Pulling a tractor with a hydrostatic transmission, bad? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 09-05-2009, 08:56 PM   post #1 of 16
kaptain krunch
Senior MTF Member
kaptain krunch's Avatar
MTF Member # 27451
Default Pulling a tractor with a hydrostatic transmission, bad?
I read that pulling a tractor with a hydrostatic transmission, could ruin the hydro. Is there any truth to this?
__________________
Wheel Horse 212-6 Off Road Mower In Progress!
(and now on hold)
400cc, inline twin , 36hp go kart in progress!
kaptain krunch is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-05-2009, 09:01 PM   post #2 of 16
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
Default Re: Pulling a tractor with a hydrostatic transmission, bad?
you cna pull the bypass lever and pull it to get it back to the shop. but i would not recommend pulling one several miles, bypass or not.
__________________
Check out our new HOMEPAGE
davidg is online now   Reply With Quote Quick reply to this message
Old 09-06-2009, 03:18 AM   post #3 of 16
Boyd
5000 Strong & Climbing
Boyd's Avatar
MTF Member # 19439
Images: 10
Thats what we were told on the farm.
__________________
http://www.youtube.com/watch?v=mHVFE02NTgU For sale: Wards gas power sweeper. Agri-Fab 42" sweeper. Peco & Wheel Horse vacuums & hoses. WH C-175: bad trans, 42" RD deck & misc. Sears 20/46 mower deck. Lots more going up for sale.
Boyd is online now   Reply With Quote Quick reply to this message
Old 09-06-2009, 03:55 AM   post #4 of 16
TUDOR
9000+ Strong & Climbing
MTF Member # 28463
If you pull a hydrostatic tractor without engaging the by-pass or shifting the two speed rear axle into neutral (if equiped), you in effect are trying to run the hydraulic system backwards and the oil tries to go the wrong way through the hydraulic motor and pumps which effectively become check valves stopping the flow. Net result is very high pressure in parts of the case designed for low or zero pressure. You are trying to turn the tires against a very high ratio reduction unit with a lock on the other end.
Comparable scenario in automotive terms, pull a manual shift four wheel drive truck with the transmission in bull low, the transfer case in four wheel drive, low range and a large V-8 engine.
Bottom line, hydro is ruined because the case is broke, and so are you when you buy the replacement.
Bob
TUDOR is offline   Reply With Quote Quick reply to this message
Old 09-06-2009, 08:52 AM   post #5 of 16
Artpb
Proud Member of the 1K Club
Artpb's Avatar
MTF Member # 52
Images: 1
Local Public works department towed a Wheelhorse with a hydro down main street with a truck. The pump exploded and damaged a few cars parked along the street. Stated they where only doing 25 mph!
Artpb is offline   Reply With Quote Quick reply to this message
Old 09-06-2009, 09:11 AM   post #6 of 16
m.jodrey
5000 posts and climbing
m.jodrey's Avatar
MTF Member # 31184
Where does one find the by-pass on a 1973 bolens h16, I haven't found one ,and you can't shift them into neutral either.
Maynard
m.jodrey is offline   Reply With Quote Quick reply to this message
Old 09-06-2009, 10:19 AM   post #7 of 16
murphycc
MTF Member # 22890
Quote:
Well that's just pure stupid. Gov. employees.
Scott
murphycc is offline   Reply With Quote Quick reply to this message
Old 09-06-2009, 10:29 AM   post #8 of 16
Dude11
2000 Posts and climbing!!!
Dude11's Avatar
MTF Member # 8852
Images: 4
Quote:
Maynard
Ain't got a clue--But my money says it's there.They all have them,sometimes you need a manual to locate it.I'm sure someone here will know.
__________________
Dude11
Dude11 is offline   Reply With Quote Quick reply to this message
Old 09-06-2009, 10:58 AM   post #9 of 16
DLF_IN
MTF Member # 1844
Your H-16 does not have a by-pass valve. If you must tow it , try releasing the idler for the drive belts or as I was told, disconnect the drive shaft. You do not want to tow the tractor any faster than about 2 miles an hour. Any faster will damage the hydrostat pump and motor.
Dave
DLF_IN is offline   Reply With Quote Quick reply to this message
Old 09-06-2009, 02:49 PM   post #10 of 16
TUDOR
MTF Member # 28463
No by-pass? Jack it up and put a set of dollies under it, like the tow trucks use. Or a 'P' handle furniture dolly hooked on the draw bar. Just get the back wheels off the ground.
How far do you have to pull it? (See post #4.)
Bob
Old 09-06-2009, 03:33 PM   post #11 of 16
cleatusj
cleatusj's Avatar
MTF Member # 400
Images: 2
I just pulled my wheel horse out of the mud three times, just eased the hydro handle into reverse then pulled with outer tractor. When I got it out it wasn't pulling enough to run over me and other tractor.
__________________
I'm the guy purist/restorers don't like.
Keith .
cleatusj is offline   Reply With Quote Quick reply to this message
Old 09-06-2009, 08:23 PM   post #12 of 16
m.jodrey
m.jodrey's Avatar
MTF Member # 31184
Not that I have to tow mine , but I like the wheels dolly idea.Thanks guys.
Maynard
Old 09-06-2009, 08:29 PM   post #13 of 16
LLigetfa
standard issue neuralyzer
LLigetfa's Avatar
MTF Member # 15283
Images: 2
Here you go.
Tow Dolly
__________________
I don't suffer from insanity. I enjoy every minute of it!
LLigetfa is offline   Reply With Quote Quick reply to this message
Old 09-11-2009, 01:27 PM   post #14 of 16
ejstith
MTF Junior Poster
ejstith's Avatar
MTF Member # 29575
LOL !! I thought he was talkin' about using a Hydro for a "Pullin' Tractor" ... My nephews, who are into pullin' garden tractors, says a hydo won't work for a puller ... Seems to me it would be but I don't really know .. Anybody know of any hydro pullers ???
ejstith is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-11-2009, 05:05 PM   post #15 of 16
Benn
Simplicity Benn
Benn's Avatar
MTF Member # 25664
Images: 10
yea i thought thats what he meant at first too...anyways yea i think i have heard of hydro pullin tractors but i think the standard trans would do alot better.
__________________
Ben
case 195
MTD 990
Allis chalmers B-212
Allis chalmers B-10
Benn is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
