| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
| John Deere Forum John Deere Garden Tractor talk |
Thread Tools | Display Modes |
#1 |
Proud Member of the 1K Club
![]() Join Date: Apr 2008
MTF Member # 10838
Where is it? I can see the engine plate and numbers but was there a separate number for the tractor somewhere. I don't see anything below the key.
| Sponsored Links | |||
Advertisement | |||
#2 |
Citizen of Earth
Nothing below the key? Not even the 2 rivet holes for the tag that sould be there?
__________________
If it's FREE, it's for ME! ALWAYS remember to remove the spark plug wire from the plug before sticking your hand in the machine!!!! The fingers you save could be your own. |
#4 |
MTF Member # 10838
It is a square fender 110 also. Runs and mows excellent. What's a tractor like this worth?
#5 |
Senior MTF Member
MTF Member # 27775
To me a couple hundred would be a good price. To someone else, hard to say depends on how bad they want one. The round fendered ones are worth a bit more I think.
#6 |
MTF Member # 10838
How common was the hydraulic lift option? Half of the 110's made? Less than half? More than half?
#7 |
MTF Junior Poster Esq.
Hydro lift is fairly rare. You can tell by the bucks they bring on ebay.
I've only seen 1 out of maybe 20. probably closer to 50. Square fender 110's aren't worth much around here. Sold a decent running one for $100 after trying for a fairly long time to get more. Looked about like the OP's with a better hood & seat. |
#9 | |
MTF Member # 10838
Quote:
| Sponsored Links | |
Advertisement |
#10 |
Senior MTF Member
If it is a 1968 model, it is probably a "sidetag" model. Lift the hood, and you'll see it on the side of the dash pedestal. You can see it without raising the hood, but one should always look at his engine as often as possible
__________________
http://gardentractorswap.com Sears GT/18, Case Ingersoll 444 Ford LGT 100, JD 110, JD 112,JD 216,JD 318, Simplicity Sunstar, Simplicity 3014 w/tiller plow blade, sicklebar, Ariens S-12h,Gravely 816T, Deutz-Allis 1920 Ultima (2) |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
