How does an 8N governor work? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-29-2009, 11:42 PM   post #1 of 11
kweeksdraw
Senior MTF Member
kweeksdraw's Avatar
MTF Member # 29458
Default How does an 8N governor work?
Not the mechanics of the thing, but what can I expect it to do?
My only other tractor experiance is using a Ferguson TO-30. On that model I set the speed I wanted with the throttle and the governor kept that speed via the throttle. I seldom had to do any adjustment. If properly adjusted, how should the 8N behave?
kweeksdraw is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-30-2009, 11:06 AM   post #2 of 11
Grand Valley Tractor
Senior MTF Member
MTF Member # 29932
Default Re: How does an 8N governor work?
It would behave exactly the same. However, if it "hunts" or doesn't allow smooth throttle adjustments, you may need to rebuild it. It's not that big of a deal to rebuild them...I'm doing one now for our store. We have the kits in stock pretty cheap. You can buy a rebuilt one...but that can get expensive.
http://www.grandvalleytractor.com
Grand Valley Tractor is offline   Reply With Quote Quick reply to this message
Old 08-30-2009, 12:31 PM   post #3 of 11
Dan
Senior MTF Member
Dan's Avatar
MTF Member # 883
Images: 2
That is the purpose of a governor. And the ferguson model uses the same type of governor the 8N does. If your governor on the 8N does not keep it the same speed as you go ever hills or load the engine down - it needs to be adjusted or rebuilt.
If you havent been introduced to the I&T FO4 manual - this may be an excellent time to get one.
Dan
__________________
Old Iron Addict
1948 8N Delilah
1954 NAA Rustbucket
1939 9N (Name to be forthcoming)
1952 8N Sampson - Gone but not forgotten
8N Acres
Dan is offline   Reply With Quote Quick reply to this message
Old 08-30-2009, 10:53 PM   post #4 of 11
kweeksdraw
Senior MTF Member
kweeksdraw's Avatar
MTF Member # 29458
This tells me that the governor on my tractor isn't working at all. At one point while I was setting the timing (all fouled up when I got it) I rev'd it up around 2200 and it did what I think you all are calling hunting. But after I got the timing set, I've never seen it work or hunt.
I've been doing some refurbishing and just today bolted on a new exhaust/intake manifold. It is supposed to be like the original; the old one was quite different and the carburetor sets a little farther forward on this one than with the old one. So I'll be readjusting some of the linkages. Can you give me any hints on getting it right the first time?
Old 08-31-2009, 10:14 AM   post #5 of 11
rscurtis
5000 Strong & Climbing
MTF Member # 25367
With the governor arm in the full throttle position (as pulled by the spring), the throttle on the carb. should be wide open. Adjust the linkage to achieve this relationship and you should be fine.
rscurtis is online now   Reply With Quote Quick reply to this message
Old 08-31-2009, 04:13 PM   post #6 of 11
souNdguy
Proud Member of the 1K Club
souNdguy's Avatar
MTF Member # 94
Quote:
yep.. and no play or preload.
soundguy
souNdguy is offline   Reply With Quote Quick reply to this message
Old 08-31-2009, 08:36 PM   post #7 of 11
kweeksdraw
Senior MTF Member
kweeksdraw's Avatar
MTF Member # 29458
O.K., let me see if I have this right...
1) The long arm on the gov. is forward, the spring being closed (not pulling) with no end play.
2) The short arm connects to the carb. throttle and at this point the carb. is wide open.
If that is right so far, then the throttle rod must be all the way open too (all the way clockwise viewed from the seat), yes?
I just found this: "With the engine off and the hand throttle set at full speed, the carb should be wide open." Ahh, O.K..
Now, something else confuses me; The manuals say that the throttle rod spring (attached from the rod to the transmission bell) is trying to hold the throttle closed. Isn't that backward? Isn't it trying to rotate the throttle rod open? I'm having a hard time wondering how that spring could rotate the rod counterclockwise.
Before I get too far into all this adjustment, let me ask you this. If the governor had been "hunting" when I first had it running, doesn't that mean that the governor is working? And that my adjustments were way out of wack? If not...how tough is rebuilding a governor?
Last edited by kweeksdraw; 08-31-2009 at 10:16 PM. Reason: New info gleaned from thread search.
Old 09-01-2009, 11:44 AM   post #8 of 11
souNdguy
souNdguy's Avatar
MTF Member # 94
compensating spring...
Old 09-01-2009, 08:33 PM   post #9 of 11
kweeksdraw
Senior MTF Member
kweeksdraw's Avatar
MTF Member # 29458
Well it is all coming together for me now. I took the governor off the tractor to inspect it and found it in pretty good condition except that there were some minor flatspots on the balls and the retaining circlip was missing. I'm not sure what effect that would have, but it can't be good!
I'll order replacement balls, whip up a new clip and put it back together.
Old 09-02-2009, 07:02 AM   post #10 of 11
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Be careful when putting it back together!!! One of the mounting bolts is longer and requires it to be back where it came out!!!!! Placing it in the wrong location will cause it to hit the internal gears and chew them up!!!
__________________
Ken N Tx is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-02-2009, 10:40 AM   post #11 of 11
Justin
Father to Triplets + 1
Justin's Avatar
MTF Member # 19622
Quote:
Uh oh. Hope you remember which one went where
__________________
74 Sears ST 16 with automotive ignition conversion, 10" moldboard plow, cultivator, hiller, single disk with 2 cinder blocks, 42" MMM, middlebuster, manual 3pt hitch, Ag tires with wheel weights and tri ribs on the front
Justin is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
