| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
Thread Tools | Display Modes |
#1 |
MTF Junior Poster
MTF Member # 31621
Hi guys,
I'm looking for some help 'cause I'm out of ideas. I have a 2001 John Deere 4100 and it isn't charging the battery. It all began after I finished mowing and shut it down. A few minutes later I tried starting it and it wouldn't turn over. I jump started it and although it turned slowly, it caught and started so I finished my work. The next day I went to start it and again it wouldn't turn over, just click like a low battery. I cleaned the battery terminals and jump started it again. I began mowing again and after a few minutes the lights began getting brighter and then they blew out (a voltage surge of some sort). I continued mowing and about 10 minutes later the engine stopped like I had turned it off. I replaced the battery and it now starts and runs fine, however, I am getting less than 12 volts at the battery, the same number whether it is running or not. I checked the alternater and it is putting out the 28-32 AC volts I was told it should. So I just replaced the voltage regulator ($143) and it is still less than 12 volts at the battery. Sorry for the long winded explaination but I'm hoping someone else has had a similar problem and can help. Thanks in advance for any input anyone may have. Brian |
| Sponsored Links | |||
Advertisement | |||
#2 |
5000 Strong & Climbing
![]() Join Date: Dec 2007
MTF Member # 8602
During Alternator Regulated current output test...
If amp output is high but battery voltage does not increase...test the battery and verify ALL GROUND CONNECTIONS...
__________________
So Long, and Thanks for All the Fish |
#3 |
MTF Junior Poster
MTF Member # 31621
Thanks for the input Paul. The battery ground is good, I'll check to see if there are any other grounds that are bad. How do I perform the "Alternator Regulated current output test" that you refer to? The alternator is suppose to put out 20 amps max (which I can't test that high with my meter) but I don't know what the regulator is suppose to put out for amperage.
#4 |
9K+ Poster
brifo,
Welcome to the forum!
__________________
Cheers JDFANATIC JD2210, loaded tires, 62C MMM, 210 Loader, 47" Snowblower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart, Stihl MS170 and HT101, Wallenstein BX32 PTO Chipper |
#5 |
MTF Junior Poster
MTF Member # 31621
Thanks for the warm welcome! A lot of good stuff in here, I'm glad to be a member.
#6 | |
MTF Member # 8602
Quote:
You still have to test your BATTERY...which is probably where the problem lies...
__________________
#7 |
MTF Junior Poster
MTF Member # 31621
I ordered the Tech manual on Monday but it hasn't come in yet. The battery is brand new, replaced it first, and then the voltage regulator. I'm hoping the Tech manual has the schematics and I can find some diode or relay that might be bad. But without the manual, I sit here and impatiently wait...
#8 | |
MTF Member # 8602
Quote:
![]() So when you get your manual...you will find an Electrical System Checkout Section and an Electrical System Diagnosis Section...you have to follow steps similar to a flowchart...after you slough through the 19 or so pages...you will understand why it is so hard to try an debug electrical problems on the internet...
__________________
#9 |
MTF Junior Poster
MTF Member # 31621
ouch, I hope not. This is getting expensive...
![]() Thanks for the advice, Paul. I know it is hard to trouble shoot online, wishfull thinking on my part that someone had the same problem and said, "oh, do this..." I'll be sure to put my solution on this post, whatever that may be...
#10 |
MTF Junior Poster
MTF Member # 31621
Is the hour meter in series with the voltage regulator and battery and could it have blown when I had the power surge, causing my problem? I'm assuming I can check the hour meter for resistance like any other electrical load?
__________________
John Deere 4100 410 Loader 54" Mid-mount Mower 5 ft York Rake 5 ft Grading Blade PTO DR Chipper 50" PTO Snowblower |
#11 |
MTF Junior Poster
MTF Member # 31621
Well I finally received the tech manual today, too many pages in the Electrical system section and not enough time left in the day to go thru it all, so I did what most guys do, looked for the quick test/fix. After 3 hours of testing components and analyzing the schematics and not finding a bad part, I switched the "K7 Safety Relay" with the "PTO Light Relay" (because they look identical) and the charging system started working. Oddly enough, the PTO system appears to be working fine also. So my best guess to the problem is the relay was/is partially damaged from either the battery cell popping or the voltage surge and although it was still passing current thru it, it wasn't enough to turn the voltage regulator on to charge the battery. I also put the old voltage regulator back in and it works fine, $140 wasted.
If anyone needs any details to help troubleshoot your own problem, let me know, I'd me happy to share them.
__________________
#12 |
MTF Member # 8602
You want to follow the STEP BY STEP Electrical System Diagnosis Section...do NOT jump a step unless they tell you to...it takes time, but that will find your problem...
![]() And, in general will save you from buying too many unneeded parts...especially since electrical parts are NOT returnable...
__________________
#13 | |
9K+ Poster
Quote:
Expensive, but glad you figured it out. Hopefully this will help others in the future.
__________________
#14 |
MTF Junior Poster
MTF Member # 31621
Thanks, I hope this can help someone in the future as well, 'cause if I can save someone the time (and money) that I invested, than that is what these forums are all about.
__________________
| Sponsored Links | |
Advertisement |
#15 |
MTF Junior Poster
MTF Member # 31621
Update: I tested the relay that was in the charging system (per the tech manual) and it is fried. The reason it worked in the PTO system is that system is an "open" system that under normal conditions, the relay is not energized. The charging system requires the relay to be energized to close the circuit and allow charging. I also did a search for the relay because John Deere wanted $90+ for it which seemed a little pricey to me. I found a cross reference to a Subaru Starter Interupt Relay and I ordered it thru the Subaru dealer for $42, it is identical. I could have saved a few more $'s if I had ordered it online from a Subaru Parts website, but I didn't want to wait any longer. Who knew an Auto dealer would be the cheaper alternative.
__________________
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
