#1 |
smokey hollow
MTF Member # 17780
Good Morning fellow tractor nuts;
Changed transmission fluid this morning with cub filter and mobil 1 15w50. Tractor runs quiet and strong. Wanted synthetic for winter use. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Proud Member of the 1K Club
Good deal wesk. I assume this is on your late model 2550 where Cub Cadet Drive System Fluid Plus is specd? I too bucked the system ~4yrs ago and swapped out to Shell Rotella-T 15w40 for the trans on my 2544. I dunno that I would have gone to a 50wt variant for winter use, but it should be fine for you.
Joel
__________________
Mowers of the past: 2010 Cub Cadet Z-Force 44 fab. 2005 Cub Cadet 2544. 1979 Case 220. 2003 MTD Yardman 600 series transmatic 1992 John Deere GT262 1970 John Deere 110 |
#3 |
Senior MTF Member
MTF Member # 22705
I have to jump in here, I have been using Mobil 1 for several years in my motorcycles (Gold wings), and have not had any problems year round. Here in New England it gets kind of brisk during the winter, and when I was a working stiff I rode year round except when there was ice or snow on the road. I did have to question my sanity a couple of times while suiting up when the temp was hoovering around 18 deg. The 15-50 did not give a problem. I started using it in a 1200CC Kawasaki Voyager, and the first thing I noticed is that I could shift it without hearing the gears clash. I used to pull a camper with the wings, and never had a problem. I used the 15-50 in my old Rears, and Throwback (Sears) riding lawn mower, however I did not use that in the winter. I will be using it in my CC in another week or 2 as I almost have 50 hours on it........
__________________
GWDave1997 Cub Cadet LTX 1045, 46" plow/Dozer blade Chains, Home made weight box, Agri-fab Aerator, Agri-fab 85lb spreader Sears (Agri-Fab Vac N Go) - Professional lawn Vacuum/W extension hose Happiness is a nice warm day, a crooked road on a motorcycle. |
#4 |
smokey hollow
MTF Member # 17780
Joel; I used it on my 07 gt2550. Mowed the yard this afternoon.Worked great.
Tractor has over 200hrs. already.Have never had a problem of any kind. Wesk |
#5 |
Senior MTF Member
MTF Member # 31189
TuffTorq hydros recently changed the recommended oil from 10W30 to synthetic 5W50
| Sponsored Links | |
Advertisement |
#6 | |
Quote:
Joel
__________________
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
