oil leak in differential case at lift arm connection - help! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-27-2009, 05:08 PM   post #1 of 25
figgskzoo
Northwoods knucklehead
figgskzoo's Avatar
MTF Member # 31613
Default oil leak in differential case at lift arm connection - help!
Has anyone seen an oil leak in an 8N diff case where the lift arm attachment stud inserts into the diff case. By the looks of things, my lift arm attachment stud is somehow sliding outward and causing this leak. Anyone have any idea how to fix this? I've tried tapping on the attachement bolt head with a hammer - no go.
figgskzoo is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-27-2009, 05:57 PM   post #2 of 25
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Default Re: oil leak in differential case at lift arm connection - help!
To fix the lift pins, you need to take the left trumpet off..
Go in from the left side to reach the right castle nut, also fix the left side while you have the trumpet off..
Quote:
__________________
Ken N Tx is online now   Reply With Quote Quick reply to this message
Old 08-27-2009, 06:07 PM   post #3 of 25
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
More info..
__________________
Old 08-27-2009, 06:19 PM   post #4 of 25
jeepersmitty
Retired Aug.31 2007
jeepersmitty's Avatar
MTF Member # 6130
Images: 2
Ken I believe you have done this before.
__________________
I always know...
God won't give me more than I can handle
There are times I just wish He didn't trust me quite so much.
jeepersmitty is offline   Reply With Quote Quick reply to this message
Old 08-27-2009, 06:54 PM   post #5 of 25
figgskzoo
figgskzoo's Avatar
MTF Member # 31613
so, by the looks of things, left wheel, left trumpet, and diff carrier all need to be removed to get at this one, simple castle nut, eh? What a collosal PITA!
Do the trumpets hold the carrier case's outer bearing races, and assembly of the trumpets to the diff case 'squeezes' and mounts the carrier?
Ken = Da Man
Thx for great info, Ken!
Old 08-27-2009, 07:27 PM   post #6 of 25
Paul J
Senior MTF Member
Paul J's Avatar
MTF Member # 19817
Images: 1
Wow, I'm glad mine are tight!
__________________
REMEMBER & NEVER FORGET
We all live in the land of the free
BECAUSE OF THE BRAVE!
Paul J is offline   Reply With Quote Quick reply to this message
Old 08-27-2009, 07:36 PM   post #7 of 25
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
[quote=figgskzoo;795019 Do the trumpets hold the carrier case's outer bearing races, and assembly of the trumpets to the diff case 'squeezes' and mounts the carrier?[/quote]
Yes the carrier races are in the trumpets.
__________________
JohnW is offline   Reply With Quote Quick reply to this message
Old 08-27-2009, 09:14 PM   post #8 of 25
figgskzoo
figgskzoo's Avatar
MTF Member # 31613
What type / weight of oil do y'all recommend I use to refill the diff case?
Old 08-28-2009, 12:17 AM   post #9 of 25
souNdguy
Proud Member of the 1K Club
souNdguy's Avatar
MTF Member # 94
you can go back in with 90w gl1/3 the original spec.. or an 80w90 gl4/5 that is yellow metal safe.. or a utf fluid that mees the ford spec M2C134D.. remember.. it's your trans and hyd fluid too... about 5g worth..
soundguy
souNdguy is offline   Reply With Quote Quick reply to this message
Old 08-28-2009, 10:25 AM   post #10 of 25
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Also, DO NOT over fill the system, less is better than more here. Best way to get your oil level correct is to remove the bottom bolt of your side cover and fill till the oil just runs out of it.
__________________
Old 08-28-2009, 10:32 AM   post #11 of 25
figgskzoo
figgskzoo's Avatar
MTF Member # 31613
I'm a noob here - as my post numbers show. Nevertheless, in my short time here I've received some of the friendliest, most informative help I've ever had on any forum of any kind. Please accept a huge "Thank You"! Take a bow, guys!
Old 08-28-2009, 01:07 PM   post #12 of 25
Fred K
She is finished! 09-17-08
Fred K's Avatar
MTF Member # 16732
Images: 2
I had same problem. Had a guy do exactly as presented here. It worked and have had no problem since. So some good news for the future-after the fix.
__________________
Fred Kroon
A lot to be thankful for-I'm standing upright and am above the grass!
Fred K is offline   Reply With Quote Quick reply to this message
Old 09-01-2009, 10:07 AM   post #13 of 25
figgskzoo
figgskzoo's Avatar
MTF Member # 31613
Well, I receive my 'trumpet to diff case' gaskets today and am planning on tackling this project. I have three (more) questions? First, does the fact that I'm having this problem necessarily mean that I need to replace the studs with new ones? Second, are there any tips or tricks for this process that might make my job a bit easier? Third, should I put some RTV into the tapered 'sealing surfaces' in the trumpets and on the studs to assure a good seal?
Thanks for all the help, guys!
Old 09-01-2009, 10:55 AM   post #14 of 25
figgskzoo
figgskzoo's Avatar
MTF Member # 31613
Quick follow-up: I called my local equipment supply shop to see if they had new lift mount studs in stock. They also have sort of a tractor salvage yard. The fellow that answered tried to sell me used 'take offs' for $20 each. I explained to him that the tapered surface is a precisely machined area and that I was concerned with them sealing correctly. "You've gotta be kidding me!" was his response. "No, I'm not kidding you." was my reply. I won't be calling there again for *anything*. Basically, I already *have* used ones that aren't sealing...jeez.
Last edited by figgskzoo; 09-01-2009 at 11:39 AM. Reason: better explanation of call
Sponsored Links
Advertisement
Old 09-01-2009, 11:17 AM   post #15 of 25
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
As long as the hole is not wallowed or misshaped I would not use any thing on it, just torque it to 150# and forget about it. Now if it is egged any then if I were not going to replace the trumpet THEN I would use some #2 Permatex, I have had better luck sealing things of this nature with Permatex than RTV. What I guess I am saying is it depends on what the hole looks like.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
