Need help finding a plow attachment for a Troy-Built Pony... - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-10-2009, 07:53 AM   post #1 of 9
nickpapagiorgio
MTF Member
MTF Member # 32252
Default Need help finding a plow attachment for a Troy-Built Pony...
Hi everyone,
I just bought a used Troy-Bilt Lawn Tractor. It's only a couple years old. The manual identifies it as a "Model Series 77T." There are accessories listed on the tractor itself and in the manual that include a plow attachment. The part number identified is OEM-190-833. The mower is supposed to be compatible with MTD accessories. I found this plow attachment for $299 at Home Depot: http://www.homedepot.com/Outdoors-La...atalogId=10053
I've read some reviews though that indicate the plow does not fit on "Model Series 700" lawn tractors. Also, my manual indicates the same thing.
I'm not sure if my mower (a Model Series 77T) qualifies as a Model Series 700 mower?? Does anyone know if this plow will work with my mower?
nickpapagiorgio is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-10-2009, 10:34 AM   post #2 of 9
Troybilt Fanatic
Senior MTF Member
MTF Member # 21926
Default Re: Need help finding a plow attachment for a Troy-Built Pony...
It is a 700 series Lawn Tractor. Only Garden Tractors use ground attachments. You could possibly make it fir but the frame will not withstand the forces put upon it using it that way.
Troybilt Fanatic is offline   Reply With Quote Quick reply to this message
Old 09-10-2009, 10:22 PM   post #3 of 9
nickpapagiorgio
MTF Member
MTF Member # 32252
Quote:
Thanks for the help... It's strange that they list the plow attachment on the mower itself if it's not intended??
Do you know whether it would fit without modification and whether damage to the frame would be an issue if I were just using it to plow a flat straight driveway (and being very careful)?
Also, which models are lawn tractors and which are garden tractors? I'm very confused by the way Troy-Bilt classifies their models by model number and pony/horse/etc.
Thanks again.
Old 09-11-2009, 12:13 AM   post #4 of 9
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
Well I see your talking about a snow plow(Dozer Blade) in your link and not and earth plow so yes your tractor can take that kind of plow with no problems. I think troy-bilt fanatic thought you were talking about a 10inch earth plow. The plow should attach on your tractor without any modification. All Current Lawn tractor made by MTD should be able to take that plow.
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is offline   Reply With Quote Quick reply to this message
Old 09-11-2009, 09:18 AM   post #5 of 9
nickpapagiorgio
MTF Member
MTF Member # 32252
Quote:
Okay. That makes sense. I now see why a "lawn" tractor wouldn't be able to accommodate an earth plow (that would be used in a garden). Sorry for using confusing terminology.
Old 09-11-2009, 09:34 AM   post #6 of 9
Troybilt Fanatic
Senior MTF Member
MTF Member # 21926
Ah my bad! Yes the snow/dirt plow will attach to this unit. What I meant was plows as in cultivator plows and earth digging attachments and the like. Sorry if confused you. Getting old you know. haha
Old 09-13-2009, 10:27 PM   post #7 of 9
nickpapagiorgio
MTF Member
MTF Member # 32252
Thanks for the help guys. I found a plow (dozer) attachment on craiglist this weekend for $65. I picked it up yesterday evening and put it on today. It's in great shape. It looks like the guy I got it from probably only used it once or twice.
The model number was OEM-190-620, which is different from what my manual says for my tractor. I didn't realize it until I got it home but it had me worried until today. Basically, it fit with only two minor modifications. First, one of the mounting holes on each side of the tractor was partially blocked by a bracket that accommodates the hood mounts. I had to get out my dremel and slowly bore out the part of the bracket that was blocking the hole. I also need to drill one hole in each side of the frame to get third bolt on each side. Right now the bracket is attached to the mower's frame with only four bolts, but I'd like six (three on each side).
Anyway, here are some pictures. Thanks again for your help.
ID:	76862   Click image for larger version
Old 09-16-2009, 09:52 AM   post #8 of 9
nickpapagiorgio
MTF Member
MTF Member # 32252
Something I found out that may be helpful to others...
I think the guy I bought the plow from had the handle assembled wrong. The handle is actually two pieces that are joined about in the middle by a set screw. In the picture, the placement of the handle seems fine but when the plow goes down, the handle move so far forward you have to almost get off the tractor to reach it. This got me thinking that something was installed correctly...
Sure enough, the handle was assembled wrong (I think). I removed the set screw and rotated the top portion of the handle 180 degrees so now, the handle is much lower when the plow is up and still reachable when it is down.
I've noticed a lot of pictures of plows where it appears the same mistake has been made. Assuming I'm correct, this may help others out as well.
Sponsored Links
Advertisement
Old 09-16-2009, 04:23 PM   post #9 of 9
nickpapagiorgio
MTF Member
MTF Member # 32252
It appears I was correct... Here's a picture from Home Depot's website that shows how the handle should have been installed:
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
