
Old 09-11-2009, 08:22 PM   #3
SonnyT
2000 Posts and climbing!!!
SonnyT's Avatar
MTF Member # 21893
Looks like it would work. Needs some kinda vibrator on it to help separate the potatos from the clay dirt,IMO
__________________
Old(er) but can still learn, God willing
I will miss my Texas Sand Flea!
SonnyT is offline   Reply With Quote
Old 09-11-2009, 08:24 PM   #4
SonnyT
SonnyT's Avatar
MTF Member # 21893
Sorry I didn't see what looks like a vibrator on top.
__________________
Old 09-11-2009, 08:39 PM   #5
pesimann
MTF Junior Poster
pesimann's Avatar
MTF Member # 23103
The is a motor on top with a wheel which is of balance and rubber pads between the frame and the caker.
and it is power with the battery in the tractor
Old 09-11-2009, 09:34 PM   #6
Wheeler09
Senior MTF Member
Wheeler09's Avatar
MTF Member # 31491
MMM I like taters wish ihad some to dig
__________________
1 - B 100
1 - 1974 White MTD 990a ( parts rig )
1 - 1977 Farm King 990
1 - Cub 1250
1 - 67 Simplicity 2 wheeler model "W"
2 - Toro S200
1 - Toro Snow Pup
1 - toro SnowMaster
1 - Lawn Boy 10327
1 - TroyBuilt Tiller
1 - Poulan "Wild Thing"
Wheeler09 is offline   Reply With Quote
Old 09-12-2009, 02:05 AM   #7
PaulChristenson
Rara Avis
PaulChristenson's Avatar
MTF Member # 8602
If you are building a digger...
You might as well build a potato seed cutter as well...
http://www.ussmallfarm.com/PotatoSeedCutter.html
__________________
Paul in VT
The information is provided without warranty of any kind. I give no warranties either expressed or implied, including warranties of merchantability and fitness for a particular purpose. In no event shall I be liable for any damages whatsoever including direct, indirect, incidental, consequential, loss of business profits or special damages, even if I have been advised of the possibility of such damages.
PaulChristenson is offline   Reply With Quote
Old 09-25-2009, 02:27 PM   #8
Cap6313
MTF Member
Cap6313's Avatar
MTF Member # 32565
a potato digger
ID:	77769  Click image for larger version
Cap6313 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
