| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
| Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board |
Thread Tools | Display Modes |
#1 |
Senior MTF Member
MTF Member # 28733
Need a diagram, or photo, of linkage rod and springs connecting the governor and carburetor. (Wisconsin engine) The engine will not idle all the way down with the throttle control pushed all the way in. I have the cable adjusted so it is pushing the pivot arm as far as possible. The governor arm comes to a closed position, at idle speed, but it is not holding the throttle closed. Also, if I pull the throttle control out, just a little, it races the engine nearly wide open. I think something is out of place or missing. Found a broken spring on the floor, but I've been working on a lot of different projects today, so I'm not sure if the spring belongs to the Bolens
| Sponsored Links | |||
Advertisement | |||
#2 |
Senior MTF Member
![]() Join Date: Jul 2009
MTF Member # 29341
I've been working on my 1050 today, all original.
I can take pictures in the morning and post them if it'll help. I have to pull the air cleaner and tube off to put in the new points and condenser, so I can see to set the points. Which will show the linkage connections better when it's all out of the way. |
#3 |
Senior MTF Member
MTF Member # 28733
Thanks, that will help a lot.
#4 |
Senior MTF Member
MTF Member # 29341
Hope these pics help. I had to shrink them for the site. If you'd like to see the full size pics, message me with your email.
#5 |
Senior MTF Member
MTF Member # 28733
Thanks for the pictures. I won't get a chance to work on this till Monday. I did take a quick look to compare your pictures to what is on my tractor. I can see, right off, that my spring is in a different hole on the governor arm. Yours' is in the third hole from the top, mine is in the third hole from the bottom. Maybe moving the spring will cure the problem.
| Sponsored Links | |
Advertisement |
#6 |
Senior MTF Member
MTF Member # 28733
I finally got back to this project today. I moved the spring to the same position as in the picture, but still can not get the engine to come down to an idle. All the linkages are moving freely. It seems like the governor is not working.
If I disconnect all the linkages, except for the rod between the governor and the carburetor, Shouldn't the governor be holding the engine at an idle once the engine is running? |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
